JB3 2.0 1/4 mile log
01-24-2010, 08:03 PM | #1 |
Joint Chiefs of Staff
4918
Rep 115,980
Here are a couple random customer who provided logs from the 1/24 maps, both using the BMS methanol kit and open intakes.
The first is default map 7 doing a 1/4 mile run, and you can see how boost is tapering to only ~11psi at the shifts. The customer VBOXed the run and hit 120mph+! Simply amazing for these mild boost levels. The second is from a different customer who is at a higher altitude, and was captured on map 7 with top end boost taper reduced to around 14psi at redline. It's a long 3rd gear run. Holding this kind of boost at high RPM is not particularly safe, but with the JB3 you have the flexability to set taper as high or as low as you want. Cool stuff Mike |
01-24-2010, 09:38 PM | #3 | |
4918
Rep 115,980
Default on map 7 is around 15.5psi peak taper to 11psi @ sea level per the first log. Mike |
01-24-2010, 10:07 PM | #4 |
441
Rep 18,331
Now that JB platform is able to datalog, they should really clean up the graphs and spend more money on the software since they are going the same route as their competitor and they should make it more user friendly to read...For new users, looking at the logs, it looks like a child with a crayon thats gone wild!
01-24-2010, 10:12 PM | #6 |
Mastermind
71
Rep 1,360
Wasn't it noted in a thread that 380hp was a safe limit?
I'd be ecstatic to have hard evidence to support what actual psi level is detrimental to the turbos/engine and what horsepower level, as well. I have been working on my car for the last year on purely cosmetic items. This year the warranty is up and I have been planning on what products to purchase in one big swoop. However, I still don't feel comfortable with 400+ horsepower levels without knowing longevity. |
01-25-2010, 02:28 AM | #7 | |
13
Rep 229
It's a mechanical device. There's no safe limit for one concerned with reasonable improvements and longevity. Everytime the turbos hit max stock boost they get a little closer to dying, if they hit max boost which is a little bit above stock they'd get closer to dying by just that much extra. If you're not dealing with actually coming up with enough power to snap the drive shaft or whatever then you're just lessening the time til something breaks from wear and tear. I think..
2007 335i, Space Gray, Black/Alum, Sports, Prem, CA, Navi, iPod
01-25-2010, 05:10 AM | #8 | |
307
Rep 5,175
01-25-2010, 06:12 AM | #9 | |
4918
Rep 115,980
Another cool thing about the JB3 is how it loads maps. Each set of maps/firmware is in one file, and you always load that file so they can never be mixed up. And while loading it doesn't trigger any codes... Mike |
01-25-2010, 06:13 AM | #10 |
4918
Rep 115,980
More samples are planned, but here is a V3 log with 20?/samples/second and similar scaling. Is this really more informative or readable? I really don't think so. I don't need to see sensor noise, I just want to know what boost is. A mechanical gauge probably only gives 2-3 samples/second and is regarded as a great way to monitor boost.
Mike |
01-25-2010, 09:40 AM | #11 |
241
Rep 4,936
ok....So Mike what would you consider setting the jb3 to boost and taper off at on a full bolt on car>
[SIGPIC][/SIGPIC]
01-25-2010, 10:09 AM | #13 |
4918
Rep 115,980
01-25-2010, 10:44 AM | #14 |
241
Rep 4,936
thats what i was thinking, the way i look at it is why mess with something thats not broken i mean dont get me wrong data logging is awesome for certain people but i know for a fact iam not going to mess with the P>S>I on my car that just seems to much for me.
[SIGPIC][/SIGPIC]
