PROcede v4 Technical: Stg3+ and Stg4+ w/methanol datalogs
01-23-2010, 09:30 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
1-22 maps tested on a 6AT Stg 3 car running Vishnu PnP Methanol System
Things to notice: Ignition correction curves The meth map (Stg 4+ with Ign Correction at 0%) runs considerably more timing than the pump gas map. This extra timing is PROcede-induced and not caused by knock feedback as it would be in a reflash or in a piggyback that does not actively control ignition timing. Boost pressures Peak boost on the pump gas map is limited to 15psi. Peak boost on the methanol map is set to 16.8psi. Eventually, these peak values will be adjustable though the User Adjustable menu. It makes no sense for a tune NOT to adjust boost when toggling between methanol and non-methanol maps. Running the same boost pressure is a tuning compromise, plain and simple. Target Boost vs. Actual Boost (aka "Pressure in front of Throttle Valve in BavTech speak) This is Debug Word 4 and Debug Word 5 (both plotted in the 5th graph) Look how closely they match each other. The closer they are too each other, the more responsive the engine will be. The error (difference between Actual and Target) is within a small fraction of a PSI at all times (post spool-up). And you will see this kind of error regardless of what your modifications/conditions are. V4 is that adaptable. You will not find any other reflash or non-CANbus integrated piggyback to come close to this. Stg 3+ on 91oct (methanol injection disabled) and Ignition Correction set at 100%: Stg 4+ on 91oct plus methanol (enabled) and Ignition Correction set to 0%: Cheers, shiv Last edited by OpenFlash; 01-23-2010 at 09:56 PM.. |
01-23-2010, 09:35 PM | #3 |
133
Rep 4,764
You have been busy today. Nice work.
01-23-2010, 09:40 PM | #4 |
1737
Rep 17,960
Drives: A Lot
Thanks.. you'll be happy to know that we are working on the progressive mapping for methanol right now. So instead of switching between two distinct maps when the methanol flow trigger goes ON/OFF, the PROcede is going to read actual methanol flow (in ml/min) and gradually "blend" one map into the other as a function of flow. So you wont see any "step" change in boost, timing or fuel. Everything will be invisible, failure-proof and as smooth as one could want.
Cheers, shiv |
01-23-2010, 09:46 PM | #5 | |
441
Rep 18,331
I am running stage 3 so if I use 3+ for meth map, all I would need to do is turn ign cor to 0%? Correct |
01-23-2010, 09:47 PM | #6 | |
37
Rep 738
http://videos.streetfire.net/video/s...rays_37268.htm
gotta do what i gotta do to get them donuts 04 spec-v: rip dec07 |
01-23-2010, 10:04 PM | #7 |
133
Rep 4,764
01-23-2010, 10:09 PM | #8 | |
58
Rep 1,230
01-23-2010, 10:36 PM | #9 |
129
Rep 1,629
Wow. Amazing how much meth allows you to tighten the timing up. Very promising. Nice work.
Edit: btw, Shiv, are you running straight meth or 50/50? Also, have you taken a look at the thread on the boards re: pre-compressor meth injection? Any thoughts? Thanks.
Cars>Women
01-24-2010, 12:02 AM | #10 |
363
Rep 5,873
Drives: m
Just to clarify, if I get a basic meth kit and have a procede, do I need a controller to adjust the meth controls? The procede will change the map if the meth stops, negating the need for a secondary gauge to prevent any engine damage?
01-24-2010, 09:07 AM | #12 | |
656
Rep 10,587
yes I do believe that is correct, his meth kit comes iwth everything you'll need to integrate w/ the procede.
01-24-2010, 09:12 AM | #13 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
01-24-2010, 09:24 AM | #14 |
441
Rep 18,331
lol...+1 on the Labonte electronics! I personally witness that the electronics need to be compatible with the tuner software!!
01-24-2010, 11:49 AM | #15 | |
24
Rep 441
with V4, how exactly should we setup the values in user adjustable menu so we can switch bewteen pump gas map and meth map on the fly? does V4 switches back to pump gas map automatically when it detects no meth flow? |
