PROcede v4 Technical: 6AT shift logic
01-23-2010, 09:05 PM | #1 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Hi guys,
I've gotten a few emails from 6AT v4 customers telling me that their peak hold boot gauge reading is ~2psi higher than expected. For example, those running Stg1 routinely see 13-14psi of boost (depending on barometric pressure) on their boost gauge, hit the peak hold recall feature and see 15-16psi. This is normal. This is why: Unlike previous version of the PROcede, v4 handles the 6AT shifting situation differently. Instead of making the 6AT behave like a 6MT and close the throttle between gears, we are keeping the throttle open. How much open depends on your applied throttle (right foot). Closing the throttle between 6AT upshifts isn't ideal for a number of reasons: 1) It causes a 20+psi pressure spike in the intercooler tube that, coupled with manifold vacuum, discharges the bypass valves. So you lose all or most of that boost pressure you had. This means the turbos have to spool up again. It also mean that you subject your turbos to a 20psi pressure spike which thrust bearing can do without if given the choice. 2) It creates a sudden load swing (full load/low load/full load) situation that opens the engine up to transient mis-calibration which can induce knock, boost oscillation, and general drivability imperfections. 3) It's just plain slower. So instead, of doing it the old way, our mapping keeps the throttle open during the shifts. This creates a ~2psi pressure spike during the shift process for a fraction of a second. Often, you wont even perceive this on a digital boost gauge. But your boost gauge will record it and show it to you when you ask for the peak hold value. So why does it boost spike? Simple.. When a turbo is providing Xpsi of boost at say 5000rpm and the revs suddenly drop to 4000rpm after an upshift, the turbo is still spinning at the roughly the same speed it was at 5000rpm. Because it has inertia, it takes a split second for for the turbo wheel to slow down and provide the desired boost pressure. During this brief period of time, there is a ~2psi overboost. So if your maps routinely runs 13psi at full throttle, you will see a ~15psi peak value. Similarly, if your map runs 15psi at full throttle, you will see a ~17psi peak value. Is this more stressful on the turbos? Absolutely not. The turbo doesn't care because it was already spinning at the same speed a moment before when it was in a lower gear (at a higher engine RPM). In fact, the turbo would have been a lot less happy if the throttle had closed, been hit by a pressure surge and then had to spool up again between shifts. So no, the turbo is perfectly fine with this. Is this more stressful to the engine? In this case, no it's not. Because in this situation, this brief period of overboost, total ignition advance drops from several degrees of 0 degrees. Actually, it goes negative advance but the PROcede logger isn't configured to display negative advance . While only 2-3 degrees of transient ignition retard would have been sufficient to ward off knock during this boost spike, the extra timing retard has another function: to drastically reduce engine torque in order to make life easier on the torque converter. The advantage using timing reduction instead of boost reduction to reduce torque is because it can be applied instantly. There is no "tapering" off of engine torque as there would be if boost was cut. Instead, the ignition retard cuts power instantly. And just as importantly, it adds power back instantly. Something that boost adjustments cannot do. All these systems work together to make the shifting performance on a PROcede v4 powered 6AT car unbelievably positive and consistent while providing minimal stress to the transmission. Here's a datalog (at the standard 30-35hz) of a manually induced short-shift at WOT illustrating all these systems in action: Enjoy! Cheers, shiv |
01-23-2010, 09:53 PM | #3 |
184
Rep 2,841
Interesting sequence of events.....
Makes intuitive sense that one can change timing a lot faster than one can change spinning turbines. And yes....eliminating throttle closure between shifts should reduce the backpressure heading back towards the turbos....which can only be a good thing for them. |
01-23-2010, 11:08 PM | #4 |
259
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
Can't wait to test the V4 on my DCT...
01-23-2010, 11:30 PM | #6 |
1737
Rep 17,960
Drives: A Lot
01-23-2010, 11:37 PM | #7 | |
324
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
01-23-2010, 11:38 PM | #8 |
363
Rep 5,873
Drives: m
The shift logic stuff is part of v4? And what exactly does it do, tune the trans for faster shifts?
01-24-2010, 12:38 AM | #9 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
01-24-2010, 12:44 AM | #10 |
Hates Speed Limits
111
Rep 2,589
01-24-2010, 12:48 AM | #11 |
1737
Rep 17,960
Drives: A Lot
01-24-2010, 01:00 AM | #12 |
259
Rep 1,165
01-24-2010, 08:37 AM | #13 |
324
Rep 2,663
I'm just like Sarah Palin, I can see NJ from here just like she can see Russia from Alaska and see what's going on.
01-24-2010, 09:08 AM | #15 |
184
Rep 2,841
01-24-2010, 09:10 AM | #16 |
1737
Rep 17,960
Drives: A Lot
With the exception of the boost spike, you'll see the same events since much of it is DME induced (mid-shift ignition retard for instance). With the 6mt, as you've seen, a quick shift will keep boot at 10psi between shifts without any "lagfix" or "bogfix" bandaids. The reason the throttle doesn't hang up between shifts is because actual and target boost stay hand-in-hand regardless of the situation.
Shiv Last edited by OpenFlash; 01-24-2010 at 09:31 AM.. |
01-24-2010, 09:28 AM | #17 |
Moderator
618
Rep 10,855
As I understood it, these are some of the issues that were involved with different OEM programming for the manual transmission from the start, and then the BMW perf version. At least with the Steptronic you have a more predictable and hence controllable situation. With the manual the vagaries of different shifting parameters required more conservative OEM boost control.
V4 appears to provide a much more 'direct' power flow. Consideration of issues involved during shifts is important, and yet another significant advance in tuning.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
01-24-2010, 09:42 AM | #18 |
40
Rep 950
Shiv, are you telling me that you designed V4 automatics to hold full boost through the shift, reducing torque quickly via timing reduction?
Is this for reducing wear or for more/smoother acceleration? That seems like a pretty big accomplishment to me, if so, nice job |
01-24-2010, 09:46 AM | #19 | |
1737
Rep 17,960
Drives: A Lot
Make sense? Shiv |
01-24-2010, 09:53 AM | #20 | |
40
Rep 950
01-24-2010, 10:13 AM | #21 |
153
Rep 5,780
01-24-2010, 10:26 AM | #22 |
Moderator
270
Rep 4,481
