Boosting 16 PSI
01-23-2010, 08:56 PM | #1 | |
Moderator
270
Rep 4,481
Boosting 16 PSI
I currently make my own experience with quite some datalogging involved, everything looks fine ( using 95 octane AKI / 100 octane RON gas ) and the car runs great . I'm curious what you think about boosting 16 PSI in terms of reliability. Please keep in mind that our turbos are used in the Alpina B3 TT with 16 PSI max by their ´stock´ tune.
I quote scalbert from another thread: Quote:
01-24-2010, 02:38 AM | #3 |
161
Rep 7,377
i have been boosting at those levels for quite sometime without any issues. Frequent oil changes and spark plugs with the right mods should help the car cope with that.
Get an FMIC though, really important at those boost levels .
01-24-2010, 08:12 AM | #5 |
441
Rep 18,331
+1 proper maintenance and supporting mods will help running those psi...
01-24-2010, 08:32 AM | #6 |
Moderator
270
Rep 4,481
I use an FMIC, Forge DV's, VKM oilcooler, High-Flow metallic primary catalysts and a drop-in filter.
Came back from datalogging right now, did a couple of WOT pulls 3rd and 4th gear. Everything works great and the car is really fast. |
01-24-2010, 08:44 AM | #8 |
Moderator
270
Rep 4,481
Isn't it normal that the BT-logs show some knock counts very rare ? Mine do, mostly in low rpm range and on 25% - 50% trottle position. I thought this is part of the continuous ECU adaption. Timing is not pulled on these occations. ECU is error-free.
01-24-2010, 08:45 AM | #9 |
153
Rep 5,780
01-24-2010, 08:52 AM | #10 |
Moderator
270
Rep 4,481
I edited my posting. Timing is not pulled, no audible knock signs, no misfiring codes, no super-knock codes. engine feels strong and healthy. All I'd have to do is to don't exceed 16 PSI in any environment, IMO.
01-24-2010, 01:06 PM | #11 |
The Stig
31
Rep 1,232
My question is, turbos aside, what can the engine reliably handle? It seems the boost keeps getting higher and higher, I'm just curious whether anyone has any speculation or comments on what the engine itself is strong enough to handle?
01-24-2010, 01:32 PM | #13 |
161
Rep 7,377
Till we dont start seeing upgraded turbos running we wont know what the limit is but i would guess 500 whp.
01-24-2010, 01:34 PM | #14 | |
Moderator
270
Rep 4,481
From a different thread:
BTW - can we log AFR using the BT tool ? |
01-24-2010, 02:36 PM | #15 | |
161
Rep 7,377
01-24-2010, 10:22 PM | #16 |
812
Rep 3,974
Before switching over to 2.0, I did a run on JB3 map#7 1.4 so you can see the boost gauge in the lower right hand corner. For the most part, boost is 14psi or lower.
Still got 0-60 in 3.8 sec Soft 2nd gear launch. 1/4 mile: 12.0 sec over 120mph trap. It really doesn't take crazy boost levels to get some pretty good power. This was Map 7 on 91octane/meth.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
01-24-2010, 11:48 PM | #17 | |
101
Rep 1,668
how long do you change your oil? intervals of 7500?
01-25-2010, 02:21 AM | #19 |
812
Rep 3,974
I do mine about every 10,000 miles, which happens to be how often the car oil service reminder comes on.
