Forge DV's
01-23-2010, 02:53 AM | #2 |
www.facebook.com/Synergy69
24
Rep 505
lol you are still up! going to the track has got me all wired too. Trying to figure out what I want to mod next. lol
01-23-2010, 07:41 AM | #3 |
133
Rep 4,764
Running the stage 3 procede maps with stock diverter valves. When I put in the meth kit and boost goes up another 1 -1.5 PSI I will probably do diverter valves at that time.
01-23-2010, 01:04 PM | #4 |
24
Rep 505
is it better to get a charge pipe with a BOV vs getting forged DVs?
http://www.e90post.com/forums/showthread.php?t=326717 |
02-04-2010, 02:43 AM | #6 |
63
Rep 989
I have just ordered the forge dv's from uk im stage 3...
EURO E92 M3 2008 6MT Interlagos ///Fully Loaded! Evolve-R ECU Flash/Gintani Sport Exhaust/MS Stg2 Intake Kit/H&R Springs/MS 18/15 mm spacers/Bmw Perf. Grills/Gloss Black side gills/LCI Tails/LUX V3's/RD license plate leds |
02-04-2010, 08:24 AM | #7 |
812
Rep 3,974
I run stock DVs. I tried forged DVs for a week. Didn't notice any improvement in qtr mile times so I put the stock ones back on.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
02-04-2010, 10:13 AM | #8 |
184
Rep 2,841
I've gone back and forth between stock and Forge several times and I always like the feel of the forge.....
Same boost levels as stock valves so no improvement there, but forge always feels crisper at part throttle angles whereas the stock ones tend to bleed boost a bit sooner. I can definitely hear more part-throttle hissing with the stock ones which means they are cracking open a bit sooner. Hotrod is right.....at full throttle, no difference.....but at part throttle, I think the forge help to keep the intake system pressurized a bit better.....so they feel crisper/tighter. |
02-04-2010, 03:57 PM | #9 | ||
654
Rep 10,587
Hotrod just because you didnt see a 1/4 mile improvement doesnt mean they are not beneficial. Cars are used for more than 1/4 mile blasts ya know . Plus, my stock DV's leaked, the forge units held. Part throttle behavior was better at higher boost levels. I recommend them.
02-04-2010, 05:47 PM | #10 | |
177
Rep 6,631
E90 LCI N54 6AT
02-04-2010, 05:58 PM | #11 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Just make sure to keep your DVs lubricated well. The Forges on my car eventually started to stick open and cause all sorts of underboost conditions. I ended up greasing the pistons and that solved the problem.
02-04-2010, 06:10 PM | #12 |
Team Zissou
3065
Rep 10,197
02-05-2010, 12:13 AM | #15 |
812
Rep 3,974
Kind of funny, but I just had my stock DVs off this last weekend, and in a bucket of water with compressed air applied on one end. Couldnt really tell much because at the break away pressure, air goes right through them. My aircompressor regulator broke, so I couldn't adjust the pressure for proper testing. But at least with medium pressure, no bubbles appeared.
Does anyone know what are some good testing procedures, and psi numbers to refer to when checking the DVs?
02-05-2010, 05:54 AM | #16 |
Keepin' America Free
72
Rep 1,260
Hows the sound vs. stock? I know its not a major issue and most don't care, but I'm just curious.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough" -Mario Andretti |
02-05-2010, 06:56 AM | #17 | |
184
Rep 2,841
I know he did a leak test with the stock ones in a bucket of water.....his post is there in the archives somewhere - I have seen it before. IIRC the stock ones held up to about 30 psi of pressure from a compressor. But a more revealing test would be playing with the cracking pressure when there is a differential on the two sides of the valve.....because this would emulate part throttle conditions. I think the stock ones crack open at around a 4 psi pressure differential.....the forge probably crack open a bit higher than that which would explain why they hiss less during part throttle. Kind of makes sense when you consider the yellow springs are stiffer than stock. |
02-05-2010, 07:00 AM | #18 | |
184
Rep 2,841
Just a little crisper with the hissing at part throttle......and sound deeper when they dump a lot of boost as you lift off from deep throttle angles. |
02-05-2010, 07:39 AM | #19 |
60
Rep 2,314
