Procede V4 Stage 4 going to run the 1/4 mile tonight!
01-21-2010, 04:54 PM | #1 |
104
Rep 919
I loaded up the most recent maps today and I will be going to the 1/4 mile track tonight for some test runs.. This will be my first time taking this car to the track but I have experience in other cars (330Ci, G35). Do you think it is worth adding a few gallons of 100 octane that they sell at the track? It's $10 a gallon! Any tips on launching or shift points would be greatly appreciated!
2007 E92 335i 6MT Procede V4 Stage 4 map AR Design Catless Downpipes Vishnu DCI Secondary cat-delete UUC RSC335 axle-back exhaust BMW Performance SSK UUC RK Shift Knob Active Autowerkes Intercooler 265/30/19 General Exclaim UHP's rear tires with about 10% tread left, so if I end up with 2.5 60ft times than that is probably the reason, lol. |
01-21-2010, 04:57 PM | #2 | |
95
Rep 1,659
01-21-2010, 04:59 PM | #3 |
133
Rep 4,764
See if you can log a couple of times down the track. Maybe you could do 93 octane for a couple then mix in some 100 and try it again. Bring ignition correction down when you mix in the 100 octane.
01-21-2010, 05:02 PM | #7 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
On pump gas, you aren't going to break any records. So if you run race gas, try to run close to 100% race gas. So get your tank low by the time you fill up. And then put in as much 100oct as you can afford This will allow you to drop your Ignition Correction from the default of 100% to 0% and pick up another 30whp or so. That's pretty much it. Although I think you'll do better when the 6MT maps come out since the current 6AT maps start rolling off boost up top. I'm going to the drag strip this weekend (weather permitting) to make 6MT maps. If if your prior drag racing experience was with a 330 and g35, you're in for a lot of work tonight. Practice practice. Even datalog the runs if you can so you can go back and look at your performance. It's your first time drag racing this car. And it's a 6MT. You have a challenge ahead of you. Shiv |
01-21-2010, 05:03 PM | #9 |
133
Rep 4,764
Good luck. Get Ignition correction suggestions from Shiv if you can. With 93 octane on the 10-9 maps I could do around 50-60% IC. With a 50/50 93/100 octane mix maybe 20-30% IC.
Get some more input. ** Edit. I see Shiv chimed in. awesome. I hope you get at least a couple times down the track. Have fun! |
01-21-2010, 05:15 PM | #11 |
7
Rep 106
01-21-2010, 05:33 PM | #12 |
Rep 27
Are you going to sunshine speedway? curious to hear the results!
Hope the weather hold up....Maybe the clouds will keep the crowds down. That 25 mph tail wind you will have won't hurt the times either.. |
01-21-2010, 05:40 PM | #13 |
35
Rep 1,084
GL man, you've got 2X the tq to deal with.
_________________________________________________
09 E90 LCI Msport, European Delivery |
01-21-2010, 06:36 PM | #14 |
104
Rep 919
I have a set of Bridgestone RE050A Pole Positions sitting in my garage that I will put on once these tires are gone.. I bought the VMR wheels with the tires already installed.
01-21-2010, 06:45 PM | #17 |
1737
Rep 17,960
Drives: A Lot
My suggestion to Malaka1 was to just forget about launching hard and just take off as he would on the street. This means running with the DTC ON and shifting as fast and cleanly as he can.
With the DTC on and running Generals, the car will be cutting power in 1st, 2nd and 3rd gear. But at least it will stay pointed ahead and get him down the strip with minimal drama. |
01-21-2010, 09:09 PM | #18 | |
37
Rep 738
teri
http://videos.streetfire.net/video/s...rays_37268.htm
gotta do what i gotta do to get them donuts 04 spec-v: rip dec07 |
01-21-2010, 09:58 PM | #19 |
654
Rep 10,587
goodluck, dont even think about WOT in 1st and probably 2nd gear.
oh and Generals are THAT bad at the strip, Clem cut a 1.8x 60ft in his 335 w generals in a 6mt. you just have to get it right!
01-21-2010, 10:05 PM | #20 |
40
Rep 950
Hope he does well, im looking forward to seeing the results..
while he is out, anyone wanna start guessing? if he can't hook, im betting 12.8@117 if he does hook, 12.3@ 115 |
01-21-2010, 10:23 PM | #22 |
27
Rep 569
I can maybe see a 12.8-13.0 on those tires with a 6mt. Trap should be solid with cold weather. My car ran a best of 12.8 at 118 on street tires and was spinning all 1-4. I will never run on street tires again. My guess would be 12.9x at 117.
N55
