Some JB3 2.0 beta logs!
01-17-2010, 10:28 AM | #6 |
161
Rep 7,377
those logs looks great! Awesome job BMS , all JB3 users will enjoy this!
01-17-2010, 10:49 AM | #7 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
01-17-2010, 10:50 AM | #8 |
4918
Rep 115,980
Analyzing takes some guidance, but here are the basic elements.
"Pre-Boost" is the pressure before the throttle body. Generally close to actual boost, except when you loose traction or have throttle closure, in which case it spikes up. The scale is 0-20psi along the left. "RPM" is enigne speed. The scale is 0-7000rpm along the right. "TPS" is throttle position. The scale is 0-10 = 0%-100%along the left. "IAT" is air intake temperature. The scale is 0-20 = 0-200 degrees F along the left. The other fields, "PWM", "ECU-PSI", and "PID-PSI" are internal fields for the boost control system. Mike |
01-17-2010, 11:43 AM | #10 |
4918
Rep 115,980
