Saikou Michi Catch Can Update
01-16-2010, 04:52 PM | #1 |
My X5d tows my spec miata to the track.
74
Rep 1,254
So I had ordered a SM can a couple of days before the review posted here:http://www.e90post.com/forums/showth...t=saikou+michi
Based on the thread, I changed my order from a standard stage 1 OCC to the n54 specific can. I installed it when it arrived but was not thrilled with the hose diameter and fitment issues caused by the size of the can and the sharp bends needed to make the hose work. I emailed my frustration to Saikou Michi and they were more than accommodating. They wanted to help and had developed that can based on the instructions that the OP in that thread gave them. It turns out the guy that wrote the review sold his setup a couple of days later and I believe is selling his car. I emailed them a few suggestions on what I would do differently and they offered to send me a replacement based on that spec. It only took a week or so but with the holidays, travel, and me relocating I just got it installed today. I'm thrilled with the result. I suggested moving to 1/2" hose as it would survive the bends without crimping. I also suggested that the stage 1 OCC diameter was more appropriate given the tight space. It fits perfectly. Here are few pix of the install. The can: Stage 1 OCC with 1/2" barbs and a 45 deg offset I bought the riss racing hose kit originally and used the intake line setup. IIRC its a 1" to 1/2" reducer using 1" hose to connect the 1/2" line to the stock intake port. The PCV valve is connected to the 1/2" hose using a very small piece of 3/4" hose to a 1/2" barb elbow with 1/2" pipe thread. The shorter the 3/4" hose the better to avoid hitting the firewall with the elbow or bending the 1/2" hose. Here are some pix showing the lines assembled and the tightness of the space. The finished product: The can fits nicely in the space, doesn't rub, and is easily removed with the 10mm nut on the fender well. The hose bends are nice and smooth with no crimps. I'm very happy with the new setup and have nothing but praise for Saikou Michi. Their cans are top notch and not too expensive. Their customer service is second to none. |
01-16-2010, 06:24 PM | #2 |
74
Rep 1,254
01-16-2010, 06:48 PM | #3 |
866
Rep 5,450
Very nice and looks pretty much factory!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
01-16-2010, 06:57 PM | #4 |
198
Rep 4,647
how much did it cost you? link to order?
also what exactly is the name of that 90 degree piece? brand name? where at? home depot?
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
01-16-2010, 09:01 PM | #5 |
74
Rep 1,254
The replacement can was free. The original was around $120 or so. I think the one I requested would come in around $90 as it's a stage 1. The elbow piece was purchased at a local hardware store. It's actually a 1/2" hose barb elbow to 1/2" threaded pipe. The hose clamps on the threads. It works. it's not perfect but it works without issues.
My advice is to get a piece of 1" hose and and a piece of 3/4" hose and find reducers to go from those to 1/2". The 3/4" to 1/2" should be an elbow while the 1" to 1/2" is straight. Sit in the store and test fit the hose and fittings until it's right. It won't take 5 minutes. EDIT: the stage 1 OCC is $75 + shipping. |
01-16-2010, 09:19 PM | #6 |
102
Rep 3,460
1/2 inch hose? Thats horrible. I have the standard can with stock pvc hose sizes on both ends (no elbows or anything) and never had any crimpling or fitment issues. I think you just bought crap hose personally. This is a smaller 135i btw.
01-16-2010, 09:28 PM | #7 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
I don't like the placement in the engine bay. Its too close to the exhaust system and therefore heat. If I was to place the catch can, it would be in a cooler place so that the hot oil vapor will have a better chance of condensation on the cooler walls of the oil catch can. I think this is essential to making sure that the oil fumes are actually trapped.
Also, think what will happen to the oil that gets captured in the catch can after long exposure to heat. It will cake up and it will form sludge. This will quickly clog the little filter element and cause the fumes to bypass the filtration thus rendering the catch can useless. Just my $0.02 |
01-16-2010, 09:43 PM | #8 |
74
Rep 1,254
pix? What hose did you buy? I boughtstandard automotive heater hose.
01-16-2010, 09:47 PM | #9 | |
74
Rep 1,254
01-16-2010, 10:34 PM | #10 | |
24
Rep 746
i would agree with this preliminarily... i dont know the compound used to create the catch can, however i dare anyone to stick there hand down the exhust side after an hour of driving and tell me it is nice and cool... NOT SO MUCH... i personally feel more comforatable with the placement of the AR catchcan (IMO)... im sure there will be experts who will chime in...
2009 BMW 335i Sedan / Auto / Paddles / Sport / BMW Assist / Heated seats / JB Matte Black Grill / Tischer First Aid Kit w\Triangle / Tischer Hood Pad / "Custom" rear fog switch <---- SOLD!!!!
01-17-2010, 12:50 AM | #11 | ||
198
Rep 4,647
edit: nvm. i did the search and found the website. but besides the size of nipple and size of the can is there any difference in filteration? it looks same... p.s. one more q. i have RR OCC with N54kit is the size on those hose different from N54kit that i have? hose works flawlessly without leaking so i don't want to change it. i'm looking to just replace OCC itself...
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers Last edited by hun77777; 01-17-2010 at 01:21 AM.. |
01-17-2010, 08:15 AM | #12 | |
74
Rep 1,254
01-17-2010, 09:09 AM | #13 |
102
Rep 3,460
You just routed it wrong. The hose coming out of the drivers side part of the engine goes out the passenger side of the engine and up to the can. (which you did) The hose from the passenger side of the engine goes towards the driverside, ontop of the other hose (theres a perfect slot in the engine cover for this. And up btwn the engine cover and cowl to the catch can. Simple really. I used good year radiator hose.
01-17-2010, 11:51 AM | #14 |
74
Rep 1,254
Maybe. I didn't see any other way to route the hose without crimping it.
I don't see how you can orient it any differently. The fuel line prevents rotation of the pcv. It basically has to point toward the driver's side. Last edited by boom; 01-17-2010 at 12:07 PM.. |
