Forge DVs...HELP!!!
01-16-2010, 02:17 AM | #1 |
28
Rep 153
Forge DVs...HELP!!!
So i had some time on a Friday night, for a change. Decided to install my Forge DVs that i got last week. Install wasnt all that bad...getting the rear gray ring off was the worst part. After install, i took the car for spin. First impression...no difference in sound at all (keep in mind i have BMS DCI). About 2 miles later...it seemed like the engine was starting to shut down. Wasnt responding to my pedal when i pushed down on it. And next thing you know...GONG...CHECK ENGINE LIGHT! Something along the lines of "Vehicle not receiving enough output. You may continue to drive vehicle, but please visit BMW dealership." GREAT! So i drove home slowly and put the stocks back on. Drove it around with the stock DVs, no check engine light and ran just fine. I'm guessing there was some type of boost leak, but i made sure i tightened everything up securely and and followed the exact directions. What do you guys think?
Khaled
2010 BMW 335i Coupe 6MT | Navi, Sports, Cold Weather, Hifi Sound, Premium | BMS DCI | Hood Scoops | JB4
My House Mixes: http://soundcloud.com/khalmusic/breathe-november-2012 |
01-16-2010, 03:05 AM | #2 |
84
Rep 1,575
Most possibly a boost leak ....make sure you have sealed the DVs tight before placing them onto the chargepipe's slot.
You should also check that the pistons into the DVs can move freely up-and-down.
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
01-16-2010, 03:06 AM | #3 |
109
Rep 3,334
Did you make sure you turn the gray clip after you installed the dvs to secure it?
Mods list got too long, lets just say more than enough.
01-16-2010, 03:18 AM | #4 |
84
Rep 1,575
+1 there are many people that messes up this part of installation...
01-16-2010, 08:46 AM | #5 | |
28
Rep 153
Also, Is there supposed to be no change in sound?
01-16-2010, 09:42 AM | #6 |
Custom Powder Coater
147
Rep 2,784
I've read they already come with springs installed I think? You didn't install other springs without taking out springs first did u?
Also are the "Forge" logos on each DV facing eachother?
01-16-2010, 10:02 AM | #7 |
333
Rep 4,632
Try re-installing them keeping in mind some of the helpful hints here, and post picstures of the finished product so we can look if you have done it correctly visually.
01-16-2010, 11:27 AM | #8 |
24
Rep 746
i had the EXACT same problem last night... so i am rolling with stocks...
i dont know what it is... going to do some more reading on the forge install... something wasnt working... we checked the silicone hoses, no leaks, DV were facing each other, and also they were sealed... (first time not... but we fixed that and pistons move freely... we checked with a pen and held the niple closed and saw it release afterwards..) i bought them brand new from rockstarrr
2009 BMW 335i Sedan / Auto / Paddles / Sport / BMW Assist / Heated seats / JB Matte Black Grill / Tischer First Aid Kit w\Triangle / Tischer Hood Pad / "Custom" rear fog switch <---- SOLD!!!!
01-16-2010, 11:43 AM | #9 |
Rep 78
Did you guys install any springs prior to installing them and if so did you pull out the springs that were pre installed with the Forge DVs. If not, then you installed the springs the wrong way ( I nearly installed 2 sets of springs).
01-16-2010, 11:46 AM | #10 |
38
Rep 944
happend to me on my first installation are you sure you installed them right position?
http://www.youtube.com/user/Ferre86
| e93 M-DCT ESS VT2-625 | Akra Slip-on | Challenge Race Catless x-pipe | Challenge front lip | Challenge Diffuser | Carbon front grilles | defi gauges control unit | Macht Schnell gauge panel | E93 M3 trunk Spoiler | IND Carbon Fiber Side Markers | |
01-17-2010, 09:35 PM | #11 |
28
Rep 153
Yes definitely the right position. Everything was definitely tightened and secure. It's kind of making me not want to re-install them. And is there not supposed to be a difference in sound? That as definitely a huge turnoff, considering it sounded the same as stock.
01-17-2010, 10:01 PM | #12 | |
208
Rep 9,339
01-18-2010, 06:35 AM | #13 |
79
Rep 1,617
Quick question: How freely should the pistons move on the Forge DVs?
I have a Stett charge pipe with the "generic" (non N54-specific) type DVs and will have them installed in a couple of months. However I want to make sure there won't run be problems. So I checked by unscrewing the top part, and then I can move the pistons using quite a bit of force. But they're not moving freely at all by themselves. Does that sound normal?
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
01-18-2010, 08:08 AM | #14 |
229
Rep 3,550
make sure that you have ONE set of springs inside the diverter valves.. they already come with a set installed behind the pistons... make sure you didn't add another set on top of them (which is what i did when i first installed them )...
Current:
'13 F10 535i xDrive - lightly modded for now Previous: '12 e92 M3 Melbourne Red/Bamboo - ADV.1 ADV10, Volk TE37SL, OSS, Innotech F1, Arkym, iND '09 e92 335i Alpine White/Saddle Brown - fully modded |
01-18-2010, 08:31 AM | #15 |
79
Rep 1,617
Hehe, yes the green springs are the only ones in there. With the top cap tightened, I can't move the piston a single bit. Only when I remove the cap, I can slowly move the piston. Normal?
01-18-2010, 10:53 AM | #16 |
28
Rep 153
Mine came with 2 sets of springs...so maybe there werent any inside of the DVs? Hmmm....i'm not sure how to install the springs. I've never dealt with DVs before to be honest. Can someone help by posting pics or giving me directions?
01-18-2010, 11:05 AM | #17 |
62
Rep 1,736
Drives: '09 E92 335i
Make sure the tops are facing each other, not facing upward. The end going into the charge pipe has a beveled edge/lip.
| 6MT | ZSP | ZPP | |
01-18-2010, 02:43 PM | #18 |
28
Rep 153
Yes that's exactly how i had them installed. I have a feeling it has to do with the springs. How do i go about checking if they're installed correctly?
01-19-2010, 01:39 PM | #19 |
62
Rep 1,736
Unscrew the caps and see if they're in there.
| 6MT | ZSP | ZPP | |
02-02-2010, 12:41 PM | #20 | |
Rep 41
Email me at service@forgemotorsport.com and we will get you sorted. |
02-02-2010, 12:46 PM | #21 |
Rep 41
If he has the new style valves there isn't a cap on the valve rather the base is removable. You can see what I mean here:
http://www.forgemotorsport.com/media/FMDVMAZ3S.pdf This valve is slightly different, the flange is installed where the port that slots into the boost hose on your valves is located. Internals are the same. |
