BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Pure Meth
      01-12-2010, 05:35 PM   #1
Htown09
Htown09's Avatar
44
Drives: E92
Pure Meth
I talked to a guy at a raceshop today about M3, and M5. (VP racing Meth)
It is about 6.75 a gal. for M3 and 7 for M5.
Has anyone tested running pure Meth + 93octane. Would it be beneficial to run pure Meth or a higher mixture of Meth than a 50/50. Maybe you could a higher map on pure meth than a mixture.
      01-12-2010, 05:50 PM   #2
Terrance28
Terrance28's Avatar
Drives: Crimson Red E92
I wouldn't run pure meth its very flammable. Besides I don't think you will yield any more gains running 100% vs 60/40 or so. I also get meth here at $4 a gallon.
Mods list got too long, lets just say more than enough.
      01-12-2010, 06:31 PM   #3
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
Be careful M3 and M5 have additives for cars that run meth as the main fuel, not an injection kit like we are using. Stick with M1 which has no additives (So you don't destroy your injection pump early).
      01-12-2010, 06:38 PM   #4
Htown09
Htown09's Avatar
44
Drives: E92
I was told that you need lube that M1 does not have. And M3 and M5 already have it added.
      01-12-2010, 06:52 PM   #5
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
No lube is needed. No additives are needed, just methyl alcohol and distilled water.
      01-12-2010, 06:54 PM   #6
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
Take a look at this thread: http://forums.evolutionm.net/water-a...-methanol.html
      01-12-2010, 07:25 PM   #7
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
Found these statements over on srt-4 forums as well:
Aquamist has found that the additive in VP M5 will cause premature seal failures in the Shurflo pumps as well as our flow sensors.
Given that, M5 WILL make more power over M1
For warranty purposes and in regards to 100% methanol injection, Aquamist users are advised to try and use the purest methanol available and methanol that does not have additives. VP-M1 meets these requirements.
To be clear, using the methanol's available from VP as an example, everyone needs to understand that there's additives in all of them with the exception of M1.
It's the additives that will attack the seals of the Surflo pumps, and over time the pumps will leak as a result. The situation of pump failures due to using methanol versus a mix is not unique to one kit maker.
Also, when buying methanol buy the factory sealed (unopened) 5 gal pals of VP M1 or methanol equivalent to VP M1. VP M1 is about the purest methanol (no additives) that can be easily obtained by most people.
      01-12-2010, 08:18 PM   #8
qwks6
Drives: '13 650i Gran Coupe
us in the turbo buick community run pure meth with great success. We say why run 50/50 except for a pump and nozzle that aren't set up for pure meth. But tuning this engine is very new, the turbo buicks have a 20 year advantage in testing and experimenting. Water doesn't add power. It helps suppress knock, but not better than meth. What you run really depends on your setup.
      01-12-2010, 08:33 PM   #9
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Scott, its the m5 only that causes trouble, m3 is only m1 with m2 lubrication added. The m2 lubrication does not damage seals, it protects seals. It also lubricates surfaces like valve guides which a direct injection engine that has no fuel flowing past the valves could most definitely benefit from.
      01-12-2010, 08:55 PM   #10
Htown09
Htown09's Avatar
44
Drives: E92
So M3 is good to use? But in coolingmist and snow kit's since we are using injection system and pump's, is running pure meth and pump gas recommended?
      01-12-2010, 10:08 PM   #11
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
If I were you, I would PM or email the manufacturer of the system you want to use, just to confirm their thoughts.
      01-12-2010, 10:09 PM   #12
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
Thanks for the info!
      01-12-2010, 10:17 PM   #13
Htown09
Htown09's Avatar
44
Drives: E92
If Coolingmist is listening, will we notice a difference in power by running pure M3 and 93 octane pump gas versus a mixture of meth/water and 93 pump gas? In other words, would we be able to run a higher race map with the pure m3/93 than we would utilizing the m3/water/93 mixture?
      01-12-2010, 10:17 PM   #14
coolingmist
31
Drives: 2009 135I 2006 Lotus Elise
its been our experience from our customers that M1 is the only one to use, no additives should be used. We have cases of M3 causing damage to seals, I am not familiar with the others. The pump does not need any lubrication. Any kind of hydro-carbon will kill the pump seals.
CM
      01-12-2010, 10:19 PM   #15
Htown09
Htown09's Avatar
44
Drives: E92
Ok so M1 is the one to purchase. Have you any info on running pure M1 vs. M1/water mix. Any testing done using pure M1 or M1/water mixture..
      01-12-2010, 10:21 PM   #16
coolingmist
31
I like running water with meth, however many like 100% meth. I hate to break the bad news, but for everyone that says pure meth is best, there are those that say 50/50 is better.
I like some water because its better for preventing detonation IMHO. Again, thats my opinion.
CM
      01-12-2010, 10:33 PM   #17
BoostedCosta
SUPERMAN
BoostedCosta's Avatar
121
Drives: AW e90 335i M-Sport
CM
i beg to differ
100 meth is bettter
MODS: JB3 18ohm | AR Design Catlles Downpipes | CDV Delete | Clutch Masters FX400 | ZEX Nitrous Kit | Devils Own Methonal Kit | VMR V701 (Matte Black) | H&r Race Springs| BMW Perf Grilles|
      01-12-2010, 10:36 PM   #18
Htown09
Htown09's Avatar
44
Drives: E92
[QUOTE=335i82108;6514959]i beg to differ
100 meth is bettter[/QUOTE
What is your reason? You can't just state something and leave it at that. Have you run higher race maps with pure meth and no detonation and made more power than 50/50?
      01-12-2010, 10:39 PM   #19
coolingmist
31
I like 100% water as well.
Like I said, asking this question is almost pointless. You will get a different response from everyone.
CM
      01-12-2010, 10:42 PM   #20
BoostedCosta
SUPERMAN
121
well i dont know about our cars but someone tested 100% meth and meth mix and it turned out that 100 was actually better
http://www.mazdaspeedforums.org/foru...-50-mix-42915/
      01-12-2010, 11:22 PM   #21
Htown09
Htown09's Avatar
44
Drives: E92
CM
Distilled water I assume?
      01-12-2010, 11:58 PM   #22
Htown09
Htown09's Avatar
44
Drives: E92
CM
So your kit can pump 100% Meth? I was looking at DO kit and it say's up to 50% Meth.
