The Mod-Bug Returns! I NEED YOUR HELP DECIDING!
01-05-2010, 11:18 PM | #1 |
56
Rep 783
close
2021 M3 6MT Brooklyn Grey/Silverstone
Previous: 2009 335i ZMP 2013 M3 6MT ZCP Space Grey/Fox Red Last edited by DOUT; 02-01-2010 at 05:28 PM.. |
01-05-2010, 11:37 PM | #2 |
241
Rep 4,936
i would suggest the stett/forge combo.....It will help you hold boost 10x better than stock and you also have the option for meth in the future.
[SIGPIC][/SIGPIC]
01-05-2010, 11:53 PM | #4 |
125
Rep 8,745
Suspension (there are other set-ups out there)
LSD M3 suspension parts Diverter valves In that order.
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
01-05-2010, 11:54 PM | #5 |
56
Rep 783
I know there are MANY other setups, but I am most lenient toward GC because it comes with camber plates and some other goodies which no other kit does.
I was only thinking of KWV2 so I could save $1000 and spend that on more mods!
Previous: 2009 335i ZMP 2013 M3 6MT ZCP Space Grey/Fox Red |
01-06-2010, 12:08 AM | #6 |
125
Rep 8,745
Camber plates aside (roughly $400), you are more lenient to GC because it comes out cheaper than other setups. Still, at $2,200 it is an expensive mod and personally I would ask myself what features it I am looking in the coilover before spending. These are konis and so are the TC Klines, the rear dampers (I think) need to be taken off to be adjusted for dampening. I have regular konis and H&R and it bugs me that I need to dismount the rears to adjust them. Anyhow, that is only an example.
01-06-2010, 12:12 AM | #8 |
164
Rep 2,409
01-06-2010, 01:11 AM | #10 |
198
Rep 4,647
i would say springs and forge dv for now.
LSD. later on when you save money for it. then change it to coilovers and extensive suspension upgrade...
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
01-06-2010, 06:40 AM | #15 |
63
Rep 989
my wavetrac was probably the best mod on the car so i would go with that....second choice would be coils/suspension....
EURO E92 M3 2008 6MT Interlagos ///Fully Loaded! Evolve-R ECU Flash/Gintani Sport Exhaust/MS Stg2 Intake Kit/H&R Springs/MS 18/15 mm spacers/Bmw Perf. Grills/Gloss Black side gills/LCI Tails/LUX V3's/RD license plate leds |
01-06-2010, 07:28 AM | #16 |
36
Rep 1,658
Suspension. (BMW Performance)
LSD. (Wavetrac) The above are around $1200 each plus the install. Forge are needed if your MT and boosting high constantly. Charge pipe is if your planning to run meth. Otherwise they both are waste of money. |
01-06-2010, 07:39 AM | #17 |
161
Rep 7,377
I would do the LSD first and than the complete M3 chassi upgrade. If you are than still not happy about suspension get coilovers or the koni fsd with eibach
01-06-2010, 07:47 AM | #18 |
Power without control is no power at all...
15
Rep 190
LSD hands down. It will not only help you put all that power to the ground (no more peg-leg), but it will also improve your cornering ability and control. As soon as I find time to part with my car for more than a few days - an LSD is going in...
2009 335i Coupe 6MT Blk Sapphire / Blk Leather
2007 328i Coupe 6MT Blk Sapphire / Blk Leather *Sold 1985 Toyota Corolla GTS 5MT 1.5-way Slvr / Blk *Sold 1987 Toyota Corolla GTS 5MT KAAZ 2-way Blk / Blk *Sold |
01-06-2010, 08:39 AM | #20 |
314
Rep 3,262
You need the Quaife LSD...
01-06-2010, 11:19 AM | #21 |
375
Rep 17,017
I would do suspension first, KW V2s would be my choice out of those options. GC's are also a solid setup but I like the KWs as a mix between street and track use.
01-06-2010, 11:40 AM | #22 |
23
Rep 130
I would do LSD first if that is an option for you, and also the Eibach springs at the same time. It's not perfect but you can live without the FSD's for a while and simply add them afterwards... least you get a bit of a drop from the Eibachs in the meantime.
