A/F ratio
12-30-2009, 02:37 PM | #1 |
Rep 200
A/F ratio
Please could someone indicate the parameter to be logged on bt in order to get the a/f information from o2 widebands and the convertion ratio (eg from volts to stoichiometric)?
Thanks in advance. |
01-02-2010, 04:16 AM | #3 |
Rep 200
I probably found them.
- Lambda nominal value bank 1-2. In addition the wideband signals are: - voltage lambda probe in front of catalystic converter bank 1-2. At the moment I don't have the conversion factors from volts to stoich but I think they are only a division and an offset away |
01-02-2010, 04:27 AM | #5 |
161
Rep 7,377
Yeah ! Please let us know!
01-25-2010, 05:56 AM | #7 |
307
Rep 5,175
Piggies bias the wideband so that is useless then. Second BT log samples are simply way to slow if you really want to see any useful wideband info. I suggest buying one if you really want to monitor A/F ratios.
01-25-2010, 07:07 AM | #8 | |
Moderator
270
Rep 4,481
Thanks, Eugen |
01-25-2010, 07:18 AM | #9 |
Rep 200
01-25-2010, 07:24 AM | #10 |
307
Rep 5,175
01-25-2010, 08:52 AM | #11 |
Moderator
270
Rep 4,481
01-25-2010, 09:00 AM | #12 |
307
Rep 5,175
