12-22-2009, 05:54 PM | #1 |
475
Rep 13,583
Drives: JB E92 335i
**********s | KW Coilovers Variants 1,2 & 3!!!
**********s is proud to present to the Bimmerpost community KW Coilovers Varients 1,2 & 3 !!!
[img]http://www.**********s.com/images/Products/KW_Coilovers/KW_head2.jpg[/img] Call in today for the ABSOLUTE LOWEST PRICE on all KW Coilovers. Please give me a call at (714) 582-3330 ext 8006 for the special price !! About KW Coilovers Is your Vehicle looking a little too high? Do you still feel insecure about the sharp turns you attempt around the corners? Is your current body kit not doing the job of creating that AGGRESSIVE appearance? Treat your vehicle and yourself with the best suspension system out there--KW's Coilovers! Not only does this system lower your car perfectly, but it provides HUGE performance benefits. KW designed and manufactured every coilover to CUSTOM fit your vehicle, unlike other coilovers that may be a "special one-coilover-fits-all", guaranteeing MAXIMUM handling and performance for your vehicle. Along with handling, this system makes sure your car is given a perfectly AGGRESSIVE stance, not a vehicle that's touching the floor. Maybe you're not the one for aggressive looks and ultimate performance, but for comfort. Well, KW took that into consideration, and integrated adjustable comfort technology. KW is known for their signature colors, individuality, quality, and security. Take a look below to read more into which KW Coilover Variant is the BEST option for you! [IMG]http://www.**********s.com/images/Products/KW_Coilovers/4_reason_02.jpg[/IMG] KW Variant 1 Sportive - Harmonic with KW factory pre-set up dampening The ideal systems for customers wishing to rely on the experience of KW engineers, yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety.
Sporty and Personalized with adjustable Rebound Dampening The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
Race Technology for the Road with: Adjustable Compression Rebound Dampening The new Variant 3 is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the high speed set-up, so decisive for driving comfort, has been preset by our engineers
[img]http://www.**********s.com/images/Products/KW_Coilovers/variant1.jpg[/img] [img]http://www.**********s.com/images/Products/KW_Coilovers/variant2.jpg[/img] [img]http://www.**********s.com/images/Products/KW_Coilovers/variant3.jpg[/img] What are Coilovers? A coilover suspension basically gives you a matched lowering spring and shock absorber combination with the added benefit of adjustable ride height and spring rates through a moveable spring perch or perches. Coilovers are to your car's advantage by reducing unsprung mass, increasing suspension travel, and allowing the car to be corner balanced. Why do KW's cost more than other Coilovers? The answer is simple, you get what you pay for when it comes to vehicle suspension. As such a crucial component of your vehicle, suspension is definitely something you do not want to cheap out on. KW is known for their reinforced and durable suspension components. KW's coilovers have been carefully crafted and designed by studying the flaws of competitors and improving on them. In addition KW coilovers can go lower than just about any other brand and allow you to set your car to a "slammed look", "sporty look", or anywhere in between. In the unfortunate event that anything should happen to your coilovers, KW's warranty backs all their products from manufacturer's defect. Function
Quality
Any questions feel free to call me at (714) 582-3330 ext 8006 or e-mail me at Alan************.com Alan |
01-22-2010, 11:35 PM | #5 |
Engineer
212
Rep 2,122
Drives: M235I 2015, 335i 2011
05-28-2010, 01:59 PM | #9 |
475
Rep 13,583
Drives: JB E92 335i
All pms sent and replied guys
Shoot me over a PM, email me at Alan************.com or give me a call at ************** ext 8006 for the best price guaranteed ! |
04-28-2011, 10:04 AM | #14 |
475
Rep 13,583
Drives: JB E92 335i
