DIY - LED licence plate lights and door entrance lights
10-15-2006, 04:18 AM | #1 |
81
Rep 1,391
Drives: F10 G29
Since the ECU is monitoring the current of any exterior light, changing to a LED bulb will trigger the error message.
In order to avoid the error message, you will need to fool the ECU that you are using the correct power consumption. This is what I used in my LED licence plate light mod... 1) an extra pair of Licence plate light housing (less than US$6 for a pair) 2) Three 25W 220 Ohm resistor w/ metal heat shink. (pls note the resister value will vary with different LED bulbs) 3) some Telfon coated cables and Telfon tubes 4) a few Nylon ties 5) a soldering iron and some solder 6) two 37mm 6LED bulbs I bought a new pair of the licence plate light housing, so that I can easily reverse the process........when I bring my car into service, they won't even know I did anything to the lights. For the telfon cables.....actually, you can use regular cables. I only use it for added protection. Just one more reminder: DO IT AT YOUR OWN RISK Last edited by rikuF10; 10-15-2006 at 09:48 PM.. |
10-15-2006, 04:20 AM | #2 |
81
Rep 1,391
Drives: F10 G29
First, you have to take out the licence light housing. Just put a flat screwdriver into the hole to the left of the plastic lens.....push to the right & pull the housing down.
Then just pull off the plugs. |
10-15-2006, 04:27 AM | #3 |
81
Rep 1,391
Drives: F10 G29
Then you need to solder the 3 resistors to the housing. I am running them in parallel. Since the two lights are running in parallel, it doesn't matter where you install the 3 resisters. For the cable length, 30cm is good enough.
I put two to the left housing and one to the right housing. In first photo, you can see a small resister at the right. It is actually good enough to just use this one. However, it will gets very hot. For safety, I divided the load to 3 extra large resisters. Last edited by rikuF10; 10-15-2006 at 05:15 AM.. |
10-15-2006, 04:33 AM | #4 |
81
Rep 1,391
Drives: F10 G29
Now, install the modified light housing back to the trunk lid. and secure the 3 resister with nylon ties.
I found there are 3 good places to put this inside the trunk lid... |
10-15-2006, 04:35 AM | #5 |
81
Rep 1,391
Drives: F10 G29
Now put the trunk lid lining back.....and it is done! :rocks:
.....also noticed that my blacklines has no white lights leaking at the edges? ....just replace all four P21W bulbs with a red color bulbs. Not only will there be no white light leaking out, the blackline also looks cooler at night! Last edited by rikuF10; 10-15-2006 at 11:41 AM.. |
10-15-2006, 05:04 AM | #6 |
81
Rep 1,391
Drives: F10 G29
For the door entrance lights, it is not being monitored by the ECU....so you don't need anything to fool it.
For this mod, I am using a 6 LED plate. On the passenger side door, I put the LED plate right behind the plastic diffusor, so doesn't really get to be diffused. The result is 6 bright LED squares projected to the ground (with three dimmer ones as bonus). Looks kind of |
10-15-2006, 05:07 AM | #7 |
81
Rep 1,391
Drives: F10 G29
On the Driver side, I put the 6 LED plate with a clearance of approx 1cm to the diffusor. I get one large bright lights. This illuminate the floor very well....make sure I don't step on any shXT when exiting the car...
10-15-2006, 06:03 AM | #8 |
235
Rep 6,874
Drives: 330i E90 C55 AMG
Garage List 2006 BMW 330i E90 [0.00]
2006 BMW 330i E90 [0.00] 2005 Mercedes Benz ... [0.00] 2002 Z3 2.2 USA Spo ... [0.00] 2002 Toyota MR-S Co ... [0.00] |
WOW ! Thank you for your kind sharing with these wonderful E90 LEDs works with us.
BMW 2006 330i E90 Jet Black/Black Leathers/Aluminium, Steptronic Active Steering; MTech Aero Kit Carbon Fibre Splitters/Diffuser. Bilstein PSS9 Coilover, Rays VOLK Racing RE30 Formula Limited Edition 18" Pirelli Rosso; Project Mu 355mm Forged 4pot Caliper. HID:Osram D1S 6000K, PIAA 6500K White Ring, Philips Diamond Vision HB4 5000K, PIAA H490/H491 Super Bright 6500K LED Interior Lights. Chrome S.Wheel Cover, Rear Windows Sunshades.
10-15-2006, 09:04 AM | #12 |
7
Rep 433
Nice DIY
2006 330i Sparkling Graphite/Sport pkg/Comfort Access/Aluminum Pedals/35% LLumar tint/Blacklines/OEM Shortshift knob |
10-15-2006, 11:35 AM | #13 |
Flushing, Queens stand up!!
35
Rep 830
Wow. Great DIY! Think I'll try this in the upcoming weeks.
l 20% Tints l Osram 6000k Xenons l Brex l Blacklines l White Led Sidemarkers l PIAA Superwhite Turn Signals l 19" Breyton Spirits l H&R Sport Springs l Koni Yellow Adjustable Dampers l ACS Roof Spoiler l Painted Carbon Spoiler l Luminics Fogs l Oem Chrome Grill l
10-15-2006, 09:44 PM | #17 |
M5 Extraordinare!
Rep 78
Excellent! I hope the rear licence plate is the same for the E60 or very similar... I've been wanting to do that for like a year.
2008 ///M5 SMG | Alpine White | Black Full Merino Leather w/Aluminum Trim | Logic 7 | iPod Adapter | HUD | Heated / Ventilated & Adaptive Comfort Seats | Comfort Access | Rear Side Airbags | Rear Side Sunshades | Folding Rear Seats | 35% Sides 15% Rear Windshield Tint
10-15-2006, 09:56 PM | #18 | |
81
Rep 1,391
Drives: F10 G29
10-15-2006, 10:01 PM | #19 | |
81
Rep 1,391
Drives: F10 G29
Feel free to come & take a look before deciding to mod it.... Let's have a mini HK LED meet! |
10-16-2006, 12:20 PM | #20 | |
548
Rep 6,563
the door light is cool bro with the 6 small led shooting down the ground... |
10-17-2006, 12:02 AM | #21 |
E60
39
Rep 587
hey i set off the ECU when installing led's in the headlights, i believe its the parking light (the peanut bulb) any idea how i can fool the ECU for that?
10-17-2006, 12:03 AM | #22 | |
M5 Extraordinare!
Rep 78
Sounds like a plan.
