BMW M3 Forum (E90 E92)
      12-20-2009, 01:31 PM   #1
viperpilot
viperpilot's Avatar
Drives: Black M3
Lux H8 install question?
The space on the right side is very limited for the H8 install.
Short of removing alot of the surrounding plastics,does anyone
have any suggestions? Thanks
      12-20-2009, 01:48 PM   #2
Moxie
Moxie's Avatar
Drives: AW 328d Touring/SG 335d
I dropped the wide part down first and them reached in & guided it up pulling the wires with one hand & my fingers pushing the bulb into the opening. I marked the metal part with a grease pencil so I knew where it lined up. Once in the opening, I got a couple fingers in to turn it tight. GL -
      12-20-2009, 08:17 PM   #3
smokinjoe64
Naval Aviator
smokinjoe64's Avatar
Drives: 12 e92 M3 6MT
As you now know, if you don't have 'toddler' sized hands, you'll need to be a little creative due to the space constraints. For me, there was no way I could 'finger' the unit and turn it in that small space.
So... I looked around the garage for possible alternative tools to assist. Actually, I used a small padded pipe wrench to securely hold the light unit while supporting the rear with a flat, slightly curved tool called a spanner (used to adjust motorcycle suspension settings). Using these in combination allowed line-up and alignment of the notches and a means to securely turn the unit until tight. A neighbor stopped by and said it looked like surgery.
...it definitely takes some patience.
e92 M3 - Interlagos Blue | Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II E85; SuperSprint F1s; Cat-less Bomiz X-Pipe; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK
      01-07-2010, 03:34 AM   #4
walmer
Drives: BMW
well yes it requires some patience....
SMF For Free -Free 646-003 Machines Forum hosting.
the only 1z0-042 Topsite out! Join and get free ad exposure for your 1z0-043 powered website!
      01-07-2010, 10:48 AM   #5
Moxie
Moxie's Avatar
And fingers like E.T. -
      01-07-2010, 03:30 PM   #6
SpencerM3
Sauce
SpencerM3's Avatar
Drives: 2009 SSII E90 M3
The drivers side I did ok, in about 5 minutes or so. The passanegr side was a total fucking bitch and I cut up my hand pretty bad. There is no trick, just play with it, you'll get it in.
2009 E90 M3 | Silverstone II | Black Novillo | HRE P40's | Akrapovic Exhaust | Eibach Pro Kit | Jet Black Kidney Grilles | SSII Side Reflectors | SSII Side Gills | LUX H8 Angel Eyes | Macht Schnell Filter | Tecnocraft Envy Charge Pipe
"M3 drivers have no friends." - Jeremy Clarkson
      01-07-2010, 06:02 PM   #7
808MGuy
808MGuy's Avatar
219
Drives: 2009 E90 M3
Is this something that could be made easier by just removing the entire light housing from the car or is the problem within the housing itself?
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
      01-07-2010, 08:44 PM   #8
mds82
mds82's Avatar
364
Drives: 2006 325xi
Nope - taking the headlight out of the car would require 2-3 hours of work. It really will only take about 5 minutes to get it in place. you just need a bit of patience
m3post
