12-18-2009, 09:37 AM | #1 |
193
Rep 1,457
128i RealOEM Engine Choices
Hey there guys,
I searched it briefly on the forums, but couldn't find information about this. When I select my car at realoem website, there are 2 engine choices.. N51: 01/2009 E82 128i Coupe N51 USA Left hand drive Production Code: UP93 N52N: 01/2009 E82 128i Coupe N52N USA Left hand drive Production Code: UP73 What is the reason for this? What are the differences, anyone have any insight on this? Thanks. Edit: Well Looks like N51 is SULEV engine, compared to N52.. So question is, which one performs better?
12-18-2009, 10:31 AM | #2 |
12
Rep 249
+1 on what's that
Currently driving 2003 HONDA S2000
128i | Jet Black | Premium package | Sport package | 18" Style 263 | 6MT | Injen Intake | BMS PowerBox |SOLD |
12-18-2009, 10:48 AM | #3 |
34
Rep 504
12-18-2009, 12:21 PM | #4 |
133
Rep 1,416
Drives: M-Sport 128i, 328xi, 3.0CS
SULEV is for California, New York, Maine, Massachusetts, Vermont, Connecticut, Rhode Island, Oregon, and Washington.
My '09 128i is a SULEV with the N51 engine. The SULEV emissions measures include: • Secondary Air System with mini-HFM • Radiator with “Prem-air” coating • Lower compression ratio (10:1) via modified combustion chamber and pistons • Underbody catalyst in addition to “near engine” catalyst • Activated carbon air filter in air filter housing • Plastic valve cover with integrated crankcase vent valve and separator (from N52KP) • Steel fuel lines with threaded fittings and sealed fuel tank • Crankcase ventilation system integrated into cylinder head cover • Purge system piping made from optimized plastic
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
12-18-2009, 06:57 PM | #5 |
12
Rep 249
so performance wise is there any difference between N51 and 52?
12-18-2009, 08:00 PM | #6 |
193
Rep 1,457
"Steel fuel lines with threaded fittings and sealed fuel tank" this is a very interesting difference... as it is really not an engine change...
12-19-2009, 08:39 AM | #7 |
133
Rep 1,416
There is a sticker near the radiator that says that it must be replaced with one with the Prem-air coating. The coating turns ozone into oxygen.
There is a BASF paper here that describes it.
12-19-2009, 08:41 AM | #8 |
133
Rep 1,416
It has the same 230 HP rating, but I am not convinced because of this difference: "Lower compression ratio (10:1) via modified combustion chamber and pistons".
12-22-2009, 12:30 AM | #9 |
8
Rep 75
I'm in California and I have the N52 engine. My VIN has the UP73 in it.
I also tried this website. I don't know how accurate it is though. http://www.bmw-z1.com/VIN/VINdecode-e.cgi |
12-22-2009, 08:45 AM | #10 |
193
Rep 1,457
well this is getting interesting.. CA driver with n52.. Did you buy it new or used ?
12-22-2009, 09:12 AM | #11 |
Rep 73
the car may have been diverted from a dealer in a non SULV state to his CA dealer...
I would not prefer a SULEV car given the extra/different emission parts used. I recall reading Mike Miller indicating that the SULEV e46s were more problematic. Last edited by cimbali; 12-22-2009 at 10:42 AM.. |
12-22-2009, 10:10 AM | #12 |
8
Rep 75
It was new, I ordered it.
This is from a couple of years ago, but it discusses the different engines. Looks like there are 2 different types of N52 engines. http://www.e90post.com/forums/showthread.php?t=52608 |
12-22-2009, 12:05 PM | #13 | |
24
Rep 179
There can't be much difference. I'm sure it takes a dyno to tell the engines apart.
12-22-2009, 04:23 PM | #14 | |
34
Rep 504
negligable. |
05-12-2010, 08:20 PM | #15 |
19
Rep 113
The N51 has the 3 stage intake manifold to compensate for that. So who knows, it may even put out slightly more than the N52... only BMW can tell.
