Procede HELP AGAIN!! SOS LIGHT AGAIN
12-12-2009, 08:23 PM | #1 |
41
Rep 1,221
I put the procede back in the car last week with the newest firm wire and map. A week later today, I got the SOS light. Keep in mind all I have for modes is a front mount inner cooler and drop in filter.
Here are the code. Can any one help why this happen or how to make it not happen? Customer Information Vehcile: Production Date: / MSD80/MSD81 Engine module for N54 Module Identification Hardware Number 7596017 Hardware Vesion Number 00 Coding Index 17 DiagnosticIndex 0000 VariantIndex 3333 Date of ECU Manufacturing 20070507 System Supplier Siemens Message Catalog Version 0.0.0 Software Version 0.0.0 OS Version 0.0.0 Current Fault Codes 2C74: 2C74 Lambda probe behind catalytic converter 2, signal Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption FREEZE FRAME INFORMATION Event 1Odometer 62672kms 38942miles exhaust fume temperature behind catalytic converter bank 2 320.00 °C resistor Lambda probe behind catalytic converter bank 2 0.00 ohm voltage Lambda probe behind catalytic converter bank 2 1.13 V time since start end 0.00 s 2C73: 2C73 Lambda probe behind catalytic converter, signal Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption FREEZE FRAME INFORMATION Event 1Odometer 62672kms 38942miles exhaust fume temperature behind catalytic converter bank 1 336.00 °C resistor Lambda probe behind catalytic converter bank 1 0.00 ohm voltage Lambda probe behind catalytic converter bank 1 1.13 V time since start end 0.00 s 29E2: 29E2 Fuel injection rail, pressure sensor signal Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption FREEZE FRAME INFORMATION Event 1Odometer 62672kms 38942miles Engine speed 0.00 rpm rail pressure 262,193.92 hPa voltage of the fuel pressure sensor before mass control valve 2.62 V average rail pressure 4.80 V 2ABC: 2ABC Charging pressure sensor, electrical Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption FREEZE FRAME INFORMATION Event 1Odometer 62672kms 38942miles Engine speed 0.00 rpm pressure in front of throttle valve 251.00 kPa throttle valve actual value 5.60 °TPS status motor control 0.00 0-n 3100: 3100 boost-pressure control, deactivation Error will not cause a warning light Error is not currently present Test conditions have been completed FREEZE FRAME INFORMATION 29F5: 29F5 Catalytic converter conversion 2 Error will cause a warning light Error is not currently present Test conditions have been completed FREEZE FRAME INFORMATION Event 1Odometer 62880kms 39071miles Engine speed 1,920.00 rpm air mass calculated 233.31 mg/stk Engine temperature 93.00 °C Intake air temperature 30.75 °C Event 2Odometer 63232kms 39290miles Engine speed 1,984.00 rpm air mass calculated 347.26 mg/stk Engine temperature 95.25 °C Intake air temperature 31.50 °C 29F4: 29F4 Catalytic converter conversion Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption FREEZE FRAME INFORMATION Event 1Odometer 62880kms 39071miles Engine speed 1,760.00 rpm air mass calculated 222.46 mg/stk Engine temperature 93.00 °C Intake air temperature 31.50 °C |
12-12-2009, 10:26 PM | #4 |
153
Rep 3,868
Drives: E93 335i
Check with your Tuner (Vishnu). That's what I do with JB3 if I get error(s) after software update.
12.770 @ 112.81 mph||slip||JB4|FMIC|DPs|DCI|N54 DVs|ER CP|Koni FSD|Eibach-Pro|F Strut-bar|R Sway-bar|Hankooks V12|DPE SP16|BBK|15%Tint|CF Front Lip|CF Diffuser|M3 Spoiler|SmartTop|LUX AE|Debadged |
12-13-2009, 06:44 PM | #5 |
200
Rep 1,741
Drives: e92 335 space gray/coral red
O2 sims should take care of 29F4 and 29F5
GIAC S2 | Brembo GT BBK 355/345 | BBS CH-R | Michelin Pilot Super Sports | AR Design: DP, S1 Oil Cooler, OCC | AMS FMIC | Bastuck Quad Exhaust | Borla MP | KW V1 | Stett: CAI, CP | Forge DV | P3 Boost Gauge | Arkym: Front Lip, Rear Quad Diffuser | Vorsteiner CSL Trunk | LUX H8 | ModMyNav | MFD M3 Sideskirts | BMW M-Tech Front/Rear Bumpers, Edition Grills |
12-13-2009, 06:48 PM | #6 |
134
Rep 3,132
But he has all of his cats...
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
12-13-2009, 07:15 PM | #7 |
101
Rep 1,668
12-13-2009, 08:15 PM | #13 |
125
Rep 3,004
Clear your codes first.
Then remove the yellow patch on your PROcede, this is the patch that has the O2 sensor intercepts. Drive around for 2-3 days without this patch plugged in, it will not hurt your car, it just won't add more fuel on the top end, so don't run it out to redline. If the car drives witout errors or mis-fires remove the Purple Wires (they are used for the o2 sim) make sure you re-install a couple of the yellow unused wire sections to "pass through" the purple wires you removed and re-install the yellow patch and drive around. This resolved my catalytic converter codes....so far anyways. Since we both have all our cats, we don't need those purple wires. This worked for me, good luck. |
12-14-2009, 08:35 AM | #15 |
اوليسيس
198
Rep 4,678
1. why havent you done the call back from Vishnu on this by now?
2. For some reason i get the feeling it was loaded with an old map on a new firmware. 3. I would start over if i were you, download the latest firmware and maps from the Vishnu site.
12-14-2009, 10:54 AM | #16 |
125
Rep 3,004
12-14-2009, 03:10 PM | #18 |
اوليسيس
198
Rep 4,678
for the sake of testing i dont think it matters. ^^^^
12-14-2009, 04:08 PM | #19 |
1112
Rep 3,261
how did u put it back in the car AFTER uploading to newest maps/firmware? as far as i know there's no way to update unless the procede is installed...
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
12-14-2009, 05:26 PM | #21 |
اوليسيس
198
Rep 4,678
i think if you hook it up to a power supply you can, its pretty much a little computer.
12-14-2009, 05:58 PM | #22 |
125
Rep 3,004
Yup you can get a little 12volt power supply from radio shack, I believe this is how Vishnu loads the maps before sending them out to customers, as installing it in a car everytime would be a real pain.
