BMW X3 Forum
BMW X3 Forum
      12-09-2009, 10:02 AM   #1
stepanko
Drives: 2006 - X3
X3 - Hands free phone advice
Just got a beautiful 2006 X3. Luv the car. However, in our province it is now illegal to use a cell phone while driving. Needs to be hands free. My X3 did not come set up for that. What are my options (or what is my best option) to add this feature? Any advice?
      12-29-2009, 01:44 AM   #2
Convertible
Finland
15
Drives: BMW
Well, I just bought a nokia phone holder for the hand rest and installed it. Numbers and names show up in the navi. Check if you have the same option.
E87 120i M Sport
E87 118i
E30 M3
E30 M3 Convertible
      12-30-2009, 01:47 PM   #3
rs6655
rs6655's Avatar
18
Drives: 2009 X3 (MT)
http://www.bimmernav.com/store/catal...o-item-85.html
      12-31-2009, 12:15 PM   #4
fijigabe0
fijigabe0's Avatar
Drives: 2013 F30 335i M Sport
i think your best bet is to just get a handsfree headset and use that. retrofitting the car for bluetooth is going to get expensive, and then you'll only have the option available when you're IN the car. i'd just go with a headset if i were you.
Gabe
'13 335i M-Sport
Past - '06 330xi, '07 X3 3.0si, '09 328i, '12 X3 XDrive 35i
      01-12-2010, 09:51 AM   #5
smellthebeans
smellthebeans's Avatar
Drives: LPCs
1990 325i  [0.00]
You can replace the head unit in the vehicle with an bluetooth enabled one. Best Buy or similar type place is your best bet.
      01-12-2010, 09:58 AM   #6
fijigabe0
fijigabe0's Avatar
i think the issue is more than just the head unit, as he'd also need the BMW antenna.
also, Best Buy (or whatever you have up in Canada) probably won't want to replace a BMW head unit with another BMW head unit, without charging massive labor rates.
if you want to know what you NEED to replace, go to the parts counter, have them run your VIN, and tell them you want to add the Bluetooth unit. see what they tell you. my guess is that it's probably not worth what they want.
Gabe
'13 335i M-Sport
      01-12-2010, 10:01 AM   #7
fijigabe0
fijigabe0's Avatar
Originally Posted by rs6655 View Post
did you check the price on that thing? $760!
Gabe
'13 335i M-Sport
      01-12-2010, 10:24 AM   #8
smellthebeans
Drives: LPCs
1990 325i  [0.00]
I may have jumped the gun...does the vehicle have BMW assist? An SOS button located next to sun roof button? If it does that I am 99.9999999 percent sure it has a factory bluetooth unit (called a telephone control unit TCU).
If not...
A reputable shop can replace the head unit. The bluetooth unit utilizes the antenna in the phone. The E83 (X3) electonics are primarliy built around the E46 Generation of vehicles so there is no fiber optic BUS between the Amp or siruis unit thus, potentially complicating replacement as seen in the new generation E90s.
The vehicle external antenna is only activated with the installation of the armrest power adapter (assuming you have a matching BMW approved phone).
It does not cost anything to ask about replacing the head unit.
      01-12-2010, 05:06 PM   #9
rs6655
rs6655's Avatar
18
Yep!
A cheaper option:
http://www.amazon.com/Motorola-T305-.../dp/B000JKKE5M
      01-12-2010, 05:25 PM   #10
rs6655
rs6655's Avatar
18
stepanko,
If you have factory Bluetooth and your car is prewired for a phone you can dock your phone (if BMW makes an adapter for your model) in the lid of the armrest.
I docked my iPhone 3G and couldn't be happier with the result.
Here is the DIY I posted on another board:
http://www.bimmerfest.com/forums/sho...1&postcount=15
http://www.bimmerfest.com/forums/sho...5&postcount=14
http://www.bimmerfest.com/forums/sho...0&postcount=17
http://www.bimmerfest.com/forums/sho...44&postcount=8
After I was done I discovered that BMW already makes a modified eject box for the 3G:
http://www.bimmerfest.com/forums/sho...7&postcount=28
http://www.bimmerfest.com/forums/sho...2&postcount=34
xbimmers
