quick questions for E90Fleet or Stressdoc - why twin turbo?
10-09-2006, 03:15 PM | #1 |
3570
Rep 10,351
Any idea why BMW went with the twin turbo instead of the sequential turbo in the 335i?
10-09-2006, 03:23 PM | #2 |
1312
Rep 10,185
Apparently partly had to do with turbo lag control (535d stilll has some lag) and turbo heat control ( remember the diesel engines that have the sequential setup have a much lower exhaust gas temperature than the petrol engines )
The high exhaust gas temperature is also why hardly any turbo petrol engines have variable vane turbos. Only main one that has it is the new Porsche 911 Turbo, and it uses very advanced, very expesive materials for its turbos. Most new diesel turbos on the other hand have the variable vane system. Some say they also didnt want the power too high, else the non-turbo M3 would have problems
BMW if you are reading, I need a job, Please. |
10-09-2006, 03:41 PM | #3 |
Vroom Vrrooooom
300
Rep 3,146
Drives: 330i
I remember wiki had a little thing on the VGT when I researched about porsches work.
EDIT: found it: http://en.wikipedia.org/wiki/Variabl...y_turbocharger
-Dmitriy
06' BMW 330i & 03' Suzuki GSX-R600 SG | Beige Dakota | Poplar || iDrive w/MP3 | PP | SP | CWP | PDC | Comfort | Shades || 40% Tint | Black Line Tail Lights | Hardwired V1 |
10-09-2006, 03:57 PM | #4 | |
14
Rep 710
10-09-2006, 04:00 PM | #5 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Also...BMW needed to maintain their legendary I-6's feel i.e. linear power delivery/flexibility. I think they put a lot of effort to replicate the feel of a large NA engine with the N54 setup. Great job!!
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
10-09-2006, 06:45 PM | #6 |
119
Rep 2,909
Remember when Dodge had a VNT turbo back in the early '90's? There was very little lag out of the turbo, however the system was total crap with regards to quality, because of what Fleet just explained. I think it was only around for a year or two, before Dodge shit-canned the idea.
11-04-2006, 12:47 PM | #7 |
Rep 7
A sequential turbo system does not necessarily mean that one turbo is larger than the other. The twin turbo Supra is a sequential setup, but both turbos are the same size. At first all exhaust is directed through only one turbo while the other turbo is blocked off. This first turbo therefore spools almost instantly. About the time that this single turbo would run out of airflow to support X psi of boost, the second turbo gets to share in the exhaust and thus it spools too. Of course you also have to block off the intake side of the second turbo during stage 1 because otherwise the boost from turbo #1 would blow backwards through turbo #2 and do you no good. This system is far more complex than a standard "twin turbo setup" and its only real upside is quicker spool. With today's modern turbos, you get X hp with much quicker spool than the turbo that would have been required to make X hp 5 years ago. Therefore, BMW was able to size two twins that would run in parallel and yet still have the desired spool and power characteristics, without all the extra cost and complexity of a sequential system.
And in case anyone is wondering "why twins at all?", two turbos that together can produce X hp will always outspool one single turbo that can produce that same amount of hp if everything else is equal (ie. both turbos have the same caliber of aerodynamics, both are the same type of bearing system, etc.) This is because the majority of the spool time is due to the delay in accelerating the wheels in the turbo, and the moment of inertia of a disc increases polynomially with diameter. In other words, it takes way more energy to accelerate one "big" compressor wheel than it does to accelerate two "small" compressor wheels. BMW seems to put a heavy emphasis on achieving zero lag and this is undoubtedly why they chose twins over a single when obviously there are dozens of single turbo choices that could have supported this power level at a cheaper price point. |
11-04-2006, 09:10 PM | #8 |
Moderator
618
Rep 10,855
I bought into the standard line from BMW R&D that small twins provide quick, even spool up. Easier to generate the early and flat power curve that they wanted for the 335. I think there are some interesting new engine management opportunities for turbos with the piezo DI system.
11-16-2006, 02:21 PM | #9 | |
14
Rep 710
11-16-2006, 02:53 PM | #10 |
548
Rep 6,563
there is an article on the new turbo engine in the last bmw magazine (or the 335i brochure) that provides lots of interesting technical discussion and why they did what they did.
under construction! |
11-16-2006, 02:58 PM | #11 | |
Rep 7
11-16-2006, 03:59 PM | #12 | ||
Borti
Rep 114
You cannot have a car with different sized turbo-chargers. It would be putting uneven pressure on the cylinders.
11-16-2006, 05:02 PM | #13 | |
1736
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
-shiv edited: it was a 6 cyl not a 5 cyl. Last edited by OpenFlash; 11-16-2006 at 09:13 PM.. |
11-16-2006, 09:00 PM | #14 | |
34
Rep 1,507
hows that work? |
11-16-2006, 09:15 PM | #15 | |
1736
Rep 17,960
Drives: A Lot
Shiv |
11-17-2006, 04:55 PM | #16 | |||
Borti
Rep 114
Thanks Shiv.
11-17-2006, 05:55 PM | #17 |
Rep 286
From what I can tell via google the Saab 9-5 used an asymmetrical turbo design. The used a Garret G17 turbo hooked up to one bank of cylinders on their V6 (which is actually a GM sourced engine) that fed the intake thus turbocharging the engine. The G17 is a very lightweight (by design standards of the day) turbo that didn't take much exhaust to spool up.
The design in general was all about getting low end power and torque in an economical sense. Saab saved money by using a small turbo and got the power they were looking for.
E90 335i, Sparkling Graphite, Black Dakota leather, Burlwood trim, 6MT, ZSP, ZPP, PDC, Comfort access, heated seats, Navi w/iDrive, Production finished 10/6, Delivered 11/22/06.
