12-01-2009, 10:43 PM | #1 |
114
Rep 973
trying to figure out a screen solution
hi guys i have a z4 with professional sound system but no navigation whatsoever so i wonder if i can retrofit a navigation system on my car.if i get to do that would i be able to connect a dvd player to the screen? thanks in advance guys
if you want perfection buy a mercedes, or marry an accountant
02-14-2010, 12:14 AM | #2 |
Custom User Title
141
Rep 661
LCDs in visors
I am noodling the idea of retrofitting a 3.5" LCD into the passenger visor. Not so much for GPS, but for backup cam/ other video. There are quite a few "LCD prototyping kits" out there for less that $200 which provide a screen and a tuner board. Nearly all accept/display NTSC or PAL video. The screen would fit easily into a Z4 visor, and the tuner board could probably be put along side it. I am not sure about the heat issues once you get all the parts covered and upholstered again though. Maybe a vented plastic panel for most of the inner visor surface?
Attachment 349379 Last edited by blender; 11-21-2012 at 10:33 PM.. |
02-14-2010, 01:59 AM | #3 |
40
Rep 969
OP there are plenty of people that have done what your asking - I would search around. You can retrofit the oem unit into a car without the nav with a bit of work.
As for the sunvisor thing... doesn't sound like my cup of tea. So when you want to get directions you need to have your visor in front of you field of view and stare at it while your are driving. The positioning of the oem unit is at least non-obstructive of your vision and is a quick glance from your normal line of sight out the windshield.
911 Carrera project car
Previous: E92 M3 ZHP - Sold E86 Z4M - Sold E36 M3 - Sold |
04-29-2010, 01:05 AM | #4 |
114
Rep 973
ok, i retrofitted the oem system. now i want to play dvds and also use the intravee ii. can i do this? how?
04-29-2010, 08:53 AM | #5 |
Certified Adrenaline Junkie
42
Rep 1,325
Here is one solution for the DVDs
http://www.zpost.com/forums/showthread.php?t=372831 But it has a camera as well. |
