Has anybody actually thrown a TUNER CODE?!
12-01-2009, 02:53 PM | #1 |
114
Rep 2,428
I'm curious if anybody has ever seen a tuner code/shadow fault code on their BT Scanner.
I remember seeing people say they've tried to throw a code on JB3 Map7 and still have not been able to do it. I don't remember ever hearing of someone actually getting a tuner code to show up. IF anyone's thrown one, what was your experience? What was the actual code? Thanks |
12-01-2009, 03:15 PM | #5 |
184
Rep 2,841
I threw the tuner code well before the BT tool was released. 2DXX something = Air/fuel implausibility.
Had a local BMW shop clear it with an autologic scanner. Recently had both turbos replaced by the dealer and I have NO DOUBT they scanned the DME and poked around the ECU box. It does exist......just not as easy to throw as one might think. |
12-01-2009, 03:23 PM | #7 |
Rep 200
12-01-2009, 03:34 PM | #8 |
11
Rep 569
12-01-2009, 04:09 PM | #9 |
12
Rep 178
I have thrown both 2D18 and 2D25 several times under WOT with an 09 E92, MSD81, progman 35.x with the JB+ @ 75% or 100% and just also after installation/reinstallation. Also 2AAF, but this may or may not be tune related.
This is the very latest version of the progman and seems to be "more sensitive" to tuning. IMO. |
12-01-2009, 04:43 PM | #10 |
159
Rep 5,689
I run my jb3 on map 7 daily and occasionally map 8 or 9 if I have fuel and never thrown a tuner code with it. I did however throw a code with my sstt at WOT close to redline.
12-01-2009, 05:14 PM | #11 | |
How you like them apples?
40
Rep 1,492
Drives: 335i
if you could comment on that at this post below...everybody would appreciate it...its about what is the turbo life expectancy for both mod and stock cars http://www.e90post.com/forums/showthread.php?t=327083 thanks a lot
V5 rev2.5 | VExhaust | V1 KW | V701 | H&R Sway Bars | Ram Air Scoops | DCI |
12-01-2009, 05:23 PM | #12 |
Modder Raider
758
Rep 8,633
Drives: M3
Interesting because my friend is a tech and has never seen the tuner codes at the dealer. Maybe it's because everybody is deleting them.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
12-01-2009, 05:40 PM | #13 |
63
Rep 1,884
Keeping the JB+ at 50% or lower should not throw a code. At 75% and up you may and that is why you should get the BT tool. That is a great reason to buy the JB+ or JB3/BT combo since it will save you a lot of money up front and give you that safe warm fuzzy feeling.
My Youtube Channel
