Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Asia > Hong Kong > Does anyone know?
      12-01-2009, 02:11 PM   #1
Renus
Renus's Avatar
28
Drives: E92 335i
Does anyone know?
Does anyone know, E92 335i's F & R brake kit and Sport suspension can install on E90 325i or not?? Thanks ^ ^
      12-01-2009, 07:56 PM   #2
little_croco
little_croco's Avatar
Hong Kong
142
Drives: E90 330i Monaco Blue/Beige
2006 E90 330i  [6.00]
negative, the brake disc sizes are different.
E90 330i VB32 Monaco Blue/Beige/BurledWalnut - Prodrive GC-014I Forged 18" 8.5J/9.5J British Black + Michelin PSS 225/255 + Bilstein PSS10 + H&R ARBs + ACS bodykit + Brembo Gran Turismo Brake Kit 355-6F/345-4R + Rogue Engineering IKON exhaust kit + Simota Intake V2 + MFD Scoops + Blackline w/ red bulbs + PIAA H11 4700K fog + PIAA 6500K White Angel Eyes + MTEC 7000K license plate LED + GS-55 front doors LED + Valentine-1
      12-02-2009, 01:11 AM   #3
RR80
RR80's Avatar
17
Drives: F10 535i
Why not? My friend's 330 is using 335i's brake kit, so did 325i! But you need atleast 18" wheel to accommodate the kit!
      12-02-2009, 01:45 AM   #4
little_croco
Hong Kong
142
sizes for 330 and 325 are also not the same
      12-02-2009, 02:54 AM   #5
RR80
RR80's Avatar
17
Drives: F10 535i
I think the kit include the 335i's brake rotor which is 348mm if I rememeber it right!
      12-02-2009, 01:28 PM   #6
Renus
Renus's Avatar
28
Drives: E92 335i
If the brake kit F & R are fit for 325i, what about the Sport Suspension??
      12-02-2009, 07:22 PM   #7
RR80
RR80's Avatar
17
Drives: F10 535i
Not sure is there any difference between E92 and E90 for the supsension parts. You can go realoem.com to check for the parts number, that will fit if the parts # is the same.
      12-02-2009, 09:45 PM   #8
335 Freak
Bimmer Turbo Land
335 Freak's Avatar
Hong Kong
39
Drives: White E92 335I Coupe
Hi Renus,
Brake kit of 335 F & R will fit 325 so long as you installed the whole set...not just taking the brake caliper of 335 and then, put in 325 with the original 325 disc! Again, take the whole set as I've sold my original 335 E92 F & R kit to a guy with a E90 325 a month ago, through my friendly garage which happened to know the buyer!! Thus, I saw the job to get done right in front of me when I upgraded mine to AP front 6 pot...for front and rear for a smaller AP 4 pot.
As of the suspension, it won't fit.....even 335 E92 and E90 cannot be inter-changeable in terms of suspension kit even for OEM or aftermarket whereby, it just won't fit due to the weight and balance issue for differnt engine and platform!!!
Lumma BDK, M3 CF Hood, I-Forged Triumph 19", AP-6pt-360FR, AP-4pt-345RR, M3 CF Lip, ACS CF RFS, CF Grill, JB3 3.0, Stett DV CHG Pipe + DCI + FMIC, NST Pulley, F+R Full M3 Susp Kits, M3 E92 Q-pipes Ex, UR Catless DP, Ohlins C/O, Eibach Sway, M3 Dash Cockpit, CF Wrap Interior, M3 CF Pedals, M5 Shft Knob, LED ATW, OSS Design BlackOut LED Angel Eyes!!!
      12-02-2009, 10:01 PM   #9
gn02931341
Hong Kong
23
Drives: Bmw E92 335i
Originally Posted by 335 Freak View Post
Hi Renus,
How you like your AP Brakes? i am thinking to get set for my 335~ how$ u got the AP front 6pot?
      12-02-2009, 10:13 PM   #10
335 Freak
Bimmer Turbo Land
335 Freak's Avatar
Hong Kong
39
I used to have the Brembo big 6 pot for my prevous Audi 2.7T...I would say the AP is so much better for the same 6 pot set up!! You can really tell the detail of the brake caliper in terms of braking leveling for each level of pressing!! The Brembo isn't having such detail in which, you feel the middle till fully pressed has no function at all.....Then, the passenger ended up pulling their heads to the front every time you press the brake..... You should know what I mean, right??
I bought the AP for HKD20,000 inclusive of installation as the whole kit came with the Ferrodo 2500 pads. Make sure the guy sell you the 362 original AP disc...not a bigger 385mm drilled/slotted BMW disc as it is cheaper product than the original AP slotted disc as AP has No Drilled Disc....
Lots of people get cheated by the bigger and nicer looking drilled/slotted disc and wired up screwed up.. \
Matthew
      12-02-2009, 10:49 PM   #11
gn02931341
Hong Kong
23
Matthew
Thanks a lot for ur reply.
I hv been thinking about Brembo too, but i am sure now i will go for AP...(haha!!
HKD20,000 for AP 6pot + installation is nice price, i check with some shop they quote me AP RACING 6 POT CALIPER (10S4+11S4) PRO 5000+ 355MM for HKD20000,AP RACING 4 POT CALIPER (5040-2S4+5040-3S4) PRO 5000+ 345MM for HKD18000 + installtion.
Could you advise which shop u bought it?
3Q
      12-02-2009, 10:54 PM   #12
335 Freak
Bimmer Turbo Land
335 Freak's Avatar
Hong Kong
39
Just a friendly garage in Kwun Tong... not a big one but I have been fixing my car and installing mod parts for more than 6 years time..... PM me and I will give you the guy's number to call and you can deal by yr own!!!
Matthew
      05-03-2011, 10:41 PM   #13
Winson
Drives: BMW E90
Can i have the contacts for the AP brake?
Im interested and i think its a good good u get..
