removing caliper paint help?
11-24-2009, 12:59 AM | #1 |
106
Rep 1,534
Drives: jet black 335i coupe
Basically i have painted calipers on my 335 and was wondering how can i remove this?
I tried regular brake cleaner and that did not work, so i figured i should use some Aircraft Cleaner(strong paint thinner). Will i need to bleed the brakes in order to do this? Or can i just use paint thinner on brakes with just the pads removed? I have also heard brake fluid removes paint right off, would i be able to use this without having to take off the brake pads?
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
11-24-2009, 01:37 AM | #2 | |
Casual Modder
12
Rep 55
11-24-2009, 05:17 AM | #3 | |
307
Rep 5,175
11-24-2009, 06:21 PM | #4 | |
106
Rep 1,534
will try this in a few hours.
11-28-2009, 03:10 PM | #5 |
64
Rep 1,498
Sam, spray it with a few coats of goo-gone and let it sit, then go over it with a wire brush. Should take it off. If not, use parts solvent,or spray it grey like the stock color.
E92 328i Jet Black / Gloss Black Grilles / 8000k D1S low beam / 6000k HID fogs / GP Thunder 8500k angels & cornering bulbs / black reflectors / gloss black vinyled window trim / tints / smoked rear turn signals / black roundels / AC Schnitzer roof spoiler / VRS style decklid spoiler / Matte black Stripes / Rear fogs / matte mirrors / 19" LM reps / APR lip |
11-28-2009, 07:22 PM | #6 |
chris
278
Rep 12,144
pour some thinner over the calipers and then rub using very fine grit sandpapers... the paint should come off.... sand paper grit should be 1500... if you use rougher grits, it will leave deep gouges on the surface of the caliper.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
12-01-2009, 11:50 PM | #8 | ||
106
Rep 1,534
considering this
12-02-2009, 02:15 AM | #9 | |
64
Rep 1,498
1. Paint them black and hope your SA doesnt care. 2. Mask off the rotors and pads and use the paint remover and wire brush. 3. If you can, remove the caliper and pads (not that hard at all, if you have the tools, try the DIY), then remove the paint. I will tell you right now that I dont think parts solvent will have any mal effects on your brake pads, etc. I occasionally clean my calipers with parts solvent. If you just respray it silver to match stock, I doubt the dealer would ever notice.
