led rear bulbs rapid flashing
11-21-2009, 12:39 PM | #1 |
179
Rep 3,923
just fitted some led bulbs to the rear indicators, they work but are rapid flashing, have not fitted resistors yet, will this cure the rapid flashing and the error codes, i have seen a relay that is supposed to cure the rapid flashing and the error code any advice is much appreciated. also does anyone know how to remove the front indicator bulbs, e92 thanks
11-21-2009, 02:04 PM | #2 |
195
Rep 1,985
This is a common Q our customers always ask when they receive the LED rear turn signal kit. The LEDs will flash/strobe (normal) upon start b/c the the ECU is sending out pulses to check and see if the bulbs are present. Resistors will does resolve this problem btw.
