The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > switching from sport springs to oem suspension
      10-03-2006, 04:12 AM   #1
daheechang
Drives: E30 m3
Hi, i was just wondering if swicching from oem sport suspension to installing h&r sport springs back and forth is bad for your car. For instance, i want to install my h&r sport springs for summer use and go back to my oem sport suspension springs for teh winters for some light snow driving. is this bad for my suspension? sorry about the lack of knowledge behind this question, but i honetsly dont know too well about car suspension. Also, is it ok to install the sport springs without a camber kit and on stock shocks? is there anything i should get to protect my car? thanks in advance for the help.
      10-03-2006, 12:04 PM   #2
Yvette
760
Drives: M
as long as you do allignment, they will be fine
      10-03-2006, 12:44 PM   #3
ShinBalNom
ShinBalNom's Avatar
Drives: AW 330i
Do you guys do this yourselves or have a shop do it? Shops in Cali are asking way too much money to swap springs...
      10-03-2006, 01:53 PM   #4
yamazaho
Wang D.D.S.
yamazaho's Avatar
Taiwan
185
Drives: 14' WRX, 15' W205
2006 325i  [7.76]
Wow that seems to be a great way to spend a lot of money and a great way to go through lot of trouble~~~ Why don't you just get a set of coliovers and so you can adjust the ride hight with a lot less efforts. I know they are more expensive, but hey you pay for what you get man~~~
      10-03-2006, 03:51 PM   #5
///Matt
United States Marine
///Matt's Avatar
Drives: 2007 Dodge Ram 1500
2006 330i  [0.00]
You are going to wear out all the fasteners. Opening and re-torqueing those bolts a few times will be enough, and then you will have to replace all the fasteners.
Get some C/O's. It'll be a WAY better ride than the H&R will give, and you get the height adjustability.
matt
      10-03-2006, 04:35 PM   #6
obLu
obLu's Avatar
50
Drives: 330i 6MT ZSP
Coilovers are the way to go, but .... rear perches are usually a bitch to adjust. And then, if you're going to do it right you need to have it corner balanced each time the height is adjusted so that you're not hobby horsing.
      10-04-2006, 10:54 AM   #7
daheechang
Drives: E30 m3
how much do a good pair of coilovers run for? also, what is the recommended coilover springs?
      10-04-2006, 11:23 AM   #8
ScBlacksunshine
YUGO is my dream car
ScBlacksunshine's Avatar
144
Drives: Bayerische Motoren Werke
Anywhere from $1200 (usually height adjustable only) to $2200 (height/dampening/compression adjustment + pillowball mount for caster/camber adjustment)
      10-04-2006, 06:56 PM   #9
daheechang
Drives: E30 m3
oh wow. haha that is quiote a lot more compared to the 225 dollars sport spirngs i picked up from dtm. hmm.. this is goign to be a touch choice.
      10-04-2006, 07:14 PM   #10
ScBlacksunshine
144
well, you're compare apple to orange..good c/o is thousand times better then just springs along, they're design to do what they do best..perform. Now if you're comparing the same spring ad $1200 difference then it's a different story
      10-05-2006, 04:06 PM   #11
shragon
Moderator
shragon's Avatar
497
Drives: BMW
too much work involved in switching back and fourth. you're better off getting a set of coil-overs.
Search this Thread:
Advanced Search
