BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      11-05-2009, 04:13 PM   #1
JuniorM3
JuniorM3's Avatar
Ethiopia
134
Drives: BMW F13 M6 CP GT3
Arrow DIY: Brakepad Wear Indicator removal for on track
Race pads often don't come with the cut out for the brakepad Wear Indicator Sensor.
Racers that do some work on their own cars don't need the sensors anywaz...They suck, and the small metal spring that keeps it in to place gets lost or broken all the time! So let remove em'!
If you follow this DIY you WON'T get a warnin' on the dash that your brakes need service...ever again!
excuse my Iphone picas
It takes 10 to 15 min each corner.
Tools needed:
- Very small screwdriver
- Cutting Pliers
- Shrink sleeves or some electrical tape.
- Soldering unit (Not really needed)
Remove your Wheels to get access.
Front: New carbon composite brakepad without BWIS cutout (Yes, that's short for: Brake Wear Indicator Sensor )
Background: stock pad.
BWIS's
These are the sensor wires you'll be removing from your system.
To get the cable out, Remove the BWIS from your pad by pulling on it. And follow the line to your Shock.
You can push the cable out of the 'clamp'.
Now find this box.
Open it.
Get the cable out of the second clamp.
And pop the White (White on my Euro spec car, It's the top one) connector out of the box.
Pull the connector apart and open the connector (THAT IS STILL ATTACHED TO THE CAR!), and remove the black clip with a flat head screwdriver.
Almost looks like I'm black on the pica, your gonna get dirty with brake dust!
Apply quite some force on the two silver looking points with a really small screwdriver. After applying force the internal connectors are somewhat bent and this enables you to pull out the two wires for the top.
These wires come out.
Out of focus and moved....I'm a natural! But this is how the wires look like.
Cut the connector ends and nice rubber thingies off, twist the two wires that you have now stripped, together and if you have some time solder 'em together.
Tape up the newly soldered wires or use some heat slink sleeves like i did.
Put your new creation back in the box, close it.
DONE!!
Yes you can do this the easy way, by putting a piece of wire in the connector. But this is nice and it can withstand track use, it's reliable.
Good Luck!
F13 M6 CP GT3 | Mineral White | 20'' BC Forged Center Locks | Fully Loaded | JB4/Meth | Custom GT3 Widebody Kit + Aero | Catless DP/X-Pipe | Turner StrackSport Discs/Pagid Brake Pads |
      11-06-2009, 05:01 AM   #2
mastek
e36s54, e70x5d
mastek's Avatar
Drives: slow
Junior -- you have some great DIY's and your effort is certainly appreciated ....
Thank You
... and as a sign of appreciation --- we (@ m3post) want to get you a gift certificate to a 'mastering the digital camera' class, ... near you --- it would only benefit us.
Thanks again
      11-06-2009, 06:31 PM   #3
JuniorM3
JuniorM3's Avatar
Ethiopia
134
Thank You
Thanks again
Thank you guy's!
I'm on the West Coast Monday! KLM 601 AMS-LAX -> AA 162 LAX-LAS.
I'll take u up on that!
      11-06-2009, 06:42 PM   #4
JCtx
258
Drives: No BMW yet
Yeah, should have saved the bandwidth and skip the pics .
Hey, what exactly trips those sensors? Didn't see any metal piece, and you supposedly need to replace them if tripped. Do you actually have to replace all that cable? Just curious.
      11-06-2009, 06:50 PM   #5
JuniorM3
JuniorM3's Avatar
Ethiopia
134
If your brakepads wear and you get an service notification on your dash.
it's because one of these sensors is damaged/activated.
You need to replace the entire cable.
Or follow my DIY
Cheers
      11-07-2009, 04:53 AM   #6
Moxie
Moxie's Avatar
Drives: AW 328d Touring/SG 335d
Thanks!!
      09-22-2010, 01:48 PM   #7
1MORELAP
1MORELAP's Avatar
Drives: '22 911 GTS '19 X3, X5, X7
I do not get it. Why can't we just remove the sensor from the pad and zip tie it somewhere on the strut? Maybe I need to see it to understand better.
I apologize for spelling mistakes up front, they are a result of multitasking.
      09-22-2010, 02:51 PM   #8
elh0102
15
Drives: 2009 335i coupe
That's all you need to do. This seems to be a great solution to a nonexistent problem.
      09-22-2010, 03:01 PM   #9
JJM335
Drives: 2008 E92 M3
2008 E92 M3  [0.00]
Ditto. Just make sure you keep the little metal clips in case you want to put the sensors back on.
      09-26-2010, 09:25 PM   #10
leo95se
Drives: '09 e92 M3, '15 F15 X5d
thats what ive been doin. lets me easily pop it on for stock pads too.
      09-27-2010, 09:26 PM   #11
OzStriker
OzStriker's Avatar
Australia
61
Drives: Ford Falcon Ute, Ducati 1198S
My car has been counting down the kms to brake pad service...Does this remove this altogether or just remove another message saying pads need replacing?
BMW E92 M3 6MT, G-Power SKII supercharged, custom exhaust with 100 cell cats and Remus Sport mufflers, Brembo 380mm BBK, BMW Performance steering wheel, LUX H8 angel eyes, CF CSL boot, Hamann CF diffuser, Vorsteiner CF lip, CF grilles, CF gills, CF bonnet vents, BMW Performance stripes, RAC RG63 wheels, Eibach lowering springs, camber modifications.
      09-28-2010, 08:13 PM   #12
VictorH
433
Drives: '09 M3
No your car will still keep counting down to the next brake service. The wear sensors are really just for when your pads are so far worn that the wear sensor starts getting it's contact grounded out through the rotor. There's probably a DIY somewhere here to reset the brake service indicator.
      09-28-2010, 09:58 PM   #13
OzStriker
OzStriker's Avatar
Australia
61
Thanks VictorH.
I have researched the procedure for resetting the service intervals, available here:
http://www.e90post.com/forums/showthread.php?t=51049
However, for a successful brake wear/service interval reset you must replace the brake wear indicator assembly with a new one or you will get a warning saying the pads must be replaced, regardless of previous pad wear.
Does anyone know if the above procedure results in the same signal to the car as you would get when fitting a new brake wear indicator cable?
      10-02-2010, 03:37 AM   #14
BimmerRob08
BimmerRob08's Avatar
Drives: 2008 M3, Space Gray
what if I have a CANBUS II reader. Can I select and delete the brake sensor light with it, if and when it appears? I'll have my sensors zip-tied off also when I get my BBK installed.
      03-10-2012, 07:27 PM   #15
Dellort_M3
16
Drives: 2011 E92 M3
Is this method reversible?
2011 Alpine White/Fox Red 6MT E92 M3 | Active Stage 2 w/Meth | KW Clubsport | OSS | Challenge Front Lip | Vorsteiner Type 2 Rear Diffuser and Bootlid | Brembo | Recaro | Akrapovic Slip-On | Challenge Race+ X-Pipe | Vossen CV3 | OEM 359M | TE37SL
      03-10-2012, 07:31 PM   #16
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
good to know i just put in ds2500s this week and was wondering about the reset on my idrive for the sensor. as it turned out i needed to go in for something else to the dealership so they just reset my indicator. will do this mod next time though.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs|
      03-26-2012, 06:18 AM   #17
TomElektro
To drift is not a crime
TomElektro's Avatar
Germany
73
Drives: BMW M3 (E92)
Originally Posted by OzStriker View Post
Thanks VictorH.
Anyone know the answer to this?
      04-02-2012, 07:13 PM   #18
C2VNY
Monster unit
C2VNY's Avatar
43
Drives: Monster spec tme sold
So if you tie the sensors for bbk you'll still get the count down??
MONSTER UNIT M3 E90
GT4 - AKRA EVO - RECARO - AP RACING -
KW CLUB-SPORTS - VOLKS
      04-04-2012, 08:16 PM   #19
montreal red
chris
montreal red's Avatar
278
Drives: White Boat
to answer your question -> yes
i have tied down my brake sensors because i have a bbk installed. but i still get the count down despite the fact that the brake sensors are no longer connected to my brakes.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      04-23-2012, 12:28 AM   #20
Zzhou
Zzhou's Avatar
Drives: 2012 E92 SSII ZCP DCT
How to do the rear one? anyone?
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER
      04-28-2012, 08:52 PM   #21
Drifty//
Drives: A4 quattro 3.2 MT6; E92 6MT
There might not even be wear sensors in the rear. They're not as critical to safety as the front brakes.
My A4 had wear sensors in the front, but not rear.
      04-28-2012, 09:48 PM   #22
Zzhou
Zzhou's Avatar
We have one in the rear.
m3post
