Procede data log questoins
11-05-2009, 01:38 PM | #1 |
82
Rep 619
so i did my first data log run today. the boost was oscillating a lot and i have no idea that was normal. here is the logs, any help would be great. edit - forgot, i have stock air box (dci coming ) with the steet pipe and forge DV's and this was map 1
11-05-2009, 02:06 PM | #5 | |
1742
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
it also likes like you are are declitching before you lift off the throttle (see rpm spike at the end of the gear.) it would also help to add CAN dbw throttle to the datalog too. Any closures would explain the boost oscillation in the IC pipe. |
11-05-2009, 02:30 PM | #6 |
82
Rep 619
ill redo it in a little bit, ill add that one as well. yes i was shifting from 2nd into 3rd at the start and 3rd to 4th at the end. when i redo it ill just start in 3rd and floor it from 40
11-05-2009, 02:43 PM | #7 | |
1742
Rep 17,960
Drives: A Lot
Shiv |
11-05-2009, 03:17 PM | #8 |
Clearing the Way
Rep 175
Is the DTC off important? I did 3 logs today, one showed a timing correction around 6200 and another around 5300 rpm.
Temps here in Germany were around +45F 6 MT by the way. Running 9-9 stage 1 default settings. If I should take it to email let me know.
Jet Black E90 335i
SCTW! Mods? Maybe, Maybe not..... |
11-05-2009, 03:18 PM | #9 |
Team Zissou
3077
Rep 10,198
with DTC on the ecu can intervene which in most cases will skew the results (if it's cutting power due totraction issues etc).
11-05-2009, 03:22 PM | #10 |
Clearing the Way
Rep 175
I thought about that, but I never got the flashing DTC warning.
Although I would be seriously proud of my self if I could spin the tires at ~60 mph and 3k rpm. lol
Jet Black E90 335i
11-05-2009, 03:27 PM | #11 |
82
Rep 619
kk, so i went back and did it again from 3rd gear 2k till redline floored 100% of the time. dtc off fully. i think its better now, there is less oscillation in boost. is the peak supposed to go that high ( i know its when im shifting )
11-05-2009, 03:34 PM | #12 |
1742
Rep 17,960
Drives: A Lot
Looks perfectly fine. I see you re having a hard time keeping full throttle though
11-05-2009, 03:34 PM | #13 | |
208
Rep 9,339
Yeah, boost will spike like that between shifts when ur off the throttle.. it's normal |
11-05-2009, 03:43 PM | #16 |
82
Rep 619
thanks. just wanted to make sure that spikes that high were normal. i could have sworn i had it down the whole time. so if the engine ( and turbos ) dont see the spike im all good.
11-05-2009, 04:11 PM | #17 | |
1742
Rep 17,960
Drives: A Lot
Shiv |
11-05-2009, 04:58 PM | #18 |
65
Rep 1,708
couple questions as a 3rd party viewer trying to decide which to tune to go with...
1. looks like there's timing advance correction during part or no throttle after the run. Also some advance correction in the beginning after full throttle?? 2. what triggers the extra timing retard for shifting... based on throttle position? 3. CAN DBW throttle is actual TPS correct? Fluctuation in the beginning I would imagine is to control boost, but I thought boost was directly controled at solenoid? Cyruz, can you post the actual timing, or DME timing |
11-05-2009, 05:00 PM | #19 |
65
Rep 1,708
when i see procede maps, they are always in the above format, but you can export to excel and graph per various values right?? and the data point are around 10 to 20 per/sec??
11-05-2009, 05:18 PM | #20 | |
1742
Rep 17,960
Drives: A Lot
Shiv |
11-05-2009, 05:27 PM | #21 | ||||
1742
Rep 17,960
Drives: A Lot
Shiv |
