Peake Reset tool vs. BT Scan Tool
10-30-2009, 02:47 PM | #1 |
Rep 80
Anyone know the differences other than $140? All I need is something to read the factory codes and reset them if necessary.
Any thoughts are appreciated. |
10-30-2009, 03:30 PM | #4 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
10-30-2009, 11:54 PM | #5 |
62
Rep 380
Anyone use the Autoenginuity one? I have the BT tool (and PROcede), but some friends are thinking of getting the Autoenginuity tool for their E46 M3's.
10-31-2009, 01:15 PM | #6 |
Rep 80
Mike-
With all due respect, I don't think your statement is completely accurate. The Peake (http://www.peakeresearch.com/fcx3.htm) or Autoenginuity (http://www.autoenginuity.com/product...ware.html#EI07) are specifically designed to read BMW codes, NOT just OBDII codes. Admittedly, the Autoenginuity product is close to the BT in price. I am also not convinced that the Peake product will read everything the BT or Autoenginuity products will, but I can't tell for sure what the differences are. |
10-31-2009, 02:34 PM | #7 | |
4920
Rep 115,999
Using Peak's site I wasn't able to find a model they suggest is compatible, and until you test it against a BT to see if it can clear hidden codes, etc, it's a risk. If they have a return policy give it a test and report back. A few months ago you would have needed to spend $3k on a fake GT1 system to clear these codes so $287 VIA a BT is quite a bargain. http://www.peakeresearch.com/prodsel/index.php mike |
11-01-2009, 10:38 AM | #8 |
83
Rep 985
Drives: 08 M5 Sapphire Black
Doesn't sound promising
They mention compatibility with "most" bmws up to 2007. Since the E90/E92 has not changed from 2007 to 2008 why would the tool not be compatible with 2008+?
11-01-2009, 10:49 AM | #9 |
32
Rep 867
Actually isnt that the period in which BMW migrated from the MSD80 to MSD81?
Not only will it kill you it will hurt the whole time while you're dying.
http://www.stevesnovasite.com/ http://www.jalopyjournal.com/forum/ http://www.garagejournal.com/ |
11-01-2009, 08:29 PM | #11 |
83
Rep 985
Yes, but some 08s got MSD80. The switch to MSD81 happened halfway thru
03-18-2010, 05:19 PM | #13 |
23
Rep 1,179
03-19-2010, 06:46 AM | #14 |
103
Rep 2,783
I am leaning toward peake, can't justify almost double the price. Especially when I found this http://www.e90post.com/forums/showthread.php?t=360706 to easliy reset CBS (oil, plugs, etc.)
05-28-2011, 07:12 PM | #17 |
74
Rep 1,543
Mega Bump!
Just bought the Peake R5-FCX product: http://www.peakeresearch.com/fcx3.htm Quick review: I got it from www.eurosportdesign.com/. $139 shipped via 2 day. Excellent product! I was looking for an alternative to the BT scan tool, which was rather expensive. I didn't want a used one either, which would have restricted me to just two Vins. My car is an '07, so luckily It can be scanned using the peake product. Yesterday I did a quick scan and found 4 codes. 1 HPFP, 2 Vanos solenoid, and 1 oil analyzer. The product can real and clear ALL BMW codes, is portable, compact, and does not require a PC. It also isn't restricting me on Vins. IMHO, its a perfect alternative to the BT product. Only downside is if you have an 08-2011 Bimmer. Last edited by Turkeybaster115; 05-28-2011 at 07:17 PM.. |
05-29-2011, 09:23 AM | #18 |
103
Rep 2,783
Thanks for the update Turkey!!!! I am leaning toward peake too. I wish it could reset/register the battery.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
