10-30-2009, 12:21 PM | #1 |
265
Rep 1,696
FS: JL Audio e6450 (6-Ch. Amp, 660 W RMS)
I have a JL Audio e6450 6-Ch. Amp, 660 W RMS for sale. It came off of my old car and is in excellent condition. I have the original box, which I will include with owner's manual. Serial number on box matches serial number on the amp.
I am not willing to ship at this time. We can meet up at a centrally agreeable location and time somewhere in Houston, TX. Here is a link to the owner's manual: http://mobile.jlaudio.com/pdfs/eSeries%20Amps/e6450.pdf Price is $220. Cash only. Thanks for viewing. GENERAL SPECIFICATIONS: RecommendedFuseValue: 60A Recommended Fuse Type: AGU or MaxiFuseTM INPUT SECTIONS: No. of Inputs: Three Stereo Pairs Input Type: Differential, noise-cancelling with RCA jack inputs (low-level, three pairs) and multi-pin jack (high-level, two pairs) Input Range: 200mV - 8V RMS AMPLIFIER SECTION: AmplifierTopology: ClassABwithpatentedAbsolute SymmetryTM dual N-Channel MOSFET output design Power Supply: Unregulated MOSFET switching type Rated Power (Stereo): 45WRMSx6@4Ω(12.5V) 75WRMSx6@2Ω(12.5V) Rated Power (Bridged): 90WRMSx3@8Ω(12.5V) 150W RMS x 3 @ 4Ω (12.5V) THD at Rated Power: <0.08% @ 4 ohms per channel (20Hz-20kHz) Signal to Noise Ratio: >104 dB referred to rated power (A-weighted, 20 Hz-20 kHz noise bandwidth) Frequency Response: 10 Hz - 25 kHz (+0, -1dB) Damping Factor: >200 @ 4Ω per ch./50 Hz, >100@2Ωperch./50Hz Slew Rate: ± 22V/μs AMPLIFIER FILTER: Filter Type: State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50-200 Hz. Configurable as Low-Pass or High-Pass. Defeatable. DIMENSIONS (LxWxH): 17.7" x 9.25" x 2.36" (450mm x 235mm x 60mm) |
