Gasoline Octane?
09-26-2006, 03:37 PM | #1 |
Rep 124
Gasoline Octane?
General question for you guys.
Would you say (for any engine, not just BMW) that higher octane gasoline gives better mileage? Perhaps so much so that it is CHEAPER overall to pay more for higher quality gasoline (because you get better mileage). Thanks.
0 car accidents provoked 4 other cars to crash pulled over by cops 12 times 2 tickets!!! |
09-26-2006, 03:49 PM | #2 |
82
Rep 432
The general theory on this is No. Not worth it. Just put the minimum required.
ED Trip - April 2015: SO F82 M4 Link to Trip Report
ED Trip - Jan. 2007: BS E92 335i Link to Trip Report |
09-26-2006, 04:34 PM | #3 | |
3596
Rep 10,358
No. As a general rule of thumb high Octane fuels are needed for high compression engines. Using lower ocatane fuels in these types of engines will cause the engine to retard timing, loose power, get worse mileage (a couple of mpg). Low compression engines (most american cars for example) would not benefit unless they are older engines. |
09-26-2006, 05:17 PM | #4 |
89
Rep 3,011
that being said, using the 87 vs. 91 will save you maybe 100.00 per year. I think using the higher octane helps the car run better, and it's worth the hundred bucks for my (maybe erroneous) piece of mind.
"Teach the ignorant. Ignore the stupid."
09-26-2006, 05:19 PM | #5 | |
105
Rep 1,181
Drives: G29 Z4 M40i Roadster
You're absolutely right |
09-26-2006, 05:31 PM | #7 | |
31
Rep 799
Bottom line, its $100/per year that you are throwing away. Instead, send it to me. PM me for paypal info. |
09-26-2006, 05:41 PM | #8 | |
pull my finger to get your kinder® surprise
148
Rep 10,455
for some odd reason, we dont have 94 in Ontario's Petro Can stations
09-26-2006, 05:42 PM | #9 |
89
Rep 3,011
we don't have CANADIAN gas in AMERICA...
i really don't have any idea what my point is....
09-26-2006, 06:26 PM | #10 | |
96
Rep 761
I remember in Michigan, getting 94 octane from Sunoco. Stuff was great. But I probably didn't need it for a Ford F-150...
09-26-2006, 06:45 PM | #11 | |
111
Rep 1,772
A BMW engine will be CHEAPER over all if you run it on higher octane fuel (unless boosted with ethanol). If you read the standard features, you will see "Cylinder specific knock control" in the engine category... what that means is that the computer will detect the Octane level of the fuel you are using and will advance or retard the ignition timing based on this. Higher Octane will allow the computer to advance timing more without getting knock and hence allow you to get the more optimum burn you are looking for. This will improve your fuel economy (not to mention the engine's perormance) to the point where you will at least recover the extra cost of the premium fuel (usually like 7 cents per liter) or come in a little cheaper. So, you at least break even on the fuel cost and on top of it, you get the cleaning solvents/additives included in Premium fuel which will save you money in the long run in the form of reduced maintenance costs. IT IS CHEAPER. Other engines... you will only benefit from improved gas mileage and performance with higher octane gas if the car has knock control or if you go to the trouble of adjusting the ignition timing to take advantage of the premium fuel. These are the facts. |
09-26-2006, 06:49 PM | #12 | |
111
Rep 1,772
09-26-2006, 07:36 PM | #13 |
201
Rep 6,381
Funny you should say that. I ran a couple of tanks of 91 V-power and it felt like the engine was the old E46er...Emptied it out and then refilled it with 94 and POW!!!!
Neuron your revised sig pic is funny!
09-26-2006, 07:55 PM | #14 | |
45
Rep 1,738
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
09-26-2006, 07:55 PM | #15 | |
148
Rep 10,455
man, I'm missing out on the good stuff then!:mad:
09-26-2006, 07:58 PM | #16 | |
45
Rep 1,738
09-26-2006, 07:59 PM | #17 | |
45
Rep 1,738
But you get a lot of Canadian oil. No point here either.
09-26-2006, 08:58 PM | #20 |
415
Rep 5,767
well, from my experience in race cars, a higher octane gasoline will run the engine at a cooler temperature, resulting in more horsepower (the change is minimal) i always like the best for my car, so i normally would use the highest octane i can find. Higher octane gasolies also burn much cleaner (less pollution), lasts longer, and promotes your engine to be cleaner. Lower octane gasolies have a tendency to build up grime on your intake valves, which can restrict air flow into the motor (resulting in less HP). But if you want to use the 91 im sure it will not be a problem, here in Miami i always use 93. sometimes 100 if i can get my hands on it at the race car shop. you also dont want to go too high. It mostly depends what you want your car for: everyday driving, or performance. everyday you can use 91 no problem, but for performance go with the 94 94=
09-27-2006, 09:08 AM | #21 | |
111
Rep 1,772
Maybe the maxima and the volvo don't have what is required to fully take advantage of premium or maybe you just pushed them harder when you used it. |
09-27-2006, 10:04 AM | #22 |
23
Rep 972
Drives: people mad
The funny thing is higher octane fuel has a lower energy density, so the lowest octane fuel that allows for optimum ignition timing will produce the most power.
So old nail engines work best on 87 and very high compression engines (e.g motorcycles) work best on 93. Best to use whatever fuel octane rating the manufacturer recommends. They don't specify premium lightly because they know that a segment of customers is turned off by the need to pay more at the pump.
__________________________________________________ __________________
2006 BMW 325i, Jet Black, 6MT, ZSP, Black Leather, Aluminum, Power Seats, Logic 7 |
