windsheild wiper problem..
10-18-2009, 01:09 PM | #1 |
30
Rep 55
wipers just stopped working out of no where one day...
anything i can check before replacing motor? im sure there are some fuses or relays that could be bad ? anyone have similar problems or anyone have any info on replacing the windsheild wiper motor? thanks for any input its an 06 e90 sedan |
10-18-2009, 01:13 PM | #2 |
149
Rep 2,383
Well, I could find the fuse box (behind the glove box), but the instructions say to remove the glove box and I couldn't figure out quite how to do that without possibly breaking it. Maybe there is a DIY on it, I will do a search.
10-18-2009, 01:41 PM | #3 |
30
Rep 55
ya i know where fuse box in glove box it...just dont know what fuses or relays to check...and is there another fuse box or relays in trunk or under hood ?
10-18-2009, 01:52 PM | #4 | |
149
Rep 2,383
So the wiper symbol indicates 01, 50 and 79. But then the fuse box diagram indicates two wiper symbols in the upper left hand corner, maybe these are relays. |
10-19-2009, 09:10 AM | #7 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
^^ true and if no fuses are blown then motor issue most likely
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i ProGaMeR on the XboX 360 |
10-19-2009, 10:55 AM | #8 |
Rep 303
The glove box does NOT have to be removed; however a section of it must be removed (designed for removal - very easy - slips off). Once off the fuses are visible. There's a sheet of paper, folded and clipped to the fuse block that indicates the circuit for each fuse. It's cryptic, but eventually understandable. There's also a pair of forceps there to assist in fuse removal, as well as a few spares.
ElRedOne
330 xi Electric Red/Beige Step-Premium-Sport-CW-CA-PDC-Shade Z4MR Interlagos/Black |
10-19-2009, 12:01 PM | #9 |
30
Rep 55
thanks...are the wiper ones relays or just fuses? ...
just glove box?..any other fuse boxes under hood or anywhere? anyone replaced motor?? ....im being lazy and havent even poped hood and tried to look under there..i think i rembember it being pretty basic on my e36 ... |
10-24-2009, 12:24 PM | #12 | |
149
Rep 2,383
To the OP, like I said I don't know if it is the same in an 06 and I have no way of finding out, but there appear to be two relays in the upper left corner of my diagram which have Windshield wiper symbols on them. You really need to get a diagram of your fuse box, maybe from the dealer or a cheap manual in an autoparts store. |
10-24-2009, 12:25 PM | #13 |
149
Rep 2,383
10-24-2009, 01:07 PM | #14 |
30
Rep 55
ok have the paper...need to go to the dealer for these relays or can i jus go to auto parts store to test some new ones before ordering a motor?
11-11-2009, 09:33 PM | #16 | |
149
Rep 2,383
Since you did replace the motor, it probably wasn't the motor. Then it is likely the switch, the power line going to the switch, or the line going from the switch to the wiper motor. Well that's my best guess. |
03-19-2010, 07:17 PM | #17 | |
52
Rep 361
So, did you get this resolved? I am having the same...
...problem, and I discovered my trunk won't open either. I checked the fuses but the diagram and so forth is darned confusing. It appears there is no fuse where they say it should be. And why the trunk? There isn't a fuse for that. I even tried using the release button in the glove box to no avail. |
