DIY - How to Disable e92 Seatbelt Assist arm
09-25-2006, 01:19 AM | #1 |
23
Rep 127
A) For those who dont like to read directions: Take out the seatbelt fuse
B) For others who want a detailed directions, read below: FIRST: Do this in the daytime for more light. Press in the key (do not press Start Button) - radio should come on, AND Seatbelt Assist. 1) Open the glove box and get out the flashlight. Take notice of both knobs at the end of the glove box. This is the fuse box. 2) Twist both knobs 90 degrees 3) Take the small paper diagram of the fuses out. 4) Look for the seatbelt icon with the number 25 beside it 5) Turn the small paper diagram over to the fuse map and find the location of Fuse 25 6) Take the fuse installer out and find the 10amp fuse in spot 25 7) Take the fuse out and store it in a safe place if you need to replace it. 8) Put the fuse installer back in the fuse box and close the fuse box cover. Make sure the twist knobs line up before closing the glove box. Last: Press in the key - radio should shut off. Press in the key - radio should come on, but NO Seatbelt Assist. Important Notes: A) I took the car out and DID NOT put on the seatbelt, the chime for the seatbelt still comes on. B) I am not 100% certian if this effects the airbags. I know that some cars passenger airbags will not come on if there is no one in the seat at the time of impact. Due to taking out the fuse, this might deactivate the sensor in the seat, but I am not sure... with that said, use at your own risk. |
09-25-2006, 03:52 AM | #2 |
35
Rep 1,169
Drives: 67 GT500,69 Boss 429, 335i
Great Post!!! Thanks very much - they look so fimsy I can't wait to get my car just to disable them! Thanks again.
Mat |
09-25-2006, 04:02 AM | #3 |
‘Viva Espaρa!
373
Rep 7,803
And they look cheap.
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
09-25-2006, 06:33 AM | #4 |
126
Rep 590
Drives: 2023 Chevrolet Corvette C8
Wow! Thnx for the help!! i know u saved alot of people from having to repair that in the future..
09-25-2006, 07:58 AM | #7 |
148
Rep 481
Drives: 2007 335 e90 1998 e39 540
Garage List 2023 BMW i4 m50 [0.00]
2020 BMW M340 [0.00] 2018 mx3 40 [0.00] 2016 340 [0.00] 2013 BMW ACYIVE HYB ... [0.00] 2010 BMW X535D [0.00] |
Before I did that I would find out if taking out the fuse disables the airbag. Who knows if you KILL your passenger what YOUR consequences may be. Accidents happen and technology is there to help us out but you will have to live with yourself not to mention possible legal problems.
09-25-2006, 08:42 AM | #9 |
95
Rep 1,018
Drives: 2014 BMW M5
thanks for the great info! The seatbelt assist actually doesn't bother me that much... but when it does i'll know what to do!
09-25-2006, 08:45 AM | #10 |
Judge Advocate General
99
Rep 1,128
Drives: e92 335i
Thank you for your great post!!!!!
'07 E92 335i "Over-Heating" and "Blowing Up" since 9-5-06 6MT, Space Gray, Gray w/ Dakota Leather, Dark Burl, ZSP, ZPP, ZCW Comfort Access, Sirius Satellite (Howard is not optional) '07 X3 3.0si - Black on Black, ZPP, ZCW, Step. - Wife's car |
09-25-2006, 08:56 AM | #11 | |
Shadow Warrior
139
Rep 2,095
Great post though
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods: PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar Installing soon: Rear Power Outlets (Happy Robot mod!) |
09-25-2006, 09:05 AM | #12 | |
Clutch pedal >> Dead pedal
18
Rep 709
Drives: '11 e92 335is 6MT
My hunch is that the airbag system would not be affected, since I believe the system looks for a certain amount of electrical resistance from each airbag, and alerts you if there's a problem. That was my experience from my '00 328, which had to have an airbag replaced. OBC kept generating fault codes because it wasn't detecting the driver airbag properly. But that's just a hunch - I agree that I'd prefer to have a concrete answer as to what fuse 25 really does! Still a good find by the OP tho
In my garage: '11 e92 335is 6MT (05/10) SpGrey/CoralRed/GlacSlvr ExecPkg/NavPkg/19" 225M
Retired: '07 e92 335i 6MT (12/06) SpklgGrpht/CoralRed/GreyPoplar Retired: '04 330Ci M-Sport 6MT SilverGrey/NaturalTan/MyrtleWood Retired: '00 328Ci 5MT SteelGrey/Grey/MyrtleWood Retired: '87 Pontiac Grand-Am 3AT White/Grey |
09-25-2006, 09:55 AM | #13 |
23
Rep 127
When I took Fuse 25 out, I drove around the block and noticed that the seatbelt chime came on (because I wasn't wearing my seatbelt), So it definitely detected me (without giving me the belt). Therefore the proper airbags should work because the seat knows there's a person in it.
09-25-2006, 11:26 AM | #18 |
I want to drive a Zamboni
1129
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
This mod is crazy and unsafe.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
09-25-2006, 11:57 AM | #20 | |
61
Rep 616
09-25-2006, 12:11 PM | #21 |
7
Rep 307
I doubt that Fuse 25 does anything except handle the butler. If the butler is broken or damaged in such a way that caused the fuse to blow it would then disable other safety system - that seems pretty stupid plus NHSTA would not be too happy about that. Also, because the butler give you the belt does not mean it know you put it on which makes no sense for the safety systems.
I assume there is another system under the seat for the air bag as required by new regs and that the seat belt clicker has another sensor and the belt butler is completely out of the safety loop. The fact that chime still plays tells me that safety systems have detected that you do not have your seat belt on. I don't believe pulling the fuse will cause a problem. The only problem that remains is covering up the arm so that nobody tries to pull it out but hand like a toy and breaks it. Truely, the belt butler is a piss poor feature and hope it goes away in MY08. |
09-25-2006, 01:14 PM | #22 |
23
Rep 127
/\ You are totally right.
Fuse 25 only works the electrical mech for the seatbelt assist. Nothing more. It's just like taking out a rear wiper fuse, sunroof fuse or power window fuse. When there is no fuse, the specific part simply does not work. |
