335i turbo upgrading
09-24-2006, 06:48 PM | #1 |
58
Rep 1,075
Hey guys, Im paymon and i just sold my M3 3 days ago, and im picking up a 335i blk/blk 6speed comming in next week (excited) but yea... Im curious does anybody know how much lbs the turbo's pull at on our 335's? and if any software is being planned for release and how much more torque and hp will it add?
Just curious I hope ill be cool with all of u guys, the forum seems tight :rocks: I kinda miss the E46 like crazy |
09-24-2006, 06:56 PM | #2 |
33
Rep 1,770
Nothing has been released yet but check out this thread http://www.e90post.com/forums/showthread.php?t=31110
Glad to see another 335i owner and congrats on the purchase!
2006 330i Steptronic/Alpine White/Black Leather/Burl Walnut Trim/Premium Package/iDrive/Heated Seats/Winter: STYLE 159 Blizzak LM-22 RFT/Summer: TBD
2004 X5 Steptronic/Alpine White/Grey Leather/Poplar Trim/Premium Package/Heated Seats/iPod Adapter |
09-24-2006, 09:01 PM | #3 |
55
Rep 960
mubarak
09-24-2006, 09:27 PM | #4 |
32
Rep 205
I believe they push about 8-9psi max. The compression is pretty high on these engines so extremely high boost applications are not a good idea without internal work
Seth |
09-24-2006, 09:44 PM | #6 | |
58
Rep 1,075
intercooler? I'm newb with turbo cars etc. never thought i wud buy 1 |
09-24-2006, 10:30 PM | #7 |
missing two turbos.
574
Rep 4,859
Drives: fast around corners.
m_bazeepaymon, FMIC is not an internal work to be precise. You should really start reading some tuning 101 stuff if you don't know much about forced induction. Don't even think about touching those turbos until you learn more about it. I heard 335i pushes 3~5psi for partial throttle and 9psi at wide open throttle. Vishnu is working on a chip that pushes more boost pressure even at partial throttle and possibly raise the boost up to 13psi or so for WOT condition. Expect 40~70hp increase.
but good bye warranty once you upgrade. so if you do upgrade, all the maintenance will be up to you. its a good idea to know what you are doing. alot of newbies just slap on turbos on high compression motors, blow the crap out of it and wonder what the mechanics at the shop who installed it did wrong. e92328i998, do you happen to know what the compression ratio is for the 335i engine application? I hope its below 13:1.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
09-24-2006, 10:32 PM | #8 | |
58
Rep 1,075
Im hoping Dinan can come out with something (i hate dinan thanks to the M3 reputation it gave) but i am on a lease, and Dinan is the only tuning company that can work on my car... Just want a lil push to take the M3 from 0... Thanks for the input guys |
09-24-2006, 11:05 PM | #9 |
35
Rep 1,169
Drives: 67 GT500,69 Boss 429, 335i
Hopefully shiv's XEDE will be able to get around the safeguards and there will be no way for the dealer to tell it was ever there... If there is a problem take it out and the warranty still works. Hopefully!
Mat |
09-24-2006, 11:08 PM | #10 | |
Borti
Rep 114
09-25-2006, 11:29 AM | #11 | |
58
Rep 1,075
And does anybody know where i can learn all about my 335 engine etc... or do i just search through threads
ZzZzZ'er |
11-05-2006, 12:18 AM | #13 | |||
Borti
Rep 114
So the 10.2:1 compression ratio means that the A/F mixture has been compressed to 1/10th its size (its 'original size' being at bottom dead center of compression cycle and its 'fully compressed' size being at top dead center of the compression cycle). The higher the compression ratio the more pressure that is put on the mixture inside the cylinders. Higher pressure equals more power (to a point), but higher pressure also equals higher temperatures, and the compression ratio found in the 335 is far too high for a conventionally turbo-charged engine. That is one of the key benefits of direct injection. DI significantly lowers the cylinder temps by actually cooling the cylinder walls. DI also allows for a much more accurate control over the A/F ratio because the fuel is injected into the cylinder itself rather than further upstream in the intake manifold. These two factors allow for a higher compression ratio which does wonders for power ( again, to a point) and, of course, throttle response. Hope that didn't sound silly!
11-05-2006, 01:01 AM | #14 |
From Russia With Boost
36
Rep 1,076
Quite a good explanation actually. thumbsup.
2007 BMW 335i - Delivered 9/8/06
Sparkling Grpahite with Black Leather/Aluminum Trim Premium Package, Sports Package, Comfort Access. |
11-05-2006, 09:56 AM | #15 |
Streifenden Komet
9
Rep 120
Drives: 525i was a 325is
more shiv action
Here you go Shiv has come a long way since the link on page 1
http://www.e90post.com/forums/showth...028#post517028
"Drive like you live" CFBA:rocks:
335i will be the new turner car for this decade! If it's a bimmer, it's badass. It's more fun to drive a slow car fast, than a fast car slow; F- That just go to driving school and you can do both. |
11-05-2006, 01:16 PM | #16 | |
149
Rep 2,419
M3 ~330 BHP vs. modded 335 ~330WHP M3 ~260 ft-lb vs. modded 335 ~345 ft-lb Now, the question is that with the total package of the M car and 160 lbs less wt., whether or not the e46 M3 is fast enough to hold up with the modded 335 in the real life. Let the track or street race answer that.
It's a great time to be alive
11-05-2006, 02:10 PM | #17 | |
118
Rep 390
Drives: '16 M3, Lotus Exige S260
_Scott |
