Shock Options for e90 xi
09-12-2006, 11:03 PM | #1 |
Modeldater
22
Rep 641
Ok, So I've been trying to find new shocks, preferably Koni adjustable or something similar. However, there doesn't seem to be any options out there for the xi. Does anyone have any options or know of anything that I don't.
Any info would be awesome! Since I lowered my car on H&R sports (330xi), it just doesn't ride the same and I'd like to get the correct rate shocks for the springs so that it takes bumps better. |
09-13-2006, 01:12 AM | #2 |
Get a grip. Get Xdrive.
14
Rep 529
Drives: 330xi
I'm thinking it may be a while. Koni only just released front shocks for the E46 Xi within the past year.
2006 330xi current
09-13-2006, 01:18 AM | #3 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
NSM, I thought 18LLC posted something about Bilstein's set? Check it out. Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
09-13-2006, 06:16 PM | #4 |
Modeldater
22
Rep 641
Seems like Bilstein has an option for their Pss9, but isn't that coilovers and not just shocks? I'm calling them tomorrow to get the real story. I'll update when I find out.
09-13-2006, 07:43 PM | #5 |
148
Rep 5,104
check this out
http://e90post.com/forums/showthread.php?t=24375 didn't have chance call them to confirm. good luck with that.
09-13-2006, 07:44 PM | #6 |
361
Rep 5,859
Drives: Vorsteiner E60 M5
Location: 1460 White Oaks Rd. Suite F. Campbell, CA 95008
Koni does not make a shock for the E90 xi at this time
Bilstein, however, does make a PSS9 dual adjustable coilover system that will work with the E90 all wheel drive. It's more expensive, but right now it is the only option! Contact us for pricing. JL |
09-13-2006, 07:57 PM | #7 |
148
Rep 5,104
with pss9 suspension, do i still need to buy the lowering spring for the car? the spring should come with the shocks, right? how low will my car go? max to min. thanks.
09-14-2006, 12:43 AM | #8 |
361
Rep 5,859
The suspension comes with EVERYTHING you need. Shocks, Spring hats, springs... everything.
The car will lower a minimum of about 1/8" and a maximum of about 1.5-2" I believe. JL |
09-14-2006, 12:14 PM | #9 | |
148
Rep 5,104
09-14-2006, 03:43 PM | #10 |
361
Rep 5,859
Bad news guys. The coils are available, and I can offer great pricing on them, but they do NOT fix the xi as the website indicates
JL |
09-21-2006, 01:21 AM | #13 | |
chamras
Rep 41
Drives: BMW 320iSE
PSS9
Threaded Suspension (height adjustable) Gas Pressure Fitting Position Front Axle, Lowering 30-50 mm, To axle load 1000 kg Fitting Position Rear Axle, Lowering 30-50 mm, To axle load 1200 kg It come with Springs and shocks |
09-21-2006, 01:28 AM | #14 | |
chamras
Rep 41
Drives: BMW 320iSE
BTW, you should check first about PSS9. After I installed mine it got some noise on the front suspension when go over a bump. Not sure if the noise was from the springs or not (front pair only) maybe metal to metal. I would prefer for you to check out KONI with EIBACH, or other brand. You should check with the shop first if they have any noise problem after it is installed. I have noise though. I heard it good for smooth condition road not too bumpy like Autoban in Germany or the highway in the U.S. In my country there is alot of pot holes and bump. (not suitable for PSS9) but it provide very smooth ride and firm grip. Very nice..... |
09-21-2006, 10:35 PM | #17 |
195
Rep 4,163
10mm = 1cm. an inch is roughly 3.2cm
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005 |
09-22-2006, 07:14 PM | #18 |
14
Rep 529
Drives: 330xi
Conversion is 1 inch = 25.4 mm
2006 330xi current
09-23-2006, 04:28 PM | #19 |
195
Rep 4,163
oops.. i remember that on a ruler 3 cm is either a lil more than an inch or lil less than an inch
09-23-2006, 04:45 PM | #20 |
14
Rep 529
Drives: 330xi
Uhaulball, did you get your springs yet?
2006 330xi current
09-23-2006, 05:17 PM | #21 |
195
Rep 4,163
09-24-2006, 02:17 PM | #22 |
361
Rep 5,859
What did you end up paying for the springs? I'm 90% sure we will match or beat it for everyone else (I can upload this product to the site if it's something you guys want to order!)
JL |
