      09-01-2009, 06:51 AM   #1
135iellis
Drives: 135i Le Man Blue
Auxillary input Volume
Hi
new 135i owner.
i noticed when using an ipod with a 3.5 mm jack that the volume did not go as loud as when using the normal cd player or the radio.
i could not find any specific volume setting for the aux input apart from the drive faster setting which is on full anyway
the ipod is also turned up to full
does anyone know if there is a setting for the aux input volume ? whether its part of the i drive menu that i can access or whether its something bmw can do ?
thanks
      09-01-2009, 08:19 AM   #2
Lester
295
Drives:
Check the Aux input volume, there is an input volume for the Aux port in the Audio Settings screen when listening to Aux devices.
      09-01-2009, 08:32 AM   #3
135iellis
hi
could you tell me exactly which screen this is on ?
sorry to be so dumb about this but bmw also mentioned the aux input volume but i cant find the setting anywhere
      09-02-2009, 02:08 AM   #4
drumglynn
Drives: 135M coupe
aux volume
Hi, with your ipod on, press button on radio which has a musical symbol on.You will eventually get to aux volume having gone through bass,treble,balance etc.You can then press button to increase volume.
      09-02-2009, 05:40 AM   #5
Lester
295
Drives:
In the non idrive setup, it is right on the radio display, AUX-VOL when using the AUX port, You just press the button and adjust the volumn from 1 - 5.
      09-08-2009, 05:36 AM   #6
135iellis
thanks guys for the reply
cant for the life of me find it so i am going to print off your replies and sit with them in the motor and see if that helps ! lol
just for clarity Lester, when you say the non i drive set up, do you mean without using the screen at all ?
or do you mean when you press the button straight down and it opens up the settings menu ?
      09-08-2009, 08:29 AM   #7
Lester
295
Drives:
Right on the radio display - just above the selection buttons - when you are playing through the AUX port - the middle button displays AUV-VOL - if you press the button, you can adjust the input volume from 1 to 5.
      09-10-2009, 12:18 PM   #8
135iellis
hi lester
i am starting think i dont have the same equipment in my car that you have
i have the dvd equipment for the sat nav
above that is the cd slot
on the cd players is the FAV buttons and the volume control
i do not have a radio display apart from on the i drive screen itself where you can move to whatever radio channel you want
so when you say Radio Display, are you talking about on the I Drive pop up screen or a completely different piece of equipment ?
      09-10-2009, 02:47 PM   #9
Harry135
7
Drives: BMW 135
Aha! I think Lester was talking about the buttons on a non-idrive radio as I have in my 135.
I'm guessing there will be an option som place in an idrive menu for the aux input volume...sorry can't help further as I don't have idrive.
      12-03-2009, 03:05 PM   #10
pavelitto
pavelitto's Avatar
20
Drives: 135i Performance
Have I-drive 09 and couldnt find it as well...
135i Performance
