BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d Turbo Questions
      08-30-2009, 07:08 PM   #1
kcgman
Burning the midnight oil
kcgman's Avatar
Drives: 2009 335d
I'm a new BMW 335d owner. Bought the car two weeks ago and still going through the break in process (<3500 RPM and under 93 mph). Even at under 3500 rpm the car really seems to move. I'm looking forward to getting past the 1200 mile break in period. I have two questions about the turbos on the car.
1. When do the turbos kick in? I've put the car up to 3200 rpm (quite accidentally) while merging into highway traffic when two trucks had me in an awkward spot. The car accelerated VERY quickly at that point and probably engaged one of the turbos -- but in truth I don't know. Since then, I've been below 2500 rpm.
2. I've read that I shouldn't engage the turbos until the oil temperature in the car is warmed up. Unfortuantely, the 335d doesn't have an oil temperature gauge. I've heard different things about how long it takes to get the oil to its proper temperature. My question is, "What harm is done (if any) if the turbos are engaged when the oil temperature is cool?" I've been told by two different dealers two different things. The first said, "It's bad for the turbos." He wasn't specific, but it made me a bit paranoid. The other dealer said, "The turbos won't be very responsive when the oil is cool, but it doesn't do the turbos any harm. If that was an issue, the BMW engineers would have built in fail safe to prevent damage." That second answer seemed plausible to me, because it would seem pretty silly to remove the oil temp gauge if doing so put the turbos at risk. Anyway, I'd love to hear from someone who knows what the issue is/isn't.
Thanks in advance.
      08-30-2009, 11:08 PM   #2
Insider
Insider's Avatar
14
Drives: 2007 335i
The turbos kick in as soon as you step on the gas to accelerate. There is no way not to keep the turbos from spooling when accelerating up to speed.
http://www.insiderpicks.com - The world's best stock picks.
      08-30-2009, 11:47 PM   #3
kiwistu
New Zealand
32
Drives: Black F82 M3
Hi
I have a 335d, turbos go the whole time, I would certainly follow the guidelines re run in, however don't get too paranoid.
My car definately warms up, but very quickly, I always use the heater as a guide if your getting hot air in the cabin - its warm, and then I give it a few more minutes, however the good news is with a 335d its so powerful you hardly need more than 3000 rpm...
Cheers
stu
      08-31-2009, 11:04 AM   #4
Xipher
Drives: 2016 X5 35i
I believe with the sequential turbos, the smaller turbo is almost always going at the lower RPMs, then as you continue to speed up and get to the higher RPM's, that's when the second, larger turbo kicks in, giving you the quick acceleration you felt.
      08-31-2009, 11:48 AM   #5
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
+1, BMW has been using this sequential setup in their diesels for a few years now.
      08-31-2009, 03:32 PM   #6
R1200RT
R1200RT
R1200RT's Avatar
Netherlands
Drives: BMW 335d (E90)
2009 R1200RT  [0.00]
2009 E90  [0.00]
Originally Posted by kiwistu View Post
Hi
Cheers
stu
I don't think the heater is a reliable source, since that uses the cooling fluent. IMO oil temp should be OK before you start to push.
It was explained to me that valves in the cooling system make sure there is a short circuit that heats up quickly and enables the interior to warm up soon after drive off. It than gradually lets in fluent of the bigger circuit until all of the fluent is at operating temp.
Considering that my dealer didn't bother to tell me to run it in and since there are no gauges for water and oil temp, it soes not seem terribly important to BMW. Probably because it is such a torquee engine and nobody has a need to high rev it under normal road circumstances. You can be very quick without high reving.
Bottom line: it's a theoretical issue.
335d E90
R1200RT K&N/Power FRK/black cylinder heads/Corbin /BMW Navigator IV/Baehr
      09-01-2009, 02:40 PM   #7
kcgman
kcgman's Avatar
Drives: 2009 335d
Thanks for the responses. My sense is that no one has heard of any issue with engaging the turbos prior to the oil getting to temp. To the extent that the turbos are engaged at any time the car accelerates, it would suggest that the turbos are fine when the oil is cool.
      09-01-2009, 07:46 PM   #8
Insider
Insider's Avatar
14
Drives: 2007 335i
What they probably meant, as with the 335i, the car does not reach full boost when the oil is cold. Therefore, you won't be making full power on a cold engine.
      11-29-2022, 12:58 PM   #9
nictobin
nictobin's Avatar
7
Drives: 2009 BMW 335D
Thanks in advance.
the turbos spool and "engage" as soon as the engine turns on. there is no way to prevent that.
      11-29-2022, 07:14 PM   #10
lnxguy
357
Drives: 2009 335D
13 year old thread bump, impressive.
'09 335D
Appreciate 2
B58557.50
POBEP364.00
      11-30-2022, 12:27 AM   #11
POBEP
POBEP's Avatar
Drives: E70 E90 E91
There has been quite a spike of new accounts created recently and posing for real ... most of the time nothing useful in the post body, 1 or 2 sentences.
Feels like new form of AI bots to me.
Or, maybe, twitter is not cool anymore .. so they come here.
      11-30-2022, 03:18 PM   #12
Nadir Point
Nadir Point's Avatar
103
Drives: Diesel
I always meant "spooling" to be when the turbo comes up to speed in the fat part of their map under load. AI needs go back to bot training.
      11-30-2022, 06:06 PM   #13
335dlci
277
Drives: 335d
Lol
