rear brakes.. is this normal?
08-06-2009, 02:43 PM | #1 |
Cunning Linguist
147
Rep 2,219
I just had my rear brakes replaced by the dealer and now it seems like the brakes don't cover the entire disc like it should. This is after driving in the rain for 60 mins.. you can see the part where the brake pads cover and is covered with rust.
Bottles are for babies, Real men get blown.
08-06-2009, 02:45 PM | #2 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
No def not normal! I have never seen that before.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
08-06-2009, 02:46 PM | #3 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
Weird, take it back to the dealer.
08-06-2009, 02:48 PM | #4 |
505
Rep 35,580
Drives: JB 33ZERO
Looks like wrong pads, make sure they replace your rotors now, you are gonna have a hella nice wear line in those! If you do not replace rotors they will wear pads wrong, gl.
08-06-2009, 02:50 PM | #5 |
Cunning Linguist
147
Rep 2,219
f**King dealer!
08-06-2009, 02:51 PM | #6 |
505
Rep 35,580
Drives: JB 33ZERO
08-06-2009, 02:58 PM | #7 |
1821
Rep 5,337
Before you jump to conclusions, I've seen wear like this on new pads installed on used rotors.
By the way, it's practically IMPOSSIBLE for the dealer to install the wrong pad. Most of the pads BMW use have rather unique backing plate and there's practically NO WAY to install a wrong set of pads since the backing plates won't fit. For example there's no way I can install, say, an E46 323Ci rear pad on an E92 328i front brakes. Just not possible. And if there happen to be some cross model compatibility, like E46 330i front brakes and E46 M3 front brakes, the pad backing plate would be the same and hence the amount of pad sweep area would be similar as well. |
08-06-2009, 03:54 PM | #8 |
Rep 70
I thought BMW always changes rotors and pads together? I'd definitely bring it back and have the dealer take a look at it.
Currently Driving: E90 335i
Coming From: E39 2003 540i Sport |
08-06-2009, 03:57 PM | #9 |
4 pot warrior
37
Rep 1,307
pads are sat in wonky.
This can happen if the discs have a altered profile due to uneven wear. But that looks just like other sets ive seen poorly fitted. The pads are not seated correctly, and are burning in at an angle
Been there, done that, wanna do it again |
08-06-2009, 08:27 PM | #11 |
2024 M440i GC (G26)
278
Rep 511
Fairly normal. The pads have to bed-in and adapt the shape of the old rotor. Look closely at your rotor, you'll see it's more worn toward the inside edge. You can also have your rotors turned if you need to help this.
08-07-2009, 09:58 AM | #13 |
Smiling politely
165
Rep 7,931
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
08-07-2009, 11:39 AM | #15 |
4 pot warrior
37
Rep 1,307
probably not,
Ive seen a Z4 with the exact same disc pattern, and after a change of pads, it was gone. Trust me, the pads are in wrong
08-07-2009, 12:00 PM | #16 | |
1821
Rep 5,337
08-08-2009, 07:48 AM | #17 |
Cunning Linguist
147
Rep 2,219
08-08-2009, 08:06 AM | #19 |
Rep 207
Wow. that doesnt look right.
2007 335i Coupe Jet Black / Black Leather / Aluminum / Steptronic w. Paddles / Premium / Sport / CA / Navigation / Satellite
08-08-2009, 10:31 AM | #20 | |
2024 M440i GC (G26)
278
Rep 511
The consequence of a too-thin rotor is warpage if overheated. If it does warp - and that's a big IF - then you would compromise the brake system and stopping performance. And if it does warp, you'll know it pretty quickly (pulsing through brakes), and then you just change the rotor which you'd have done anyway. I've turned the rotors on my BMW 335 and Mercedes SL500 and they've been fine. No warpage at all. The dealers may not turn the rotor, but almost any independent brake shop will. |
