Does anyone's comfort access act up?
07-31-2009, 05:56 AM | #1 |
1705
Rep 14,829
Such as when you pull the handle, the car doesn't know what to do, so it unlocks and then locks, or it just tries to do both and makes a clicking sound? Trunk doesn't open all the time, windows don't want to go down when the button is held down on the fob.
All kidding aside, I was told the above is normal by the dealership. I don't think they were trying to be funny, I think they were saying it was working as well as BMW designed it. Of all the push to start rental cars I've had, none of them exhibited anything unusual. I almost would have to suggest people don't order comfort access, but if it's standard on an Altima, one would expect to have it on a BMW, otherwise the push to start is stupid.... |
07-31-2009, 06:32 AM | #3 |
72
Rep 941
I get the trunk not opening thing occasionally, and that's usually when I'm trying to show off to someone lol. Apart from that, I haven't had any other issues.
07-31-2009, 07:30 AM | #6 |
866
Rep 5,450
Mine works great never seen that - only issue I have is the trunk sometimes, but usually I have the key in the pocket furthest from the car, I just have turn closer to the car and it will work - probably looks like I am humping my car! (I do love my car)
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-31-2009, 08:18 AM | #8 |
208
Rep 9,339
trunk does it for me once in a while too... i notice i'm usually standing too close to the car. If i go to open the trunk standing almost an arm's length away, it works every time... go figure!
07-31-2009, 08:42 AM | #9 |
152
Rep 3,983
Are your windows tinted? That will interfere. It does with mine sometimes. Also, make sure you don't have your keys in the same pocket as you cell phone or any other junk that would get in the way. Try grabbing the door handle a little 'softer' then usual, helps for me. My trunk almost never works.
Just out of habit, unless my hands are full I usually just unlock and lock the car with the fob. I find locking it the worst, and I usually end up just standing there looking like a jackass jamming my thumb on the ridges. Faster to lock it walking away anyways. The only real great part is not having to insert the key, so the push start isn't redundant. That alone is worth it. |
07-31-2009, 08:45 AM | #10 |
36
Rep 1,361
+1
Once in a while if I am too far away from the car and the car is started, I will get a No Key sign (mine is very sensative), but otherwise I have no issues with the key fob and controls.
2016 F10 535 xDrive Msport Alpine White -Current
2014 F10 535 xDrive SOLD 2009 E90 335i SOLD 2007 E92 6MT SOLD |
07-31-2009, 09:25 AM | #11 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
mine started to act up after about a yr and a half
07-31-2009, 09:28 AM | #12 |
142
Rep 3,161
No issues except the trunk, I find you need to keep the FOB a little further away for it to work, go figure.
2018 F80 M3 6MT ZCP
07-31-2009, 09:29 AM | #13 |
BlackBerry King
41
Rep 184
Drives: 2009 BMW 335i
Could be a weak battery in you FOB.
2009 BMW 335i /6 SPD Fully Loaded Saphire Black on Black Dakota Leather |
07-31-2009, 09:36 AM | #14 |
1705
Rep 14,829
I'm getting the distinct feeling that it's not normal for my driver's door to lock as I'm trying to pull it open. The question is how I'm going to get it fixed without getting into a shouting match with the dealership. They claimed it's normal and that they contacted BMWNA who backed them up. Maybe try a different dealership and start over? I just don't want things breaking out of warranty when I mentioned it under warranty...
07-31-2009, 10:22 AM | #15 | |
335
Rep 2,385
My 325i doesn't have CA and I don't use his car unless I can't use mine or my wifes so it could be my error not using the system enough. But I'm pretty confident I know what I'm doing so it must be the car. It's rather sporadic and nothing he felt like addressing. He isn't keeping his car for a long time either so as long as it works most of the time he doesn't care.
retired 06 E90 325i New: 09 VW Platinum Grey Jetta Sportwagen 2.0T SEL w/DSG, panoramic sunroof and Ipod adapter |
07-31-2009, 10:32 AM | #16 |
27
Rep 1,306
Mine acts up too. Every now and again you should put the key fob in the ignition. This seems to make it work properly for a while. I also get the battery replaced once a year.
Train with your head; not above it.
07-31-2009, 11:45 AM | #17 |
Where'd my VTEC go?
481
Rep 6,067
Mine works fine. Maybe not 100% of the time but most of the time. Like everyone else, the trunk seems to give the most trouble. I've never had it try to lock when I go to open the door though.
07-31-2009, 11:48 AM | #18 |
679
Rep 5,382
i hate how i can roll down all the windows but i cant roll them back up with the fob
07-31-2009, 11:49 AM | #19 |
Smiling politely
165
Rep 7,931
+1 Mine is 3 years old, has never had any quirks. I'd take it in for a look.
A couple of times, the trunk hasn't worked on the first try if I'm standing in some weird way like way off to the side, but getting closer and trying again worked. Mind you, this is less than a handful of times for a car I've driven daily for 3 years.
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
07-31-2009, 11:52 AM | #20 |
Smiling politely
165
Rep 7,931
FWIW, the car actually warns you of a low battery signal in the comfort access fob. On mine that I use daily, it took over 2 years for the warning to pop up, and other than the warning, I'd never noticed the battery was low. YMMV of course. I seem to have had better luck with CA than others have. It's a definite "must have" on any future BMW I get.
07-31-2009, 11:53 AM | #21 |
137
Rep 1,914
My CA works PERFECTLY, 85% of the time. But the other 15% is really frustrating. It would be nice if BMW could somehow refine the technology to get the glitches out of the system.
07-31-2009, 01:25 PM | #22 |
12
Rep 113
Mine is kinda funky. Sometimes I grab the handle and the doors unlock, sometimes they don't, sometimes I have to pull the handle twice, etc... seems like there is no set way to get the doors to unlock with the comfort access that works 100% of the time. The door locking method should just work for unlocking too if the doors start out locked. Simple as that.
