long crank - dealer cannot replicate. Advice?
07-28-2009, 03:45 PM | #1 |
Rep 49
I have an e92 with 31k on it - manual sports package. I've noticed that after sitting overnight (regardless of weather), it takes about 2-3 seconds for it to start up. After it warms up its not an issue. Additionally, during the first hour or so, it will have a very rough idle.
The dealer had it overnight while doing scheduled maintenance and claimed they were unable to replicate the issue. The car has just had the microfilter and oil replaced, and still no effect. Anything I can check or do myself? I am no mechanic but I am thinking clogged fuel lines or something requiring an oil/fuel additive to be poured in? I haven't done anything, just wanted to get your opinion. |
07-28-2009, 04:08 PM | #2 | |
12
Rep 301
07-28-2009, 06:02 PM | #3 |
Rep 77
Thats exactly what happen to my car..it started out with 2-3 seconds of cranks..took it to the dealer and they could not do anything about it since it didn't throw any type of codes. A week or 2 later..even longer cranks and my service engine light eventually popped up. It was a HPFP failure. Recording the long cranks is not going to help and dealers are not going to replace it until something actually fails.
07-28-2009, 06:08 PM | #4 |
122
Rep 6,594
It's unlikely they're going to replace anything unless something is actually broken or throwing errors. Long cranks are certainly a sign the HPFP might be going, but until you hit limp mode they won't be replacing it.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
07-29-2009, 10:14 AM | #6 |
28
Rep 946
Fuel pressure regulator? My car is going in friday for the same issue - I will update once they figure it out.
07-29-2009, 02:46 PM | #8 | |
189
Rep 609
2019 Z4 sDrive 30i Msport,
Previously owned BMWs, 2014 428i Msport, 2008 335i Coupe, 2007 328xi sedan, 2002 325i sedan 1996 318ti (loved this little car) |
07-29-2009, 03:49 PM | #9 |
former N54 owner
11
Rep 607
SIB 125506. I knew it well.
+lemon
07-29-2009, 05:22 PM | #10 |
60
Rep 2,014
Its not the dealers that play this game, its BMWNA. Before the dealer can replace your hpfp under warranty your car has to throw codes of a failing fuel pump. Until then the long cranks will get you nowhere at the dealership.. Unfortunately its the way it is..
07-29-2009, 08:12 PM | #11 |
189
Rep 609
Yes, exactly just looked on my service order
07-30-2009, 02:52 AM | #12 |
8
Rep 286
It's both...If no fail code throw, they will open a PUMA case and go form there. They replaced injector/lines/adjust pressure test everything they can on my car for 3 weeks before changing the freaking HPFP!
07-30-2009, 08:00 AM | #13 | |
31
Rep 376
Check out - http://www.e90post.com/forums/showthread.php?p=5599690 If you're tired of BMW jerking you around, then you need to do what other members are doing. |
08-01-2009, 10:15 PM | #14 |
28
Rep 946
Haha guess what the problem was . HPFP is being replaced, I did get a 335d loaner with 2 kms on the odo. This car has so much torque, lets just say I got a ticket within the first hour of driving this thing!
08-01-2009, 10:59 PM | #15 |
8
Rep 194
Yeah unfortunately the dealer won't do anything unless the HPFP totally fails or throws a code.
My car is experiencing the long cranks again and I took it in since I had a long trip ahead and don't wanna get stranded. They had my car for about an hour and gave it back to me, saying no code, no go. Sucks that you have to be basically stranded for them to do anything abot it. |
08-01-2009, 11:04 PM | #16 |
679
Rep 5,382
yeah happens to me almost every morning i go to school.
