Xenon High beam part help
07-27-2009, 09:37 PM | #1 |
28
Rep 487
I need a Xenon highbeam light blub for a e92 328i. I looked on the Getbmwparts.com website, and there are multiple light bulbs, not sure which one it is : /.
Help regarding this will be greatly appreciated!
Current - 2017 Porsche Macan Turbo
Current - 2010 BMW E92 M3 Retired - 2008 BMW E60 M5 Retired - 2008 Audi B8 S5 Coupe Retired - 2007 BMW E92 328i |
07-27-2009, 09:57 PM | #2 |
Where'd my VTEC go?
481
Rep 6,067
xenon high beam shares the same bulb with the xenon low beam. which is a D1S HID bulb.
07-27-2009, 10:26 PM | #3 |
28
Rep 487
this is the one that could be turned on and off, and its in the center of the outer ring ya?
07-27-2009, 11:50 PM | #4 |
Where'd my VTEC go?
481
Rep 6,067
wait are both your low beams working? the same bulb is used for low and high beam. its just a metal shield that moves up and down to switch the projector between low beam and high beam mode.
07-28-2009, 12:13 AM | #5 |
28
Rep 487
nope the low/high beam on one side isn't working, so I'm assuming its the bulb. there's a light on the dash that said lighting bulb failure. The thing is that I can't seem to find the part number, becasue I'm not sure what part it is
07-28-2009, 12:39 AM | #6 |
Where'd my VTEC go?
481
Rep 6,067
Yeah, thats the D1S xenon bulb then. See if you can get the dealer to cover it under warranty, since xenon bulbs are supposed to have super long lifespan.
If they're not going to cover it, the dealer is going to charge an arm and a leg for a xenon bulb (~$250 USD). You can get a used one on ebay or something for cheaper, or go aftermarket and change both bulbs out to whiter/bluer ones while you're at it.
07-28-2009, 01:15 AM | #7 | |
28
Rep 487
07-28-2009, 01:27 AM | #8 |
Where'd my VTEC go?
481
Rep 6,067
tischer? they should sell it. part number is 63217162862 obtained from here http://www.realoem.com/bmw/showparts...61&hg=63&fg=05.
not sure what the procedure is, but changing the bulb shouldnt require removing the bumper (maybe have to go in though wheel well though), so it shouldnt be too difficult to change it. $450 is insane... sounds like you got a used headlamp from somewhere? you should try swapping the bulbs between the two sides to make sure its actually the bulb and not the ballast that's dead.
07-28-2009, 01:47 AM | #9 |
189
Rep 5,046
On my sedan there are 2 different high beams. If you push the stalk forward so it stays on it is the HID high beam. If you pull it back its a halogen high beam.
07-28-2009, 01:49 AM | #10 |
Where'd my VTEC go?
481
Rep 6,067
E92 has a cornering light instead of a halogen high beam.
07-28-2009, 10:51 AM | #11 |
189
Rep 5,046
07-28-2009, 12:20 PM | #12 |
148
Rep 1,728
The reason it is $450 dollars is because the dealership might be swapping out both of them like they are supposed to. This way in 2-3 years you wont have one purple headlight and one blue and xenon bulbs tend to color-shift after some time.
Its still way overpriced anyway from the dealer!!!! |
07-28-2009, 05:58 PM | #14 | |
860
Rep 35,253
07-29-2009, 01:41 AM | #15 |
28
Rep 487
do you guys offer any?
07-29-2009, 10:02 AM | #16 |
860
Rep 35,253
07-29-2009, 11:53 AM | #17 |
70
Rep 316
Drives: X1, i3 BEV
wait are you referring to the flash-to-pass bulb (pulling on the stalk) or the actual high beams (pushing on the stalk)???
