need help on Bilstein PSS9 on the E90
08-29-2006, 10:53 PM | #1 |
chamras
Rep 41
Drives: BMW 320iSE
I have just installed Bilstein PSS9 onto my E90, it is the 2005 BMW 320i model with 1998cc. After installed by Bilstein Technician, the rear seem to feel much better than the stock shock and Spring. But for the front suspension, it seem to have some noise when go over a bump, like those bump they have on the road to prevent you from driving fast in residential area etc. It have this click sound like metal hitting a metal. Yes, the shock were installed properly. So...yesterday I went back to the shop and they removed the front pair of shock again and check for problem. They found no problem at all, so they disassembled them and check for problem. There were no problem at all so they put them back on. The sound seem to be solved but only a little noise can be heard when go over a bump a little too hard or too fast. I am not sure if this sound is normal if your car is lowered about 3-4 cm. from it original height.
Do anyone have any experience with this kind of thing, any help and advice would be very much appreciated. |
08-29-2006, 11:40 PM | #3 |
chamras
Rep 41
Drives: BMW 320iSE
yes..... i have the 2005 320i model, E90 6 A/T
09-12-2006, 10:45 PM | #5 |
Borti
Rep 114
There is a lot of metal to metal contact in the PSS9 suspension kit. Put some electrical tape in the spring perch mounting point and other areas in the front driver's side to help alleviate the sound when contact occurs.
09-12-2006, 11:37 PM | #6 |
chamras
Rep 41
Drives: BMW 320iSE
Bilstein PSS9
Thank you......will try your method
09-14-2006, 12:14 PM | #7 |
195
Rep 4,163
how much did u guys spend on the pss9
'06 bsm e90 330xi : 18" VMR CSL : KW V3 : GruppeM Rep Intake : UUC/Corsa Catback : Hartge Lip : ACS Roof Spoiler
OEM CF Trunk Spoiler : CF Emblems. Pillars. Mirror. Grille : LUXER12 led plate : V1 Hardwired : OG.longtran e90post sticker! circa 2005 |
09-21-2006, 01:16 AM | #8 | |
chamras
Rep 41
Drives: BMW 320iSE
PSS9
10-08-2006, 01:22 PM | #9 |
56
Rep 1,962
I used to have a set of pss9's on my gti and what it sounds like is the springs moving on the perches. Its completely normal..
Peanut Butter Chunky
