Would it make any difference if I got my oil changed at the mechanic?
07-21-2009, 03:24 AM | #1 |
Drive till Infinity
33
Rep 118
I need to get my first oil change done (I bought a used '07 and the last oil change was when I bought it from the dealer--they took care of it)
I've looked at DIY oil changes and it doesn't sound too complicated, but would it make any difference if I just took it to the mechanic? Would I need to supply them with my own oil (Mobil-1, or similar). If they use their own oil, will they know to use synthetic oil? Is it relatively safe? Do they change the oil filter and get a new one, like I would have to if i changed my own oil, or do they keep the old one? I know its a mechanic were talking about here, and quality really isnt their top priority, but how much quality will I lose if I have it done at the mechanic? |
07-21-2009, 05:12 AM | #2 |
Where'd my VTEC go?
481
Rep 6,067
are you out of the warranty period already?
BMW has a list of oils that should be used if not using their own brand. You will most likely need to buy your own oil and filter and have them do the labor if you wanted a mechanic to do it, unless you go to a BMW specific shop and they stock BMW approved oil and filters. changing oil is simple and any mechanic can do it. its just a matter of if they have the required oil and filters. but whatever you do, dont go to those quick lube places.
07-21-2009, 05:29 AM | #3 | |
Drive till Infinity
33
Rep 118
07-21-2009, 06:29 AM | #4 | |
36
Rep 1,361
2016 F10 535 xDrive Msport Alpine White -Current
2014 F10 535 xDrive SOLD 2009 E90 335i SOLD 2007 E92 6MT SOLD |
07-21-2009, 06:37 AM | #5 |
1705
Rep 14,829
I don't think it would matter, but while the car is under warranty I'd prefer that the BMW dealership does it.
My strategy would be to pay for one, get the other free, every 7500. But their policy is very confusing, even the SA can't explain it. That and whether or not the red service light should be off or on when you have low miles. |
07-21-2009, 07:47 AM | #6 |
866
Rep 5,450
I would take in my own oil and filter if it is a non-bmw specialist as they will probably not stock the correct stuff, if it is a independent BMW shop, then ask them as they may have it all.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
07-21-2009, 08:09 AM | #7 |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
I just buy BMW oil and Filter and put in myself. The service reset is easy.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
07-21-2009, 10:08 AM | #9 |
17
Rep 415
Go getcha a free oil change! but if you do take it to a mechanic it isnt a bad idea to bring your own oil and oil filter. (depends on mechanic really) some guys put oil straight out of a refillable drum which accumulates debris at the bottom of it, which is where the oil nozzle ends to draw up the oil from the drum. SO you could very easily be having a mechanic pumping a whole bunch of crap into your car. just so you know
07-21-2009, 10:21 AM | #11 |
322
Rep 17,316
Drives: E92 M3, E30 325i
Just do it yourself.
Just b/c you have warranty doesnt mean you can go into bmw whenever you want and ask for an oil change. You have go by what the car status says in your idrive/screen. It'll tell you how many miles till and oil change. You may get the oil change if you're close to that mark, but it usually doesn't hit till about 15K miles depending on how you drive |
07-21-2009, 10:23 AM | #12 | |
7478
Rep 10,120
07-21-2009, 10:51 AM | #13 |
One cam is enough
130
Rep 6,801
Last time of the many times I've been in for service, there was a lady there who had brought her car in for an oil leak. The SA came out after they had evaluated it and told her that the shit wasn't put together right and they know they didn't do the oil change because there was a Korean filter in there. Man, he was condescending, but it was pretty funny.
I guess they don't like you doing oil changes with Korean filters. That's the only advice I have. Oh, also make sure they put the car all the way back together. |
07-21-2009, 04:13 PM | #15 |
13
Rep 1,187
You can have it done anywhere. But:
1. Use the right parts. Oil with BMW LL01 approval and the correct filter. 2. Keep the receipts. If you don't want any warranty questions down the road you need to be able to show that the correct oil went in. 3. If your mechanic does not care about quality you need to find a new mechanic. There are good ones out there, but the relationship does not start with "how much do you charge to....". |
07-26-2009, 03:15 PM | #16 |
Drive till Infinity
33
Rep 118
Thanks. I think the safest bet is to simply change it myself. I was looking at Oil filters online, and came across this : http://www.bavauto.com/lview.asp?img...27541827_2.jpg
Is this a decent one? Which brands or make (if any) should I look for. By make, as in, Made in ________.
Drive till Infinity | '07 Jet Back 328i | Sport-LESS ._. |
07-26-2009, 08:22 PM | #17 |
Where'd my VTEC go?
481
Rep 6,067
just get BMW oil and filter.
Tags |
mechanic, oil change |
