Switching from JB+ to JB3..
07-06-2009, 05:53 PM | #1 |
104
Rep 919
Well I just got my JB+ a few days ago and I set it to max and did the solenoid bypass right away and I really felt the power difference. It will break the tires loose all the way through 1st gear, and jump out sideways spinning the tires into 2nd gear..but I still have stock 225's so that is somewhat expected. Fourth gear pulls very hard all the way up until 130mph when the STUPID damn no good limiter kicks in!!!! But it's just a tease when the JB3 is out there and there is more power to gain. My main reason for buying the JB+ was because it is very easy to install/un-install before going to the dealer for service. But the JB3 PnP doesnt look like it would take much longer and for the amount of power I will gain I think 20 min of my time is worth it.. So JB3 it is!
07-07-2009, 01:58 AM | #5 |
104
Rep 919
07-07-2009, 10:02 AM | #6 |
professional assassin
17
Rep 207
It can take more than 20 min, just be warned.
There is something to be said for the ease of install/uninstall on SSTT and JB+
2008 E92 335i---AW/CR/Grey Poplar
07-07-2009, 10:03 AM | #7 |
161
Rep 7,377
first time took me 1 hour.. take your time when you do the install..
07-07-2009, 03:07 PM | #9 |
The limit of adhesion is my home.
1702
Rep 3,778
i had the JB+ and its a negligible gain, if any at all, at past 75% on 91 octane. At the higher settings you would need higher octane to feel the benefit.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
07-07-2009, 06:01 PM | #11 |
32
Rep 414
Last time, 11 minutes to remove JB3 and 12 minutes to put after dealer visit.
Very easy install/uninstall
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB3 2.0|Unlocked 18ohm Board|BMS Meth Kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP |BMS DCI|AA Exhaust|Helix fmic|CDV|H&R coilover| 10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, 11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph at 10.18
