Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > New Clutch w/ Dinan Flywheel
      07-03-2009, 06:39 PM   #1
RonPaul4Prez
Drives: BMW 335i coupe
My stock clutch failed catastrophically on me the other day after my jb3 install (map 6 on 93 octane). I drive my car like I stole it ('07 with a little over 50,000 miles ), so I'm not terribly surprised.
So, I'm replacing my clutch and flywheel with a ClutchMasters FX300 unsprung kevlar clutch and hd pressure plate in addition to blowing my wad on a Dinan lightweight dual mass flywheel for my 335. Throwout and Pilot bearings are being ordered through BMW. I think the setup will work fine, but considering the $ that the components are costing me, I'd appreciate feedback on any problems I may run into, particularly with my clutch selection that can be addressed now before the install.
I'm already running jb3 and dci, dp's along with a slew of other mods to be ordered soon. Anyone have experience w/ windowed/segmented kevlar (particularly unsprung)? Anyone have experience with the Dinan flywheel?
      07-04-2009, 08:33 AM   #2
RonPaul4Prez
bump. Anyone think ceramic is the way to go?
      07-04-2009, 09:00 AM   #3
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
I don't know about going ceramic, but I can't beleive you would drop $2500 on the Dinan flywheel - all they do is take a stock flywheel and machine it down to loose weight - costs them basically the cost of a stock flywheel and about $200 of machine time. You might want to find a good performance machine shop and have them just lighten your stock flywheel for about a zillion less!
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      07-04-2009, 01:16 PM   #4
vase330
vase330's Avatar
Drives: 19 E63S; 15.5 RangeRover ATB
I am not an expert, but I'd leave the flywheel alone. The lighted flywheel is unfortunately weakened too. Be ware of that. If it warps under abuse (you seem to drive the piss out of it anyway), you will be in a world of hurt soon enough.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
      07-04-2009, 01:49 PM   #5
ar design
ar design's Avatar
Drives: 04 M3
The Dinan flywheel is just an OEM piece with holes drilled in it. Major rip-off. Stay away from ceramic clutches, they EAT flywheels for lunch. Unsprung wont be as much of an issue with the dual mass flywheel.
-Critter
      07-04-2009, 02:09 PM   #6
Dr_Dirt
Dr_Dirt's Avatar
Drives: E90 335i 6AT
The lightened flywheel might take some practice to not stall your engine when starting from a stop...
      07-04-2009, 04:19 PM   #7
ybbiz34
ybbiz34's Avatar
670
Drives: 2023 330i M Sport
I'd rather have a modified OEM flywheel than some piece of crap that makes a bunch of noise.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV
Gone: '20 W205 C43 Sedan
Gone: '18 W205 C43 Sedan
Gone: '13 W204 C63 Sedan
      07-04-2009, 09:04 PM   #8
RonPaul4Prez
Thanks to some of those that had some constructive comments. However, to those others that feel the need to knock someone's purchase of a performance part, I was simply looking for some input on whether that particular line of kevlar clutch with pressure plate would be sufficient for a car with 400 - 450 lbs of torque. There is really no need to debate the merits of buying the flywheel. Regardless, whether it passes or fails the cost benefit test in your own perspective doesn't matter to me, as it is to ONLY aftermarket dual mass flywheel available right now for the 335i which should contribute to performance gains. Anyway, anyone here even use a kevlar clutch?
      07-05-2009, 01:17 AM   #9
ar design
ar design's Avatar
Drives: 04 M3
The billet flywheel in my car is pretty nice, not exactly a piece FWIW, Modified dual mass flywheels can have some serious issues.
Should work just fine for you.
-Critter
