Oil change after warranty expires?
07-02-2009, 01:17 PM | #1 |
11
Rep 68
Guys,
Would you recommend to follow the 15k miles oil change interval when it's out of warranty? It seems a bit too much to me, it seems like BMW was trying to save on their free maintenance, no? thanks. |
07-02-2009, 01:27 PM | #3 |
13
Rep 1,187
A search will find many threads on this subject, all of which turned into heated debates.
There are two major schools of thought; to follow the BMW system or to cut in in half (oil changes at 7500 miles). In any case you should be using oils with BMW LongLife 01 approval. Commonly these are oil from the dealer, Castrol Syntec 0W-30 or Mobil 1 0W-40. NOT Castrol or Mobil 1 5W-30. Also consider the other fluids. Transmission, differential and coolant. |
07-02-2009, 01:36 PM | #5 |
New Lifetime Replacement Policy
818
Rep 11,738
We have oil service kits available here on the website:
http://www.ecstuning.com/BMW-E92-335...aign=postreply |
07-02-2009, 02:10 PM | #6 |
90
Rep 2,707
Under or over warranty I change my oil at 10K intervals, and plan on doing it all the way to 300,000 miles. By this time I am sure the car will be a rust bucket but the engine will run as smooth as it did on day 1.
zhpregistry.net - ZHP stats and free classifieds.
07-03-2009, 11:57 PM | #10 |
Rep 244
DIY and do it every 7500 miles and use either BMW OEM 5w30 or Mobil1 0W40. An LL-01 ACEA3 oil is what you need.
You might know me from E46Fanatics.com |
07-04-2009, 12:00 AM | #11 | |
46
Rep 591
I do my oil changes every 6000km or so........ EFF what BMW says.......
SG | Coral Red | 6MT | Sports Pkg | CA | PDC | KWV2 | Dinan Stage II | Morr VS8 | Aero Lip |
07-04-2009, 12:07 AM | #12 |
98
Rep 3,618
+1 I only do the equivalent of about 8000 miles a year, so annually works quite well for me.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
07-04-2009, 10:43 AM | #13 |
90
Rep 2,707
Whoever assured you of that is a mean mean person.
07-04-2009, 12:56 PM | #14 |
Rep 317
i will stay with my 2.5K interval as always since i was told that was the best. i only use the best oil like quaker state or penzoil which are very american and ive used since the 60s. ive also been told to not use synthetic since its not real oil
07-04-2009, 01:23 PM | #15 | |
Dictator
55
Rep 1,811
The first years of its life are the important years. But going to a shorter schedule is still a good idea, imho. fwiw, I change at 7.5k despite mfg's suggestions. |
07-04-2009, 01:29 PM | #16 | |
Dictator
55
Rep 1,811
For Dino oil, use stuff like Kendall Racing Oil which is no longer made or Brad Penn which is available and comes from the same pool in PA that Kendall came from. http://www.lnengineering.com/oil.html |
07-04-2009, 08:06 PM | #17 | |
90
Rep 2,707
07-04-2009, 08:52 PM | #19 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
I personally trust the cars diagnostic system, I mean synthetic does go up to 25k miles in some studies, depending on climate and driving conditions.
But I dont race mine or drive it to hard so I will see when I get flagged for a change, It just had one b4 I bought it used.
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i ProGaMeR on the XboX 360 |
07-04-2009, 10:52 PM | #20 |
221
Rep 4,279
I don't think my BMW Dealer charges me what he does and then uses anything other than the Manufacturer Recommendation. I know it isn't strictly necessary (it isn't an Evo/STi) but i don't mind.
07-05-2009, 01:02 AM | #21 | |
Chicks dig wagons!
43
Rep 1,375
Drives: 2009 E91
Location: Where you can see through the people, but not the air (i.e., Los Angeles!)
E91 Montego Blue gray leather burl walnut , Idrive, PDC, Logic7, CA, Sirius, xenons, 6FL, ZPP, heated seats, 17" tires.
4, 8, 15, 16, 23, 42 |
07-05-2009, 01:50 AM | #22 | |
11
Rep 68
How about the other fluids (as someone mentioned earlier). Transmission, differential and coolant have never been changed. What schedule would you recommend? The record only shows brakes fluid changed at 45k-ish. Thanks. |
