TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Engine break-in period?
      06-30-2009, 10:05 PM   #1
bmwnoy
11
Drives: 335i Coupe, 335i Sedan
Question Engine break-in period?
How many milages does it take for an engine to fully break-in?
Also, will the gas milages increase afterward?
      06-30-2009, 10:12 PM   #2
ybbiz34
ybbiz34's Avatar
670
Drives: 2023 330i M Sport
I don't know if you have tried this yet, but a quick search of the forum will most likely yield a plethora of information discussing break-in theories/beliefs/recommendations.
Some will suggest taking it easy for the first 1,200 miles or so, following any manufacturer-related break-in recommendations, while others will suggest a "hard" break-in that requires you to drive the car like you stole it.
I prefer the hard break-in method. If you go this route, just make sure you allow everything to warm up properly (including tires) before you start getting aggressive.
Welcome to the forum.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV
Gone: '20 W205 C43 Sedan
Gone: '18 W205 C43 Sedan
Gone: '13 W204 C63 Sedan
      06-30-2009, 10:37 PM   #3
MrChessy
Magical Pill...
MrChessy's Avatar
Drives: wreckless
+1
      06-30-2009, 11:59 PM   #4
cbad335
cbad335's Avatar
Drives: '09 E92 335i
Originally Posted by MrChessy View Post
+1
I, on the other hand, suggest that you follow the break-in period instructions explicitly stated in your manual.
| 6MT | ZSP | ZPP |
      07-01-2009, 01:25 AM   #5
cali_guy
20
Drives: 17 MW M4 DCT
Drive it like you stole it!
      07-01-2009, 01:34 AM   #6
ViperJPB
ViperJPB's Avatar
Drives: 2009 E90 335i
2009 E90 335i  [0.00]
I followed the manuals break-in instructions and took the time to let the car warm up and down before starting and stopping. I let the cars rpms drop to 700 before putting her in gear. I officially passed break-in a few weeks ago and I'm glad I was patient. Been driving aggressive and in DS a lot ever since. Waiting to pass 2000 miles before doing in WOTs though.
2009 E90 335i 6AT / Procede / Vishnu DCI / Space Gray / Oyster Dakota Leather / Light Burl Walnut /
/ Sport, Premium, Cold Weather Pkg / Paddle Shifters / iDrive / Logic 7 / Park Distance / Comfort Access / iPhone Port/
      07-01-2009, 02:58 AM   #7
persian54
persian54's Avatar
Drives: M760/G83M4
i shifted early, didnt floor it, and didnt go above 90 mph until i hit 1250 miles
manual says 1200, i say follow it
      07-01-2009, 03:09 AM   #8
roozie2001
Just some guy
roozie2001's Avatar
Drives: 2008 White 335i sedan
drive it hard
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
      07-01-2009, 07:44 AM   #9
ianthegreat
60
Drives: n54
When you drive it off the lot -- it's broken in.
      07-01-2009, 07:53 AM   #10
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
today's engine dont need brake in. just warm it up before pushing it.
      07-01-2009, 05:07 PM   #11
shifterboy45
shifterboy45's Avatar
23
Drives: 2009 335i Coupe
its surprising how the comment differ on this subject.. maybe that is what the OP is asking.
i have built many engines in my time, rangiing from low horsepower 4cylinder to tire shredding big blocks and i have to say, a reasonable break-in period is OK .. but if your wondering if it necessary? -- the answer is NO..
will it make you feel better letting the engine temp warm up a bit, since most car manuf. say drive away after starting -- but will it be a deal-breaker? -- NO
note: these cars are not port injected engines which enrich the fuel mixture (cold start) at the intake port and are usually trying to overcome a "cold" lean condition, direct injection fires the fuel into the comb chamber with out mixing air and fuel (outside of the comb chamber). so the mix is a lil richer, the car seems to stumble just a bit .. and the exhaust sound a whole lot different -- louder cuz the secondary air pump is dropping a ton of outside air into exhaust system to warm up the cats. the exhaust flap closes off the exhaust pathway to one muffler, limiting the flow -- again, to let to catalysts to warm up quicker. letting the car warm up for 30-45secs couldnt hurt
varying the engines RPM range and putting the car under different load conditions may be good..
not trying warp speed blast @ wide open throttle in the first thousand or so miles may be good ..
letting the engine have a short cool down period prior to shutting the car off .. well, it could help dissipate heat and allow the block to cure properly (see that its a new casting that gone through a few test bench runs at the engine assembly facility) couldnt hurt. is it required? --NO
but the fact remains -- you can drive it like you stole it -- or treat gingerly and never see the cars true potential ... its been my experience that you car is not going to feel "real good" for probably 5-6km --
i'd go with your gut feeling -- whatever that may be
      07-01-2009, 05:13 PM   #12
HighVoltage
HighVoltage's Avatar
Drives: 07 E90 335i
I agree. Once the rings seal it doesnt really matter...
Not only will it kill you it will hurt the whole time while you're dying.
http://www.stevesnovasite.com/
http://www.jalopyjournal.com/forum/
http://www.garagejournal.com/
