SSK on XI
06-30-2009, 05:43 PM | #1 |
48
Rep 609
SSK on XI
which SSK do you use?
what's been your experience? recommend it? I did but most of the info is on difficulty of install rather than experience |
07-01-2009, 12:09 AM | #2 |
Rep 32
I have the BMW short shifter and the perforated M knob. I haven't tried any other options, but I drove a stock 330i last weekend and difference between the two was night and day or should I say sports car and truck. The install is actually very easy. You don't have to go under the car at all. Look for the install thread.
07-01-2009, 01:26 AM | #4 |
Air India
145
Rep 1,834
i use the z4m lighted shift knob.
i am going to try the UUC ssk. I really like their SSK on my friends e46 m3 and my friends e90 m3.
PKumarM3 |
07-01-2009, 06:09 AM | #5 | |
48
Rep 609
07-02-2009, 05:21 PM | #6 |
Rep 32
When I bought the SSK I had to buy the entire kit, now you can just buy the shifter. My part number for the kit with knob and boot was 25110430357 but the shifter has the #0434219 on it. It was the 330i version. I would guess the entire part number is 25110434219. I would just get the shift lever as the knob and boot with my kit was not one I wanted to use. I purchased the perforated knob and brake handle #25118037308. Hope this helps.
07-02-2009, 08:14 PM | #7 | |
48
Rep 609
07-03-2009, 08:10 PM | #8 |
158
Rep 6,805
DIY here:
http://www.e90post.com/forums/showthread.php?t=106829 Looks like some parts are different for the OEM SSK.
MY07 A22 E90 N52Nxi
07-05-2009, 09:23 AM | #9 |
137
Rep 8,067
I had the bmw ssk originally and it was ok. The intall was quick. It took about 15-20 minutes. Then UUC came out with their ssk and i had it installed because you had to remove the transfer case. all I can say is WOW. i have the UUC weighted shift knob also installed. Its a little pricey but its so worth it. If anyone is interestedyou should find the post about the UUC ssk on the forum. Me and this guy longo had them installed on our xi models and did a write up on it.
07-06-2009, 04:38 PM | #10 | |
48
Rep 609
07-09-2009, 11:37 PM | #11 |
Ski bum
317
Rep 6,198
http://www.e90post.com/forums/showthread.php?t=279940
Been there, done a bunch with the BMW OEM for the 330. PM me, mine is up for sale.
1999 e46 328i Ti Silver / Black[retired] 2007 e90 335xi Jet Black / Black[retired] 2011 e70 X5 35d Vermillion Red / Cinnamon 2011 e92 M3 LeMans / Fox Red extended |
07-17-2009, 02:39 PM | #12 | |
109
Rep 1,801
I'll post DIY pics when i get this on. Likely be doing this the same time as the cdv mod. Thanks again Jason! |
07-17-2009, 08:18 PM | #13 |
17
Rep 146
I just had a dealer tell me that the BMW Performance SSK would not shorten the stick and only marginally shorten the throws. He also said that the install would be very involved and take 2-3 service hours....what's the deal??? I also did not know that UUC made a SSK for the Xi. I must be missing something or maybe it's cause I have the 328, not 330, 335.
07-29-2009, 02:49 PM | #15 | |
109
Rep 1,801
08-01-2009, 09:42 AM | #16 | |
18
Rep 429
Summary: the stock style shifters from other 3-series suck IMO. They just shorten the throw while increasing effort. Not all that bad unless you have a notchy 2nd gear like most of us. Then these shifters make it even worse. I had a 330 shifter in for a month and took it right out for the UUC which is pricey but substantially better IMO. FWIW you don't drop the "transfer case" to install a UUC on a 335XI- UUC instructions state that you need to lower the whole rear of the trans by putting a jack under under it, unbolting the exhaust, unbolt the trans X-member/support and then lower the trans enough to get your hand up there from the bottom. The procedure is actually required on a 335i as well- it's not a 335Xi thing. I describe in my DIY here http://www.e90post.com/forums/showth...&highlight=uuc how I was able to do it entirely from the top but it involves grinding a small relief in a non-critical area of the steel pivot cup on the UUC. Easy to do with the right tool and a ton faster than getting under the car.
2014 Audi S5 DSG
2011 335xi Sedan (retired) 2008 335xi Sedan (retired) |
08-02-2009, 09:36 AM | #17 | |
Ski bum
317
Rep 6,198
07-21-2011, 04:46 PM | #18 |
22
Rep 1,083
Drives: 2021 M2C 6MT
Garage List My garage spot [0.00]
07/07 BMW 335xi [8.50] 2001 Honda CBR600F4i [0.00] 2007 Husqvarna SM610 [0.00] 2004 Chevy Tahoe Z71 [0.00] 2005 Harley Davidso ... [0.00] 2007.9 335xi [6.50] |
sub
2021 BMW M2 Competition, BSM, Exec Pkg, 6MT
GONE:07/07 E90 335xi SG Black Dakota|Alum|ZSP|2AB|ZPP|ZCW|Nav|CA|6FL|PDC| Blacklines|3M Summers: 235/40/18 265/35/18 Hankook Ventus V12 on VMR 701s A/S: 225/40/18 255/35/18 Pirelli PZero Nero M+S on OEM 162s |
07-21-2011, 07:14 PM | #19 |
63
Rep 788
If anyone wants a UUC ssk for 335xi I'm selling mine!!!
JB4 Trebila tuned cp-e IC AMS exhaust BMS DCI AR DP's METH RB TURBO
19" VMR VB3 Stoptech BBK TC KLINE VORSHLAG SPEC STG 3 OSS design |
07-25-2011, 04:30 PM | #20 |
Waaka Waaka
41
Rep 486
I gave up on this as the BMW OEM SSK is not intended for an xi. I contacted so many dealers on this and they all said the same thing.
Interesting people here seem to be running the full kit (not just a knob) without an issue. |
07-25-2011, 06:53 PM | #21 |
22
Rep 1,083
So is there anything special for an xi if one wants to just replace the tall oem shift knob w a shorter weighted one? Does it just stick up a little higher compared to a non-xi?
I can deal w that.
07-26-2011, 10:49 AM | #22 |
Waaka Waaka
41
Rep 486
^Nothing special to do, (pull off the knob, put on a new one) but that doesn't really accomplish much except asthetics. If you're trying to reduce the throw and shifting experience just the knob won't do too much. Some may say it's actually tougher to shift due to the loss of leverage, despite the weight increase in the knob.
XI and non-XI OEM knobs are the same. My issue remains that BMW dealers don't seem to support a SSK (full kit) for XIs. |
