Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Does one even NEED an intake?
      06-28-2009, 05:26 PM   #1
persian54
persian54's Avatar
Drives: M760/G83M4
As some may have noticed, I have posted several topics relating to intakes in some way or another...
well this is because I don't want to send X dollars without knowing if it's worth it (as I am sure many understand)
If I am going to be running a PROcede Rev2, and other than that, I don't see myself getting an exhaust or downpipes (at least not in the near future)
so... would I even need to change from the stock intake? (whether it be injen afe stett etc)
Thank you and sorry for being such a nuisance :P
      06-28-2009, 05:28 PM   #2
200Duece
200Duece's Avatar
45
Drives: '73 2002,'18 X5 35d,'17 328d T
no
1988 E28 535is Euro Conversion --- sold
2009 E90 335 6MT --- sold
2003 E39 540iT Msport --- sold
      06-28-2009, 05:31 PM   #3
ThorsHammer
ThorsHammer's Avatar
Drives: '09 BMW 335i Coupe
If looks and sound are important to you, then yes, a dual cone or cold air induction will help. Performance-wise, it's debatable. Similar results have been achieved with both a high-flow drop in filter, dual cones, and CAI.
"SYONRA" is for sale! http://www.e90post.com/forums/showthread.php?t=366678 BSM '09 e92 335i | Performance: JB3, RR Catted DP's, INJEN DCI, Britalman Exhst, AA FMIC, FORGE DVs | Suspension: ST-V1 Coils, Hotchkis Chassis Brace & F/R Sways | Wheels: Bremmer Kraft BR03s, Brake Performance Rotors, Cool Carbon Pads, ECS Lines | Exterior: OEM Aero Lip/Rear, ****** CF Trunk Lid, BLUX5 Angels, M-Force M3 Sides | Interior: Passport 9500ci, Black Trim, M3 Wheel
      06-28-2009, 05:43 PM   #4
persian54
persian54's Avatar
Drives: M760/G83M4
In any car that I have had, I have rarely opened the hood.. so looks is not an issue...
performance gain (like hp gain) not that big of an issue as much as allowing my engine to run without (or less) problems due to increased air flow.
but if the stock one is enough or more than enough.. then much of a point in that area
sound is nice, but is it worth a 170/280 dollars? debatable... I'd rather get a smarttop if sound is the only thing...
its just that my car runs at an avg of 240 degrees even without a procede so i'm scared that it'll run much hotter when I do install it...
      06-28-2009, 05:44 PM   #5
ThorsHammer
An intake won't affect that. What you need is an upgraded front mounted intercooler.
      06-28-2009, 05:58 PM   #6
TheTwinz
11
Drives: 300Z
dude, you've already made up your mind that intake isn't worth it. so why do you keep asking us to convince you otherwise if you aren't taking anything we say seriously.
      06-28-2009, 06:00 PM   #7
xsb00st
Drives: Slow
An intake will not help you with the oil temps. If that's what you're worried about, save your money and put it towards an upgraded oil cooler.
      06-28-2009, 06:06 PM   #8
persian54
persian54's Avatar
Drives: M760/G83M4
If i had decided, life would have been easier :/
yet, i cant complain that the main questions on my mind now are what to do and what not to do and what should i do etc regarding my (already amazing) car....
Thank you all for the information
Intercooler does make the most sense.
I have only recently joined this forum and have learned a great deal of important and useful information from fellow members.
Thank you all again.
      06-28-2009, 06:10 PM   #9
roozie2001
Just some guy
roozie2001's Avatar
Drives: 2008 White 335i sedan
be a man. make a decision. stick to it.
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
      06-28-2009, 06:10 PM   #10
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
You would need pretty big HP before the stock airbox won't flow enough - south of 400, until then, the stock airbox and a drop in are just fine and generally will be getting cold air better than dual cones.
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      06-28-2009, 08:01 PM   #11
D.B.S
D.B.S's Avatar
30
Drives: '11 X5 35i / '13 S5
He's right on the money, more or less... An intake makes great noises under the hood, and might give you a small bit of hp on the high end, but they really don't do much else unless you are running a 400+ HP engine. Better off with stock or even a drop in filter... Personally I'm getting a K&N drop in filter, after warranty ends (Aftermarket FMIC and Oil Cooler)... If your worried about temps, that's what you should do as well...
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi)
2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune
      06-28-2009, 08:04 PM   #12
persian54
persian54's Avatar
Drives: M760/G83M4
Thanks.
I'm not worried about my warranty ending... thats 4 miles/50k miles... and I'll be out of the car before then most likely...
life is short.. gotta drive as many beautiful cars as I can...my goal in life actually..
      06-28-2009, 08:11 PM   #13
Vudoo4u2
Night Sh1ft
Vudoo4u2's Avatar
458
Drives: F95 X5MC LCI
as with any forced induction car, the more volume of air you can get into the system, the happier your engine will be. While the temperature coming in from the intake side is important, test results shown give the stett cai a few degree F advantage, which doesnt really translate into much difference vs a DCI if you consider going through the fmic as well etc. Overall, when your engine needs more air, the stock airbox will be limiting you. While you may not need more of that air now, as soon as you strap a tune on your car and are essentially adding 80% more boost, a little more air is beneficial, even at the expense of a couple degrees higher intake temp.
all in all...get FMIC...it makes a huge difference on AIT in comparison to the intake, which you need to increase volume of air brought into the system
sadly its not a simple answer
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson
      06-28-2009, 08:14 PM   #14
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
why not find out for only 100 bux?
http://www.e90post.com/forums/showthread.php?t=277015
the sound is really cool, with a high powered tune it can make a difference but not big from my experience.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      06-28-2009, 08:26 PM   #15
zaxjax
43
Drives: 2008 Crimson Red 335i
2008 335i  [9.00]
If you don't want to spend a ton, go and pick up two dual cones from Autozone or Pep Boy's and make your own. Take off your stock box and put on your two cone intake filters on the intake hoses, clamp and your done. There is a DIY somewhere.
      06-28-2009, 10:50 PM   #16
Slidewayz
Slidewayz's Avatar
33
Drives: 2007 335i
With the amount of coin you've dropped on the car, angst over $200 for a DCI is not making the most sense to me.
      06-28-2009, 11:19 PM   #17
gerardm
gerardm's Avatar
Drives: '07 335i Sedan - Alpine White
u can find bms dci's for like 100 bucks on ebay and shit
      06-29-2009, 06:03 AM   #18
Spydeputy
Spydeputy's Avatar
Germany
205
Drives: 2015 F23 M235i/2008,E90,335xi
just go w/ a up graded drop in, and call it a day.
      06-29-2009, 06:16 AM   #19
Former_Boosted_IS
307
Drives: 4 Wheels
Why don't you guys ask Terry what the wastegate duty cycles look like on a tuned car with the stock intake. I think you will quickly find that running a tune on the stock intake is not a good idea.
      06-29-2009, 08:42 AM   #20
dr.roro
Drives: 2019 G01 X3
I've seen a few people on this thread recommend a drop-in filter. Are these really better than the stock OEM filter? If so, which ones are people finding to be actually better (K&N, Helene Streamline, BMC, ITG, aFe, Macht Schnell)?
      06-29-2009, 08:47 AM   #21
Former_Boosted_IS
307
Drives: 4 Wheels
The funny thing about drop-in filters is that they were dyno tested and showed no gains, but no one seems to believe the dynos. It is kind of odd.
      06-29-2009, 10:04 AM   #22
D.B.S
D.B.S's Avatar
30
Only good thing about a drop in, is you clean it and re-oil it and drop it back in again, don't have to worry about buying a new filter every 20-30k miles...
