Vishnu stage 3 VS JB3 map 13
06-25-2009, 08:28 AM | #1 |
47
Rep 507
I found this on a car forum in Sweden, The cars have similar mods ,the silvergrey car has is fully modded with Jb3, camera car is a coupe fully modded, the only difference is that the camera car is a coupe with catted dp.The wagon has uncatted dp
Camera car stage 3 settings (81%) jb3 on map 13 (racemap), there was a difference with app 2 cl´s between 81% to 85%. 94octane gas. http://www.garaget.org/video/c282mlergdz7 Last edited by per; 06-25-2009 at 08:49 AM.. |
06-25-2009, 08:32 AM | #2 |
133
Rep 4,764
Good find. Can someone give details on the upper maps for jb3? Don't really know much about 10-13. Is there higher than 13?
06-25-2009, 08:50 AM | #5 |
161
Rep 7,377
those maps are custom and works with a lowered resistor to upp the boost.
06-25-2009, 10:10 AM | #6 |
327
Rep 4,484
Something not right there. You can't run Map 13 on 94 Octane, you need at least 100 Octane to run maps over Map 10.
So if he was running Map 13 on 94 Octane, he was getting a lot of power being pulled via knock or timing. Wagon would be a sleeper for sure. How much does the wagon weigh? |
