HELP!!! Procede Limp Mode During Install
06-23-2009, 10:00 PM | #1 |
Night Hawk
12
Rep 91
I just bought a PROcede V3 PNP Rev I. for my 07 335i 6MT.
I was installing it today, following the directions on YouTube to a "T". When I finished installing the harness, it came to the time to start the vehicle (as per the video). (WITH JUST THE HARNESS INSTALLED) The engine turned over the first time I pushed the start/stop button, however the starter really had to work for it. Then I received (in order) the following error lights: Suspension Control System Failed Drive-off assistant has failed Full engine power no longer available (limp mode light) After that I contacted Vishnu through email and got this response: "Be sure that you have only one arrow on either side of your connections. In other words, when you look at the connection between the factory sub connector, and the harness sub connector, you should only see one arrow on either side. If you see two arrows on one side, it has gone wrong." That was not the problem. The tech offered to work with me over the phone but at the time I couldn't. So I "screwed the pooch" on that one. I'm leaving for Jamaica in the morning and have to spend the next week trying to figure this out online before I get back and can talk to Vishnu. Has anyone had a problem like this that they've resolved? This is the first time I've done anything like this and I'm kinda concerned. |
06-23-2009, 10:05 PM | #2 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Shiv |
06-23-2009, 10:18 PM | #3 |
Night Hawk
12
Rep 91
That's why you are the man! You hit it right on the head.
Since it's used, am I going to run the risk of running the wrong map and firmware? Can I update those before start-up, as long as the power is on? |
06-23-2009, 10:20 PM | #4 | |
1737
Rep 17,960
Drives: A Lot
Cheers, Shiv |
06-23-2009, 11:34 PM | #6 |
75
Rep 1,009
Drives: 2007 JB/Saddle E92 335i
Damn.. impressed.
09-08-2009, 04:00 PM | #7 |
64
Rep 158
I have been having almost the same exact issue, except I have the v.2 Procede, NOT the PNP harness. Are these bypass plugs needed for the v.2 as well?
09-08-2009, 04:07 PM | #8 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
09-08-2009, 04:17 PM | #9 |
64
Rep 158
Yeah, that's the video I've been using, and I've tried re-installing it on three separate occasions, always carefully following the instructions. Each time, I get the same errors. I doubt I did it wrong 3 times, right? :-) I guess it's possible that since there are a bunch of loose wires to connect, that one of the loom's wires has come disconnected inside the plastic covering and that's what is causing it. :-(
I didn't think it needed bypass plugs, but after reading the above post, I figured I would ask! Thanks! |
09-08-2009, 04:18 PM | #10 |
Vishnu Powered
68
Rep 2,205
The bypass plugs were used mainly for troubleshooting the harness. With the old pin-out harness sometimes the problem would lie with a loose connection. This is no longer the case with the PNP harness. The bypass were also good for when you take your car to the dealer. You just unplug the procede and install the bypass. It was more of a pain back in the day to take out the pin-out harness.
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3 |
09-08-2009, 04:28 PM | #11 | |
125
Rep 3,004
09-08-2009, 04:56 PM | #12 |
64
Rep 158
Definitely don't think I swapped any of the connectors. I only worked on one connector at a time, following the video at every step. Do ya'll think I might be better off upgrading to the PNP harness for v.2 procedes? What do you gain (other than the obvious easy connections)? Worth it?
09-08-2009, 05:14 PM | #13 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
12-15-2009, 07:18 PM | #14 |
Rep 2
Similar situation
The exact same thing happened to me yesterday as I was coming home from work!
I had all the exact same warnings light up for me. I "limped" home at about 30 km/h. I have not modded the car in any way, I just bought the car from a dealership in Sept. I took it to the dealership today and the only thing that happened when I turned it on this morning was that the "check engine" light came on. Once they turned it on in the dealership (inside the garage...where it is heated) all was fine. They told me that i might have to replace the intake manifold (dunno why...cracks in it maybe?), but that they were going to let it sit outside over night and try it in the morning (when it isn't going to be nearly as cold as it was last night (-8 C/18 F). All I can think of is that it was COLD last night (-32 C/-26 F) and I was driving with the DTC on, but I was at a red light when it happened. Any ideas/suggestions that I can bring up to the mechanics? The car is under warranty so I'm not overly concerned, but I don't want this happenign again once the temp drops. |
12-16-2009, 10:42 AM | #15 | |
133
Rep 4,764
Hoping they don't come back. Since this isn't tune related, maybe make another post, or search for others. I have seen people need to get the steering angle sensor or ABS sensors replaced. Last edited by scottp999; 12-16-2009 at 11:04 AM.. |
12-16-2009, 10:33 PM | #16 | |
14
Rep 329
